Old 12-16-2007, 04:40 PM   #1
AardvarkWRX
Member#: 163620
2008 Impreza WRX
World Ralley Blue
Default Is the auto climate control lowest setting of 65 degrees F too hot for you?
My 08 WRX is the first car I have ever own with an automatically controlled climate control. For the last 6 weeks of ownership the climate control has been an annoyance that distracts my attention from the road.
It works perfectly well, when I set it to 65 deg F it keeps the cockpit near that temperature. However, I'm too warm-blooded for 65 deg F. In the winter I am wearing clothing that keeps me warm, I can't just remove my clothing when I get in the car, that would be frowned upon. With all my previous cars, I just set the temperature manually to give just enough heat that I am comfortable. I also like to keep new air circulating in the cockpit, so turning off the air flow is not an acceptable choice for me.
I want to hack this car so that the automatic temperature control dial (knob) range of 65-85 deg C is modified to have a wider range of perhaps 55-85 deg C.
I have a suspicion that the climate control is all computer controlled. There is going to be a micro-processor somewhere. Can anyone tell me where this processor is, and if there has been any work done by other members to this processor? I thought it would be prudent to ask this forum before I start ripping apart my new car.
I have a backup plan if the processor can't be modified. Plan B is to modify the temperature sensor itself so that it reads 10 deg F higher than normal. Depending on what kind of sensor subaru is using, this may be a very easy modification (adding a resistor in series) or slightly more difficult. Does anyone know what kind of sensor is used?
AardvarkWRX is offline   Reply With Quote
Old 12-16-2007, 05:26 PM   #2
GripGC8
Member#: 110653
87 FC3S
cant you just crack the damn window for a little while?
GripGC8 is offline   Reply With Quote
Old 12-16-2007, 05:52 PM   #3
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
LOL!! Seriously I couldnt agree with you more. All that trouble because the guy is thermostatically challenged.
Samirr76 is offline   Reply With Quote
Old 12-16-2007, 06:09 PM   #4
GripGC8
Member#: 110653
87 FC3S
it seems more and more people are crying about stupid **** these days. whatever happend to common sense?
"WAA..my 2008 wrx is to warm for me..WAA"
grow a pair and crack the window, there is no need for this thread.
Old 12-16-2007, 06:33 PM   #5
fasteddie888
Member#: 161359
2008 WRX
Gray
yep it's true at 65 it is a little warmer than I expected. I just turn it off. If you put the AC on however it blows pretty cold.
fasteddie888 is offline   Reply With Quote
Old 12-16-2007, 06:36 PM   #6
bluwrx27
Member#: 107312
06 STI
no matter how much u mess with ur controls, or micro-processor the coldest it will ever get is 30 degrees below exterior temp..
bluwrx27 is offline   Reply With Quote
Old 12-16-2007, 06:51 PM   #7
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
oh my.......
v8eaterWRX is offline   Reply With Quote
Old 12-16-2007, 07:32 PM   #8
Winner
Member#: 106050
- pm Josey Wales
very true.....
Winner is offline   Reply With Quote
Old 12-16-2007, 08:36 PM   #9
GeoTracker
Member#: 146042
2005 STi
Here's an idea. Take off your jacket.
GeoTracker is offline   Reply With Quote
Old 12-16-2007, 10:29 PM   #10
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
Never mind...
Old 12-17-2007, 02:14 AM   #11
Uncle Buck
Member#: 140062
2005 STI ATP3076r
95' Eclipse gs
i can just picture you driving down the road sweating puddles and not even thinking about turning the heat off for a few minutes.
Uncle Buck is offline   Reply With Quote
Old 12-17-2007, 02:52 AM   #12
Dforce
Member#: 93435
2008 STi DGM
+1 Berk Technology!
Take off your pants and jacket.
Dforce is offline   Reply With Quote
Old 12-17-2007, 03:18 AM   #13
Uncle Buck
Member#: 140062
2005 STI ATP3076r
95' Eclipse gs
haha, i was totally going to say that instead of the post i had, you win
Old 12-17-2007, 07:15 AM   #14
jace2k5
Member#: 107964
2004 WRX Wagon
Platinum Silver Metallic
how about we trade? you can have my frigid 2004 wrx wagon..
i'll take the new 08
jace2k5 is offline   Reply With Quote
Old 12-17-2007, 02:02 PM   #15
demo24
Member#: 87170
2005 WRX Wagon
Grey
umm, just take it off auto. It's not the best system in the world. You can manually adjust the fan speed, where it exits, and the heat. No different than any other system
demo24 is offline   Reply With Quote
Old 12-17-2007, 02:07 PM   #16
WRXLTD
Member#: 136314
2014 Grand Cherokee
You don't have too much time on your hands...do you...
WRXLTD is offline   Reply With Quote
Old 12-17-2007, 02:18 PM   #17
Okeyd57
Member#: 113271
2006 STi
Obsidian Black Pearl
Push in on the third hvac button. It says A/C. It will get as cold, or hot, as you like !
Okeyd57 is offline   Reply With Quote
Old 12-17-2007, 02:53 PM   #18
dodgerfreak714
Member#: 130340
man i would like to the OP's facial expression when he sees these responses
dodgerfreak714 is offline   Reply With Quote
Old 12-17-2007, 03:01 PM   #19
Jeff54
Member#: 129503
2002 It's resting
6 > 4?
wow way to tear the guy a new one cause he asked if theres a way to mod his climate control
heaven forbid if a question was actually answered or led to some discussion which was actually helpful to someone....
anyway....on subject:
i really doubt you'll be able to modify(reprogram) the processor....your best bet would probably be to modify the sensor like you said. most likely it's just a thermistor....im not sure exactly where the sensor would be in your car....usually it's located near the control panel on the dash....underneath a little vent in the plastic...
Jeff54 is offline   Reply With Quote
Old 12-17-2007, 05:57 PM   #20
AardvarkWRX
Member#: 163620
2008 Impreza WRX
World Ralley Blue
Hey you're the first guy to add anything useful on this thread. The previous 17 people found satisfaction in adding nothing but still taking up bandwidth.
You're correct, the sensor is behind some slots near my right knee when i sit in the drivers seat. I'm hoping that with this post someone might know the sensor type. if not i'll just have to do the investigation.
And to answer all those idiotic responses: Who wants to open windows or turn the temperature control to full cold, then revert back to heat, perhaps every 5 minutes? This is annoying on a long drive. An old fashioned non-auto climate control would have worked very well in this car for me.
Old 12-17-2007, 08:42 PM   #21
incubusjunkie614
Member#: 125296
05 2.5rs
silver/black
you could add a resistor in line with the sensor wiring, but depending on the output of the sensor, i.e. {if the temp goes up the resistance goes down (NTC) or if the temp goes up and the resistance goes up (PTC)} that would work fine if you knew that, but you could go the other way and effectively raise your operating range.
2. another way to fix your problem would be to fool/cheat the exterior temp. sensor. and make the processor think that its colder/ hotter outside then it really is, it will compensate more with the auto setting. this would be easy to do, just measure the resistance at a few different temps. then just replace the sensor with a specific resistor and you have fooled the computer. BUT your exterior temp sensor read out will show all kinds of weird readings
thats all i can think of real quick. i'll do a lil research and see what i come up with!!
incubusjunkie614 is offline   Reply With Quote
Old 12-18-2007, 12:37 AM   #22
the_crazy_canadian
Member#: 165356
2008 Impreza WRX
Gunmetal ? (deep grey)
im not on here to tear a guy up but it does seem like alot of work when it has a manual option aswell
the_crazy_canadian is offline   Reply With Quote
Old 12-18-2007, 12:45 AM   #23
SubeN'Siren
Member#: 151171
02 Subaru WRX
Disagree...though climate control is nice, it is no good if it doesn't control it to what you want.
If I bought a brand new car, and the AC/heat didn't work, I'd be sorely pissed.
SubeN'Siren is offline   Reply With Quote
Anyway to disable the Auto climate control in 2010 WRX? jay25RS Interior & Exterior Modification 7 02-23-2010 09:39 AM
2008 Impreza - Is it possible to buy some parts to get auto climate control? hotweiss Interior & Exterior Modification 6 08-15-2009 01:43 PM
auto climate control heater core, blower motor and controls fourage20 Interior/Dressup/Audio & Security 3 06-02-2009 10:40 AM
04/05 HVAC controls with Auto Climate COntrol murderedoutrex Interior/Dressup/Audio & Security 1 06-17-2008 02:44 AM
