Welcome to the North American Subaru Impreza Owners Club Saturday July 4, 2015
Old 04-19-2001, 05:26 PM   #1
Joncas
Member#: 5349
Post I'm an idiot or something is wrong.
Ok,
Granted I just got the car so let the onslaught begin, but here's my deal.
I just recently purchased a '99 rs with 12900 miles (no snow/no rain). I found a few bothersome things and can't seem to figure out if its just the way it is or if something is the matter.
1. At around 45mph the car develops a whistle from wind and it appearrs to come from the right passenger side (maybe the middle?) All hatches and seals are tight. It is still there when I open the windows?
2. The center 2 vents are nice, but is the center driver's side vent suppost to be 1/4 as powerful as the center passenger's side vent?
3. Right rear wheel has started to make a wirring noise at about 60-65mph. Bad wheel bearing? Car came with aftermarket sway bar. Will that cause a problem with warranty on a wheel baring?
4. Going up my friends steep (i mean steep) drive way, I pull in very carefully as to not scrape the front of the car. As soon as I get a front wheel up, one of the rear come off the ground. Stiff suspension (sway bar?) or just something stuck. Harm done?
I have a feeling the car just wasn't driven enough... Yet. (12,900 in 3 years, 1500 last week)
So where does that put me. Idiot seat or taking it to the dealer under warranty?
Thanks much!
Thanks for input.
Joncas is offline   Reply With Quote
Old 04-19-2001, 05:34 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Post
Ok whislte noise from mirrors---normal.
whirring noise, scoobs are known for wheel bearings--warrenty, sway bar will not void it.
Make sure the thumbwheel on the side of the vent is at full open. If not warrenty.
As for a wheel comming off the ground! crap how steep is the drivway? No wheel should come off the ground, the sway bar will have not affect on this.
Welcome aboard, any more q's feel free to ask. Good luck with your RS. Youll learn alot here, and gladly be forking of your wallet in the near future for mods.
Jay McDade
Auto Tech--Lincoln/Mercury/Jaguar
www.hometown.aol.com/impreza25rs2000
Old 04-19-2001, 05:44 PM   #3
ChosenWon
Member#: 2236
2000 Audi S4
silver/rally dirt brown
Post
1.) I have heard the whistling is from the side mirrors.
The others.....I have no idea. They will probably make you pay a small fee to change over the warranty too.
ChosenWon is offline   Reply With Quote
Old 04-19-2001, 05:46 PM   #4
ChosenWon
Member#: 2236
2000 Audi S4
Post
He beat me to the mirror thing....btw, mine do not whistle, but my back window will sing like there is no tommarow!
Old 04-19-2001, 05:50 PM   #5
Frank
Member#: 3791
Post
i think the vent thing is by design. If you close the middle vents to say 50% im pretty sure the full pressure reaches the side vents and the power increases. Put your hand over the side vent and close the middle and you'll feel it.
Frank is offline   Reply With Quote
Old 04-19-2001, 06:42 PM   #6
Fido
Member#: 1867
Post
That vent thing is normal, so don't worry...I thought there was a problem with mine, too, and took it to the dealer to look at it. They looked at some other RSes on the lot (same thing happens), and took my dash apart just to make sure (no blockage), so it's normal on them, and they told me not to worry about it, so no worries
Fido is offline   Reply With Quote
Old 04-19-2001, 07:11 PM   #7
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
Post
My left front wheel sometimes makes a whining noise consistant with speed (slows down when I slow down, etc). I can't tell if it is the brakes or the wheel bearing. It went away after a 4 hour 80mph trip and then came back when I washed my car and used brake cleaner on the brakes.
Any ideas?
I've had this for about 9k miles (well before I put the metal master pads on). The dealer refuses to diagnose, saying "Oh all subarus have squeaky brakes that's just a flaw in the design"
And yes, exact quote. I'm not sure how the brakes can be squeaky without having the pedal applied, unless they are rubbing which I know the stock pads did not do.
remarcable is offline   Reply With Quote
Old 04-19-2001, 07:19 PM   #8
Sooberman
Member#: 5344
Location: Greenwood Lake, NY...where the heck is that?!? :P
2002 WRX WRagon
Platinum Slipper
Post
Regarding the rear wheel lifting off the ground...
It's kinda hard to diagnose without seeing/being there, but I would think that it is normal if the driveway is that steep and you enter at an angle. The same would happen if you enter a steep downslope (from level ground) at an angle.
Sooberman is offline   Reply With Quote
Old 04-19-2001, 07:30 PM   #9
cj917
Member#: 627
MY96 outback wagon
Question
about the whistle in 1), did the car come with aftermarket short shifter?
cj917 is offline   Reply With Quote
Old 04-19-2001, 07:34 PM   #10
pooreman
Member#: 3209
Post
Couldnt the whistle noise be from an misaligned window glass being to far out? Mine was actually so tight it bent some parts up--warranty fix. I actually had to get the dealership guy in the car and put the window down and let it go up and mark the glass at the sill and then open the door and watch it pop up almost a inch.
The vents sound normal and the driveway.
pooreman is offline   Reply With Quote
Old 04-20-2001, 09:32 AM   #11
v6scoobie
Member#: 1563
Question
With that low of mileage I hope you didn't get a car where someone at sometime reset the digital display on the odometer.Just a thought on a three year old car.
v6scoobie is offline   Reply With Quote
Old 04-20-2001, 10:08 AM   #12
Sardonic
Member#: 2445
RBP
Post
One more thought on the whistling...
I noticed mine had a whistle coming from the right side as well. I couldn't figure out what it was, until I turned on the windshield wipers. It went away while they were moving, then came right back when they came back. And it only happened at 70-75mph.
Sardonic is offline   Reply With Quote
Old 04-20-2001, 10:39 AM   #13
AWDrivin
Member#: 1687
99 2.5RS
Post
I have a '99 too. After I put my 20mm sway bar on I noticed the same thing happens when I enter my driveway at an angle which also has a very steep entrance.
Cdb
AWDrivin is offline   Reply With Quote
Old 04-20-2001, 10:53 AM   #14
SlideWRX
Member#: 3803
07 Mustang GT
285 is a wide tire!
Post
on the rear wheel bearing being bad, here is a test: (hopefully at a lower speed)
when you car hear the wirring noise, try swerving left and right several times(changing the load on the bearing). the noise should change intensity. then it is probably a bearing wearing out. The swerving doesn't have to be to severe, you should be able to stay in your lane.
As for the tire leaving the ground, that is pretty common on a steep drive way.
[This message has been edited by SlideWRX (edited April 20, 2001).]
SlideWRX is offline   Reply With Quote
Old 04-20-2001, 10:57 AM   #15
8Complex
Member#: 922
04 FXT
Red
Post
The lifting of the wheel is normal. I have an aftermarket sway bar and when I drove through the Land Rover test track, over the twist section (uphill and slanting to the side at the same time), it lifted the wheel very easily. Other examples - take a look at the picture on the header of my site - http://8compex.mwic.org
Old 04-20-2001, 11:11 AM   #16
remarcable
Member#: 2362
1999 Legacy Outback
Post
When you put a larger rear sway bar on a car you are decreasing the amount that the suspension can articulate.
This is why rock-crawling jeeps and other trucks have sway bar disconnects. This is also the reason why I really don't want to get a larger bar for the back of my Outback. I want the ALK but that is not STS legal.
This dude looks like he has his rear bar still connected <img src=http://www.offroaders.com/images/readers/brown/rb9-l.jpg>
This dude most likely has them undone:
<img src=http://www.bc4x4.com/tr/1998/gvi/gvi14.jpg>
Sorry I couldn't find better pics.
Old 04-21-2001, 08:36 AM   #17
Borjaq
Member#: 4812
04 STi
Blk
Post
I had a bad wheel berring. Like a wind tunnel in the back of my car. 30,000mile 3 year warranty. My center driver's side vent does the same thing so I put a soda can in the cup holder. Seems to work a little better now. Like everyone else said the whistling is normal. Also get your rear pinion seal checked too. I heard of that going bad often and GreaseMonkey told me I had a minor leak from it last week. I also need a new clutch.
Borjaq is offline   Reply With Quote
Need an alignment or something else is wrong? BigWater Brakes, Steering & Suspension 6 08-11-2009 11:45 AM
"Help, I'm an idiot!" or "Brake systems 101 for dummies" woofmaster Brakes, Steering & Suspension 5 07-29-2006 08:54 PM
Hi, I'm an Idiot (Unit is Slipping) Unit 91 Off-Topic 82 07-06-2004 12:33 PM
I'm an idiot. See pic inside...Audiophiles; Is it salvageable? ChosenWon Car Audio, Video & Security 19 10-10-2001 11:07 AM
I'm an IDIOT! John2.5RS Southern California Impreza Club Forum -- SCIC 2 05-30-2000 12:55 AM
