Old 12-18-2007, 01:34 AM   #1
silentt
Member#: 119995
2004 Outback XT
Peachy
Default 05RS ECU in an 99-01RS?
Hey guys,
What would it take to have an '05RS ECU work in an older RS? Is it possible with minor mods, if possible at all?
I'm intrigued since I would love to do some open source tuning as opposed to spending retarded amounts on standalones.
silentt is offline   Reply With Quote
Old 12-18-2007, 03:33 AM   #2
kaos200
Member#: 2692
but you're a 99 RS-T
Why go RS ecu?
Why not do a WRX/STi ecu (non drive by wire for ease of transition if you wish, although it's not much more work) and have a turbo-ready ecu/sensors etc off the bat?
edit: doh! I just remembered about the heads...
Yah I suppose that would be an issue but you can find cheap WRX heads off a parted motor for pretty cheap!
kaos200 is offline   Reply With Quote
Old 12-18-2007, 03:37 AM   #3
silentt
Member#: 119995
2004 Outback XT
Peachy
Why go RS ecu?
I'm not pulling my motor again, tearing it down, rebuilding a new one, and doing an engine swap just to use a WRX ECU.
I'm what you call a stage 4 turbocharged vehicle using a hybrid motor. I want the 05 ECU so I can datalog and do open source tuning, since there is a local guy who's an OS guru.
Old 12-18-2007, 08:40 PM   #4
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Im sure a wiring/swearing nightmare this could be. I guess you could take a look at both ecu wiring diagrams and use that to influence your decision.
~Josh~
Old 12-18-2007, 09:36 PM   #5
Qman
Member#: 964
'95 work in
progress
Itr is definitely a rewire or cut and splice. Some benefits can be had from this. But, I am not convinced it is worth the amount of work it would take.
Qman is offline   Reply With Quote
Anyone use an '04 STI ECU in an '05 STI??? JDM-STI Engine Management & Tuning 16 07-16-2006 10:56 PM
STI ECU in an 06 WRX Tokudai Engine Management & Tuning 4 06-27-2006 08:49 AM
02 ECU in an 04 Jeramie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 07-13-2005 02:14 PM
02 ECU in an 04 will it work? CMJ Engine Management & Tuning 0 09-05-2003 02:09 PM
ECU in an accident, Safe to plug in? Tomnel Engine Management & Tuning 5 04-06-2003 12:31 PM
