Old 12-12-2007, 11:45 PM   #1
remowgn
Member#: 41149
09 FXT
SSM
Default Question for people who have had a separate Torco map made...
Hey folks... I'm about to get a retune on friday, and I want to get a torco map this time around.
For those of you who have had their cars tuned for a torco map... were you able to just dump a can of it in on the dyno and go, or did you have to add some more fuel in at the same time to get everything to mix properly? I'm just wondering whether I'm going to need to bring a 5 gallon can of 91 with me so that I can get everything to blend well. I'm gonna have pretty limited dyno time, so I need the easiest drop 'n go solution I can find!
Also, what kind of results did you get? I've seen some dyno charts with good increases- nothing like race gas, mind you- but that's not what I'm expecting.
remowgn is offline   Reply With Quote
Old 12-12-2007, 11:57 PM   #2
n2oiroc
Member#: 141952
03 11 wrx/13 brz
just dump it in! no need to pre mix or drive around to mix it. here is mine with 93 octane in blue and torco in red. huge difference! the chart doesnt show how much more responsive it is! nothing was changed betwen runs except the addition of torco and retuning. 1.5qts torco to 1/3rd of a tank of gas. (107 octane)
n2oiroc is offline   Reply With Quote
Old 12-13-2007, 01:10 AM   #3
remowgn
Member#: 41149
09 FXT
SSM
Excellent! That's what I like to hear. So you put in a can and a half? Or have you moved up into the big leagues of buying it by the 5-gallon drum?
Old 12-13-2007, 01:15 AM   #4
n2oiroc
Member#: 141952
03 11 wrx/13 brz
5 gallon drum, but i have a small pump and a 1 gallon gas can that i pre measure with. torco rocks! the only negative i can come up with is that it leaves your exhaust tip orange.
Old 12-13-2007, 05:22 PM   #5
remowgn
Member#: 41149
09 FXT
SSM
Bump for anybody else?
Old 12-14-2007, 03:42 AM   #6
gtasti
Member#: 152036
2004 Sti
hrmm can this stuff cross the boarder
cause ive never heard of it
i'm sure they dont sell that here in canada
gtasti is offline   Reply With Quote
Old 12-14-2007, 11:03 AM   #7
twigg107
Member#: 119718
2008 STI
Check it out...
http://torco.com/content/view/74/26/
twigg107 is offline   Reply With Quote
Old 12-14-2007, 12:05 PM   #8
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
amazingly, but this stuff does work
I put in full bottle with NY 93, and the IAM jumped to 16 from 8 (JDM STI map on 93 octane = pinging bad)
as a reference, I am getting IAM 16 @ Moscow RON98
the only downside is Torco puts this orange stuff on your spark plugs
Hyper is online now   Reply With Quote
Old 12-14-2007, 05:12 PM   #9
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
I used to use torco and had a torco/96 tune and then a torco/100 tune.
Basically I'd fillup with 100 octane but if I had to make a long trip I'd haul a few cans of torco with me.
IMHO Torco's not worth it. Works? Yes, but it's JUST AS EXPENSIVE AS 100 octane if you're going to run in on a daily driver.
Even the most expensive alcohol kit out there (Perrin) will pay for itself in less than a year. Once you go meth, you don't get back
verc is offline   Reply With Quote
Very easy simple Ground Control question for people who have them installed Blaze-65 Brakes, Steering & Suspension 1 05-13-2009 09:15 PM
Question for people who have moved cross country nos Off-Topic 31 10-30-2006 10:49 AM
Question for those who have had extensive track time with the STi Zoso STi Forum Archive 22 08-22-2003 09:56 PM
questions for people who have the kaminari wing djrocker666 Interior & Exterior Modification 1 03-12-2003 08:11 PM
Questions for people who have their windows tinted CM Vancouver Impreza Club Forum -- VIC 14 09-16-2001 03:37 PM
