Welcome to the North American Subaru Impreza Owners Club Tuesday August 4, 2015
Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 03-07-2008, 04:38 PM   #51
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
Default anyone?
Originally Posted by watchunglava View Post
i ordered my kit and its on the way . ok the bushing upgrades i understand and im down. but the lock out bolts? ok do these lock out the rear diff??? like make it useless and make my rear axles act as one?this is what i understand a diff lock out to be . or does it just tighten up the suspension? im curious because i would love to lock my rear diff on the dirt , but on a road i like the function of the rear diff . can you please clarify what exactly the " lock out " bolts accomplish?
anyone know the answer to this????
watchunglava is offline   Reply With Quote
Old 03-07-2008, 06:16 PM   #52
ATK
Member#: 123698
2004 WRX Sportwagon
From what I understand, this is the bolt you're talking about. I'm pretty sure the bolt just locks down the subframe and doesn't allow the diff to clunk around.
ATK is offline   Reply With Quote
Old 03-08-2008, 02:06 PM   #53
Spike700
Member#: 136282
2002 WRB WRX
2010 Infiniti G37xS
What can I do if the threads that the subframe bolts are screwed into are rusted off?
Spike700 is offline   Reply With Quote
Old 03-09-2008, 12:50 PM   #54
PERRIN
NASIOC Manufacturer
Member#: 6776
ATK: That is correct. That is bolt / shim combo right there. Prevents the subframe from jouncing around!
Spike700: I may be missing something in the question, but my opinion would be to clean them and re-tap them. Should be a relatively easy affair. Let me know if I missed something!
Adam.Taft@perrinperformance.com
PERRIN is offline   Reply With Quote
Old 03-09-2008, 02:12 PM   #55
watchunglava
Member#: 168862
sweet , thats exactly what i thought it did . so what the bolts are . they are lock down bolts. i was just concerned they locked the rear diff . but i think welding is the only way to hook that up. just trying to be as informed as possible thanks for the clarification.
Old 03-09-2008, 10:09 PM   #56
Spike700
Member#: 136282
2002 WRB WRX
2010 Infiniti G37xS
Thanks Adam,
No you didn't miss anything. The threads are rusted out on my car so I was just wondering if there was something I could do. Thanks for the advice.
Old 03-10-2008, 11:14 AM   #57
PERRIN
NASIOC Manufacturer
Member#: 6776
Originally Posted by Spike700 View Post
Thanks Adam,
Koolio! No problem! Keep me posted!
Old 03-11-2008, 01:01 PM   #58
miked001
Member#: 91980
2005 WRX STi
"Locate the differential front support beam and the 2 outer bolts securing it to the chassis. Remove the passenger side large bolt securing the front support beam to the chassis, and the two bolts securing the plate to the chassis."
I have the parts on order. Is this step pretty obvious? I didn't see anything picturing this?
miked001 is offline   Reply With Quote
Old 03-11-2008, 01:07 PM   #59
PERRIN
NASIOC Manufacturer
Member#: 6776
Yeah I wouldn't stress just yet. It is pretty easy once you have the parts and car in front of you. However, if you DO get into a pinch, then let us know. Always happy to help!
Old 03-17-2008, 12:23 PM   #60
FleaDog
Member#: 96267
'06 20G-XT'd STI
CGM & NT03+M
installed this this past weekend. There is a circular piece of metal above the forward crossmember/brace, in between the stock rubber and the chassis....
Its not described/referenced in the instructions.. is this removed, or does the urethane bushing go on-top-of or below?
FleaDog is offline   Reply With Quote
Old 03-17-2008, 12:32 PM   #61
watchunglava
Member#: 168862
Default situation
same thing here man . on one side i put the plate underneath. on the other i put it on top.
when i put the second side together it was obvious the metal plate goes on top of the red bushing. i went back to the otherside and the metal plate was all bent up cause i put it on wrong. after fixing it and tightening everything up im pretty sure it bent back into place. it feels fine. next time i hae the car up on ramps or stands ill recheck everything.
Old 03-17-2008, 12:39 PM   #62
PERRIN_JOHNL
Member#: 125283
YES the metal plate goes on top. Good point on the instructions, thanks.
I'll have our instruction man look at it to see how we can illustrate that.
PERRIN_JOHNL is offline   Reply With Quote
Old 03-17-2008, 04:00 PM   #63
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Ya, those bolts, need to be tightened. In that position the subframe will not be locked down. Just crank'em down!
PERRINJeff is offline   Reply With Quote
Old 03-17-2008, 09:23 PM   #64
Furious George
Member#: 109742
MBP
Dammit! I just got around to installing this weekend, and was asking myself the same thing. I put bushing on top of plate because it didnt seem like the plate was going to sit flush against the chassis (I didnt notice it was there until it was fully disassembled).
Luckily though the install was very easy. My wife was amazed as it was the first time I told her I would be back in from the garage in an hour, and I actually was.
As a tip, I know a lot of people talk about the lockout bolts not threading in correctly. I took a tooth brush, which fits up there perfectly, and some cleaner and scrubbed the threads out well, and then blew them out with some air just to be sure. I also put a bit of lithium grease at the start of the bolt threads to ease the start. Both bolts went in nice and easy (finger tighten first for sure).
Furious George is offline   Reply With Quote
Old 03-18-2008, 05:04 AM   #65
Uber-Charged
Member#: 154313
2002 /2004 Conversio
n Stage 2 WRB
how much does NVH does it make?
Uber-Charged is offline   Reply With Quote
Old 03-18-2008, 10:01 AM   #66
PERRIN
NASIOC Manufacturer
Member#: 6776
Very little. The biggest change you might notice is on expansion joints in the road. Others in this thread may be able to better relay their experiences now that they have the system installed.
Thanks for asking!
Adam.taft@perrinperformance.com
Old 03-18-2008, 01:25 PM   #67
Furious George
Member#: 109742
MBP
I have only been on it a few days, but what I can say is that overall NVH is minimal. However, if you hit a pothole or something else in the road with the rear wheel, the sound transmission is much greater than stock.
Old 04-06-2008, 04:04 PM   #68
pdxsilverwrx
Member#: 54935
Just installed this kit. Only kind of hard part was aligning the bolt holes after installing the bushings on the differential stabilizer. Overall not a hard install at all.
pdxsilverwrx is offline   Reply With Quote
Old 04-06-2008, 04:19 PM   #69
nicholam
Member#: 133936
2005 WRX Wagon
Stage 4 Silver
I installled this kit on my 05 wagon last spring and I love it. The install was easy with jack stands and hand tools. The car immediatly felt much more solid. You really feel the acceleration and it's much easier to be very precise with steering, braking, and acceleration. I highly recomend it. The NVH isn't that noticeable and it's kind of nice to hear the car.
nicholam is offline   Reply With Quote
Old 04-06-2008, 05:47 PM   #70
PERRIN
NASIOC Manufacturer
Member#: 6776
Thank you for the honest feedback. That is what can make NASIOC GREAT!
Old 04-06-2008, 05:48 PM   #71
PERRIN
NASIOC Manufacturer
Member#: 6776
KOOL! Thanks for the business!
Old 05-03-2008, 12:51 PM   #72
PERRIN_Ken
Member#: 165212
Blaze Yellow
Here is a little help for you weekend warriors
Ken
Ken Jubb
Sales
PERRIN Performance
503-693-1702 Ex.113
ken.jubb@perrinperformance.com
PERRIN_Ken is offline   Reply With Quote
Old 05-03-2008, 01:40 PM   #73
TheNewThatGuy
Member#: 148041
2000 Rally Impreza
Blue and Gold, baby
I really like the idea of this kit... I drive an '00 RS, but I drive it hard as hell and beat it into the ground off road....sometimes litterly, that's why I keep a winch.... So after 150K, it's easy to understand why I get those jolts not just in first and second, but also third... I've always known there to be alot of unwanted slop in the driveline, but I also know there's alot of rust....So I guess I'm just skeptical about doing this mod, because my rear end is held together by frozen bolts.
Uh, I guess my two questions are, after seeing this thread just now, is that sale still active, and also....You guys have any suggestion for if I break/ and forced to destroy bolts? Like, can you guys at least supply me with some dimensions so I can run by the hardware store and get new ones?
TheNewThatGuy is offline   Reply With Quote
Old 05-04-2008, 01:01 AM   #74
PERRIN_Ken
Member#: 165212
Blaze Yellow
IM sent
Have a good night
Ken
Ken Jubb
Sales
PERRIN Performance
503-693-1702 Ex.113
Old 05-24-2008, 05:02 AM   #75
socrates42
Member#: 7747
2004 WRX 5door 5spd
08 E90 M3
nice writeup
socrates42 is offline   Reply With Quote
Perrin Subframe Lockdown System (SLS) on 2010 WRX Sedan Blue_Rex Car Part Reviews 5 04-12-2010 11:02 PM
DIY Perrin Rear Differential Cover Installation PERRIN_Ken Transmission (AT/MT) & Driveline 73 09-24-2009 01:10 PM
Rear diff bushings/ lockdown systems opinions? mostasz Newbies & FAQs 14 09-20-2008 09:01 PM
Perrin Rear Differential Subframe Lockdown 06blacksti Transmission (AT/MT) & Driveline 6 01-19-2007 04:46 PM
