Old 12-16-2007, 03:56 PM   #1
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Default The STi Strut FAQ
This is meant to be a fairly short FAQ devoted to all the wacky quirks of the STi struts in all their forms.
I have some red struts in front of me. Which ones do I have?
The paint codes on the spring should help identify them.
http://forums.nasioc.com/forums/show...ruts+dots+spec
I want to put STi struts on my car. Will they fit?
Check out the "Will this suspension part fit my car?" thread:
http://forums.nasioc.com/forums/show....php?t=1303381
Short version: The 05+ STi's have different hubs, and the mounting points on the front struts are different. 05-07 front STi struts won't fit any other car (the rears did not change) because when the 2005 STi got the new 5x114.3 hubs the bolt locations changed. The rest of the details are covered in the thread including what you have to do to make 02-03 stuff fit 04+ stuff and vice versa.
My STi struts are making a clunking noise. I think it's in the rear. What gives?
There are many threads about the STi strut clunk. This is the most famous:
http://forums.nasioc.com/forums/show...ighlight=strut
Is the clunk of doom dangerous? Will it affect my car's handling?
There is no definite answer. The strut may be sticking, which may be affecting the car's performance. (This link is okay, but I'm always looking for a better one.)
http://forums.nasioc.com/forums/show...clunk+stiction
What can I do to fix the clunk?
Greasing them can help make the symptoms go away. This thread discusses it:
http://forums.nasioc.com/forums/show....php?t=1362104
So does this one:
http://forums.nasioc.com/forums/show....php?t=1415706
What springs should I put on my STi struts?
Start here:
http://forums.nasioc.com/forums/show....php?t=1383366
It discusses a lot of the issues related to the STi struts and MacPherson struts in general. The short version is - a lot of the lowering springs out there are too low.
How stiff a spring can I put on the STi struts?
*waiting for a better answer to this question
I know someone local who ran 325/300 lb/in Ground Controls on his STi and liked it as an autox setup. I'm not sure what the upper limit is but it's probably something in that range.
Can I put Koni WRX inserts in my 2004 STi struts?
Maybe (see below) but your best bet is to just pick up some WRX housings since they will definitely fit, and those housings will definitely fit your car.
Can I put Koni WRX inserts in my 2005-2007 STi struts?
Mojambo and jamesohoh7 hav experimented with this. The short answer is "probably but there's some work involved":
http://forums.nasioc.com/forums/show....php?t=1276865
More here:
http://www.iwsti.com/forums/suspensi...t-housing.html
Old 12-16-2007, 03:56 PM   #2
Butt Dyno
Member#: 17301
is the "dark side"
expansion 1. Feedback appreciated, this isn't remotely comprehensive
Old 12-16-2007, 03:56 PM   #3
Butt Dyno
Member#: 17301
is the "dark side"
expansion 2
Old 12-16-2007, 04:30 PM   #4
jamal
Member#: 71875
98 Legacy GT
my wheels fit
Wow someone's bored today. And why do we even need this you should just get coilovers.
kidding. Anyway, might not be a bad idea to just say flat out that 05-07 STi struts do not fit any other car.
jamal is offline   Reply With Quote
Old 12-29-2007, 01:13 PM   #5
Butt Dyno
Member#: 17301
is the "dark side"
Old 12-29-2007, 07:57 PM   #6
BIGSKYWRX
Member#: 7958
09 GH B+
I like the "how to make the STi strut work w/ Koni insert thread"- particularly handy for 05+ guys that can't use WRX strut housings
Old 12-29-2007, 08:04 PM   #7
Butt Dyno
Member#: 17301
is the "dark side"
Good suggestion - added
Old 01-07-2008, 01:36 PM   #8
Robbie_B
Member#: 137728
93 MR2T 87 924S
Teal and Black
Also, you should clarify that only the fronts aren't compatible from 05-07. The rears didn't change.
Robbie_B is offline   Reply With Quote
Old 01-07-2008, 02:54 PM   #9
BIGSKYWRX
Member#: 7958
09 GH B+
^ and include your talking STi to WRX
Old 01-08-2008, 04:17 PM   #10
Butt Dyno
Member#: 17301
is the "dark side"
Edited first post. Does that look okay?
Old 01-08-2008, 11:04 PM   #11
BIGSKYWRX
Member#: 7958
09 GH B+
looks good, maybe a short discussion on inverted vs non-inverted, not many cars come w/ inverted struts
Old 01-08-2008, 11:46 PM   #12
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
still confused dyno! im looking into possible v7's on my 2002 wagon
jdubya301 is offline   Reply With Quote
Old 01-09-2008, 08:28 AM   #13
jamesohoh7
Member#: 39070
GTF off my lawn!
That's largely a bolt on, but you'll need to do something to help correct the front camber since sedan struts on a wagon == camber challenged. The usual, cheap solution is... an extra camber bolt (Whiteline makes some) in the lower clevis bolt hole on each front strut. Camber plates are probably a better, but more pricey solution. A friend of mine did both when he had a V7 STi strut setup on his wagon.
jamesohoh7 is offline   Reply With Quote
Old 02-06-2008, 10:40 AM   #14
Imprezive_04
Member#: 104591
02 Zed06
08 Evo X
Fantastic thread as are all of these suspension threads.
This is a question that could use a lot of focus for those on a budget. I bought Pete's set up you mentioned above and will use it on my 04 STi this season along with the GC camber/caster plates. I'm sure we'll cross paths at some point since I like to hit the Frederick CDC events and Cumberland events. So I'll work on a second opinion. Pete seemed very pleased, but then again he had to sell them
Imprezive_04 is offline   Reply With Quote
Old 02-06-2008, 10:59 AM   #15
Butt Dyno
Member#: 17301
is the "dark side"
I think that Tom Hoppe spec'd em originally, so it must have been based on data. He's pretty good at that sorta thing
Old 03-31-2008, 11:07 AM   #16
hoffmanEstates
Member#: 122043
04 wagonier
psm
but with work they might tom at kartboy has quoted on this section
hoffmanEstates is offline   Reply With Quote
Old 01-16-2009, 01:55 PM   #17
1stockwrx
Member#: 162365
06 RSX Type S
can you use stock wrx top hats with sti struts?
1stockwrx is offline   Reply With Quote
Old 01-16-2009, 03:07 PM   #18
BIGSKYWRX
Member#: 7958
09 GH B+
stock WRX tops (front and rear) = stock STi tops from 04-07- same part #'s
Old 01-16-2009, 03:17 PM   #19
1stockwrx
Member#: 162365
06 RSX Type S
thanks!
Old 12-31-2009, 10:43 AM   #20
Butt Dyno
Member#: 17301
is the "dark side"
So, anything here that we should add for the 08-09 cars? Anyone have a good link about the new suspension (and how little travel it has) to include here?
Old 12-31-2009, 02:38 PM   #21
BIGSKYWRX
Member#: 7958
09 GH B+
the front has almost identical travel (still strut based) to previous gens, the rear does have less (shock based w/ the double wishbone)
iwsti had a thread that went into some detail on the rear configuration
Old 09-18-2010, 11:14 PM   #22
dougfeature
Member#: 196971
has anyone written/figured out the 1 inch mystery drop?
dougfeature is offline   Reply With Quote
Old 06-23-2011, 01:21 PM   #23
Skibum101
Member#: 265502
2008 5 Door WRX
Rally Blue
anyone know if its possible to swap 09-10 STI struts into a 08 WRX. Im looking for a stiffer lower ride.
Skibum101 is offline   Reply With Quote
Old 06-23-2011, 03:13 PM   #24
BIGSKYWRX
Member#: 7958
09 GH B+
not possible (not w/o a lot of complex machining anyways ) ever since the STi (in 05) went to the thicker knuckle the front struts have been a no go for WRX guys
the rear shocks MAY possibly fit, but I don't what that would gain you- and not even certain if they will
I'd say Bilstein or Koni are going to be your best bet, don't bother w/ the 09-11 WRX struts/shocks- they are only mildly firmer than the 08 ones
Old 01-09-2012, 11:33 PM   #25
scratchgolfer
Member#: 305998
Default Bottom STi Strut Mount Thickness??
Hi everyone, I have an 06 STi and am having some [COLOR=blue !important][FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif][COLOR=blue !important][FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]coilover[/font][/font][/color][/color] fitment issues. The bottom [COLOR=blue !important][FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif][COLOR=blue !important][FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]strut[/font][/font][/color][/color] mount on my STi is 1 7/16" wide and the stock strut is 1 1/2" so stock fits perfect, however on the coilovers the opening is only 1 1/8" wide therefor the strut wont fit onto the bottom mount....do I have the wrong coilovers or has my suspension been changed? what is the factory width on your guys stock struts bottom mount? im confused haha
Thanks
scratchgolfer is offline   Reply With Quote
Anyone worried about how the STi struts/springs handle the rough stuff, neednt... gtguy Brakes, Steering & Suspension 6 11-18-2002 11:53 AM
How do you tell the difference between the Sti Strut tops I drive a WRX wagon Brakes, Steering & Suspension 3 08-15-2002 02:31 AM
how do i assemble the STI struts/springs? nhluhr Brakes, Steering & Suspension 1 06-12-2002 06:37 PM
Anyone try the Sti struts with stock springs? DRE1 Brakes, Steering & Suspension 6 04-29-2002 10:43 AM
Chad - How are the STi struts / springs?? webkris New England Impreza Club Forum -- NESIC 0 05-03-2001 06:26 AM
