Old 12-14-2007, 01:29 PM   #1
reddd02kg
Member#: 157610
Default Just put in My Boost gauge
I just got an autometer boost guage and pyrometer. I haven't hooked up the pyrometer yet and would appreciate any advice on tapping the manifold.
The boost guage peaks at 14 and then drops down to a steady 12. Is the spike just build up or am I actually hitting 14 psi? Pretty much Im asking if boost will build up and peak to give me a false reading. I taped into the line coming out of the top of the stock bypass valve for the T fitting on the guage.
I have not tuned my car yet, bad I know, and these are my upgrades that matter:
TXS Upipe
TXS TBE
reddd02kg is offline   Reply With Quote
Old 12-14-2007, 02:07 PM   #2
iri_tuan
Member#: 80572
06 STi
waiting for something new
its just your boost tapering down a bit.
next step, get some type of EM asap!
iri_tuan is offline   Reply With Quote
Old 12-14-2007, 02:24 PM   #3
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Without a doubt I would have got a tune before buying the gauge JMO. All those mods and not even an OTS map is just asking for trouble.
4ST-AIR is offline   Reply With Quote
Old 12-14-2007, 02:42 PM   #4
WRXislander
Member#: 50064
'02 WRX
MBP
Remember, he has an '02.
WRXislander is offline   Reply With Quote
Old 12-14-2007, 03:55 PM   #5
WRXGus
Member#: 124484
05 WRX PSM
Cobb Stage II
Yea what he said. With the '02 WRX's you dont need EM for a TBE, but it always helps.
WRXGus is offline   Reply With Quote
Old 12-14-2007, 04:00 PM   #6
Mayor McCheese
Member#: 117018
79 Rexor on Dubs
Paws McGillicutty
Mayor McCheese is offline   Reply With Quote
Old 12-16-2007, 12:58 PM   #7
reddd02kg
Member#: 157610
I got the gauges so I could tune myself with some sort of open source tuning program. Any other option was way more money than the gauges.
Old 12-16-2007, 01:11 PM   #8
CynicX
Member#: 48199
06 WRX
Its normal for then engine to suck the life out of a small turbo. I used to peak the TD04 around 17.5-18 psi and see around 10ish psi by redline. A larger turbo and tuning will hold boost better until redline....
What I'm saying is you most likely are hitting 14 psi and its dropping to 12....and that is normal....
CynicX is offline   Reply With Quote
can i "T" my EBC in my boost gauge? revenance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-21-2008 06:41 PM
just put in my rear strut bar ychan Mid West Subaru Owners Club Forum -- MWSOC 6 03-10-2003 10:34 PM
Condensation in my boost gauge ?! BuickturboV6 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 12-22-2002 01:54 PM
New to Turbos and I just put in a boost gauge, now I have a question gotsol Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-09-2002 08:33 AM
Where should i put my Boost Gauge? bluperlrex Interior & Exterior Modification 1 06-06-2002 06:36 PM
