Old 12-15-2007, 06:54 PM   #1
mattmx525
Member#: 118525
2002 wrx. stg 4+
blue
Default 1st and Reverse hard to engage
so when i shift into 1st and reverse sometimes i need to use two hands to pull it into reverse. any idea whats going on with my car?????????
mattmx525 is offline   Reply With Quote
Old 12-15-2007, 07:19 PM   #2
nevets87@siu.edu
Member#: 151119
if your put in your clutch and try to engage reverse and it is hard to do, release the clutch pedal and then repress it and try again.
nevets87@siu.edu is offline   Reply With Quote
Old 12-15-2007, 09:27 PM   #3
iyzmi
Member#: 150004
2002 18g WRX
WRB 310hp/285tq
You should never force the shifter into any gear. If you have to use two hands to shift then that should ring a bell in your head that something isn't right and maybe you should stop before you hurt your synchros or worse. The trick is to either let go of the clutch then push it in again or shift into a few other gears and try 1st or reverse again. If you're moving and want to go into 1st at like 5mph, the trick is to give it some gas.
iyzmi is offline   Reply With Quote
help 1st gear sticking/hard to engage as well Rod702 Transmission (AT/MT) & Driveline 26 01-10-2010 03:35 PM
Gears Grind when shifting to 1st and Reverse fast eylopez Newbies & FAQs 7 06-25-2008 10:15 AM
Reverse gear hard to engage. C-grunt South West Impreza Club Forum -- SWIC 21 10-05-2007 11:42 AM
Hard to Engage 1st and Reverse rich728 Transmission (AT/MT) & Driveline 11 04-01-2006 12:16 PM
Re: 2nd to 1st and Reverse Sticky shift w/ ST SHift Jing Transmission (AT/MT) & Driveline 0 01-18-2002 03:19 AM
