Old 12-14-2007, 03:50 PM   #1
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
4eat Stage 2 Protuned
Default Quick AP v1 dealership clearing CEL code hypothetical question
This has always been on my mind and never really found an answer but here it goes:
Let's say you are running a Stage 2 base map (Protune soon) and for some reason you throw a code, for like example misfiring spark plugs (had this issue before I ran any EM and mods, so let's use that an example), you go to the dealership (Stage 2 loaded on the ECU) and they perform the work, and clear the CEL codes from the ECU. Is the Stage 2 base map at all affected by their clearing of the CEL codes, or is it only effected if the dealership decides to flash the ECU? Also what would cause the dealership to flash the ECU? What kind of work would need done by them to constitute flashing your ECU and clearing your ECU of any COBB maps?
Thanks for the help!!!
eurospek is offline   Reply With Quote
Old 12-15-2007, 12:02 AM   #2
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
if you have an AP, why would you goto a dealership for that?
if you have a pro tune it should be in your AP
if the dealer flashes the ecu your screwed because your AP will no longer be married to your car
a6n6d6y is offline   Reply With Quote
Major Issues 2.2 Only Running On 2 Cylinders After I Cleared Cel Codes (iacv) bcustom561 Service & Maintenance 2 05-20-2010 09:17 PM
Can the UTEc clear CEL codes? scutzi128 UTEC 7 11-02-2007 09:19 AM
quick AP v1 ? Giganticprune Newbies & FAQs 2 09-22-2007 01:46 AM
AP ? - How To Clear CEL j-wrx Engine Management & Tuning 4 07-13-2005 10:58 AM
Madison WI: anyone able to read/clear CEL codes? davearm Mid West Subaru Owners Club Forum -- MWSOC 1 08-13-2004 12:43 AM
