Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 01-28-2008, 10:20 AM   #26
benjaminenjamin
Member#: 153982
2012 Impreza WRX 5dr
Satin White Pearl
Just ordered one as well awesome pricing. Thanks Perrin!
benjaminenjamin is offline   Reply With Quote
Old 02-13-2008, 01:12 AM   #28
bemani
Member#: 5673
02 bug eye, 05 LGT
Originally Posted by Perrin View Post
Also as a special treat to those following the Project 15K saga, I am offering a 15% discount on the SLS system when ordered directly from our website.
CLICK HERE!
During checkout apply coupon code SLSRULES (must be caps no spaces) to get 15% off the item! This is a great deal on a great product!
Thanks again NASIOC!
[email protected]
Coupon doesn't work anymore?
bemani is offline   Reply With Quote
Old 02-13-2008, 01:50 AM   #29
PERRIN_Ken
Member#: 165212
Blaze Yellow
PERRIN_Ken is offline   Reply With Quote
Old 02-19-2008, 11:03 PM   #32
shift0246
Member#: 136553
02 bugeye,fozz
driftslut rx-7
is it me or does the perrin and whiteline subframe kits look the same but they install differant?
shift0246 is offline   Reply With Quote
Old 02-20-2008, 12:15 PM   #34
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
How long is the sale for?
BeBop86 is offline   Reply With Quote
Old 02-20-2008, 12:18 PM   #35
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
How long is the sale on?
Old 02-20-2008, 05:16 PM   #37
shift0246
Member#: 136553
02 bugeye,fozz
driftslut rx-7
i mean i am looking at both installs and the perrin loks like it is for the rear and the whiteline and kart boy are for the front it seems to me cause on the whiteline install guide it says nothing about the rear diff its all for the front
Old 02-21-2008, 11:07 AM   #38
PERRIN
NASIOC Manufacturer
Member#: 6776
Got it now! Different product. The PSRS from PERRIN goes on the front. Click HERE!
VS.
The subframe lock down shown in the DIY above.
Each product does a different thing. The PSRS is an anti-lift system for the front suspension under braking and hard acceleration. Plus with the additional caster angle it dramatically improves steering response. (Hence the name Positiver Steering Response System.)
The rear subframe lockdown system prevent axle trounce, driveline lash, improves throttle to drivetrain control etc.
Thank you for the follow-up question!
[email protected]
PERRIN is offline   Reply With Quote
Old 02-21-2008, 09:53 PM   #39
shift0246
Member#: 136553
02 bugeye,fozz
driftslut rx-7
oooo so the whiteline and kartboy kits are just a step blow the psrs system? instead of the psrs peice they use bushings? is that what you are telling me? and would it be wise if i made my own bushings for the rear diff bushings inserts because i have left over polyurethane bushgings from my energy suspension kit i got for my old car and im pretty sure if i trimmed them down i could make them fit do you think this would be wise?
Old 03-03-2008, 03:31 PM   #40
wrxhard
Member#: 108091
Finally got around to installing mine last night. I love it!!! Easy install and small investment for a huge return in the feel of the car. Infreakincredible.
wrxhard is offline   Reply With Quote
Old 03-04-2008, 11:55 AM   #41
PERRIN
NASIOC Manufacturer
Member#: 6776
First part yes that is correct.
Second you should be just fine. As long as you can get it to fit that is ok. You will be missing all of the metal piece to lock the subframe, but other than that you are a-ok!
Let us know how we can help further!
[email protected]
Old 03-04-2008, 11:55 AM   #42
PERRIN
NASIOC Manufacturer
Member#: 6776
NICE! Thanks for the post and the biz-nez!
Adam
Old 03-04-2008, 01:15 PM   #43
unclemat
Member#: 114530
2005 LGT 6MT wagon
Are you going to offer this for 2008+ Impreza? If so it should also fit 2005+ Legacy. Supposedly all the bushings are the same.
unclemat is offline   Reply With Quote
Old 03-05-2008, 10:57 AM   #44
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
Default ordered
ive had a list of parts of parts im working twords. its large. this rear subframe lockdown was on the list and now that its on sale i ordered it . let the suspension work begin . this is my first step in rear . next comes larger sway bar , end links , mounts, lateral links, trailing links , assorted chassis stiffening bars ,well see how it feels after all that in the rear if its too loose still ill look at coilovers. i just cant see swapping out the stocker struts and springs yet cause they still work . once they go bad ill upgrade , but we will see how other mods affect performance first.
watchunglava is offline   Reply With Quote
Old 03-05-2008, 11:13 AM   #45
PERRIN
NASIOC Manufacturer
Member#: 6776
Old 03-05-2008, 11:14 AM   #46
PERRIN
NASIOC Manufacturer
Member#: 6776
First THANK YOU for the purchases. I agree you should build your car in the manner you want to do it. Choose as you want the upgrades to go. Let us know how we can help with any of the planing etc.
Thanks again for choosing PERRIN!
[email protected]
Old 03-05-2008, 11:38 AM   #47
unclemat
Member#: 114530
2005 LGT 6MT wagon
Old 03-05-2008, 01:01 PM   #48
PERRIN
NASIOC Manufacturer
Member#: 6776
Old 03-07-2008, 01:35 PM   #49
watchunglava
Member#: 168862
Default questions
i ordered my kit and its on the way . ok the bushing upgrades i understand and im down. but the lock out bolts? ok do these lock out the rear diff??? like make it useless and make my rear axles act as one?this is what i understand a diff lock out to be . or does it just tighten up the suspension? im curious because i would love to lock my rear diff on the dirt , but on a road i like the function of the rear diff . can you please clarify what exactly the " lock out " bolts accomplish?
Old 03-07-2008, 03:08 PM   #50
unclemat
Member#: 114530
2005 LGT 6MT wagon
DIY Perrin Rear Differential Cover Installation PERRIN_Ken Transmission (AT/MT) & Driveline 75 02-02-2016 04:07 AM
Perrin Subframe Lockdown System (SLS) on 2010 WRX Sedan Blue_Rex Car Part Reviews 5 04-12-2010 11:02 PM
Rear diff bushings/ lockdown systems opinions? mostasz Newbies & FAQs 14 09-20-2008 09:01 PM
Perrin Rear Differential Subframe Lockdown 06blacksti Transmission (AT/MT) & Driveline 6 01-19-2007 04:46 PM
