Old 02-28-2008, 07:04 PM   #76
10-56
Member#: 144436
2007 WRX GRP
1995 Justy GL AWD
Why isn't this sticky??
10-56 is offline   Reply With Quote
Old 03-05-2008, 09:37 PM   #77
RallyIt07
Member#: 158498
07 WRX w/ JDM 6spd
Yup got that on Vista. It doens't work on vista even when you do run as xp SP2. I just put it on an old crap computer and it worked just fine.
Originally Posted by TurmultTee View Post
When I try to install Enginuity there is an error
"java.io.FileNotFoundException: C;\Program Files\lib\j3dcore-ogl.dll (access is denied)"
Anyone else get this error. It seems like it's trying to read a file that dosen't exist?
RallyIt07 is offline   Reply With Quote
Old 03-05-2008, 09:40 PM   #78
Tea cups
Member#: 103136
The answer to this exact question is in the FAQ in this thread.
Tea cups is offline   Reply With Quote
Old 03-26-2008, 12:25 PM   #79
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
Yay for the sticky!
Noah is offline   Reply With Quote
Old 03-26-2008, 09:38 PM   #80
jr4jc
Member#: 76834
2005 STI
crystal metalic gray
ok i got an open source tune and we turned off the appropriate things to prevent CEL's
but i had one anyway, went to autozone and they checked it, it read NO Codes.
'pass' i think is what it actually read. the girl then clicked clear all codes and the CEL went away for a couple of days, now it's back on and autozone says nothing is showing up.
i am cat-less DP but i have my rear O2 sensor pulled.
can anybody help!!!
jr4jc is offline   Reply With Quote
Old 04-11-2008, 06:31 PM   #81
ReX-7
Member#: 163990
2003 WRX
I'm getting this error as well on Vista. Any suggestions?
Edit: Nevermind, I can read. :P
ReX-7 is offline   Reply With Quote
Old 05-20-2008, 02:59 AM   #82
fusionchicken
Member#: 123777
http://www.romraider.com/RomRaider/Download
clicked on download for Windows and says page not found
i need to log my car
fusionchicken is offline   Reply With Quote
Old 05-20-2008, 06:48 AM   #83
Jon [in CT]
Member#: 2992
02 WRX Sedan
It works for me.
Jon [in CT] is offline   Reply With Quote
Old 05-20-2008, 09:20 AM   #84
Rogan
Member#: 142133
3 Jeeps
And a Saab
worked for me too..
Rogan is offline   Reply With Quote
Old 05-21-2008, 06:36 AM   #85
fusionchicken
Member#: 123777
weird it works now my comp failed me yesterday
Old 06-06-2008, 09:00 AM   #86
Redthorne
Member#: 103593
2006 WRX Wagon Ltd
Steel Grey Metallic
Originally Posted by Tea cups View Post
OpenPort for Subaru Drive-by-wire vehicles -> Purchase this cable if you wish to read/flash only the 32-bit ECU (you would still be able to log the 16-bit ECU, however). You can also purchase the flash jumpers separately for the 16-bit ECU later if you wish.
Just to double check...if I am reading this statement correctly. If I purchase the above cable I will be able to log both my 06 WRX & my friend's 05 OutbackXT? We are not interested in flashing (nor will we ever be), just an occasional log for diagnostic purposes. (just to see if anything funny is happening)
Plus we are both electronic junkies and want to see what's going on when driving
Redthorne is offline   Reply With Quote
Old 06-06-2008, 09:18 AM   #87
Tea cups
Member#: 103136
The cable for Subarus is the same cable in both packages - it is just that the 16-bit ECU requires the separate jumper for flashing and that is included in that "package". Both vehicles you mention use the 32-bit ECU, so you only need the cable itself which is listed as the DBW package (and you'll be able to flash if you later decide to do so).
Old 07-07-2008, 02:54 PM   #88
thereplacement
Member#: 183624
I bought a v2 AP a while ago off ebay and the guy included a ACCESSECU cable hooked up to a usb, he said he got it for datalogging - has anyone used one of these?, just wondering if it will work for data-logging with romraider (I have the AP to reflash) or if there is going to be a trick to using this vs the tactrix cable.
Also, do I still need ECUflash if I only want to datalog? I'm assuming I don't need to know what the current map is, though I wasn't sure if it was needed for some reason in order to get the live values.
thereplacement is offline   Reply With Quote
Old 07-25-2008, 12:03 AM   #89
srREXed
Member#: 72234
2004 WRX SRR
EJ257-35R-6MT
I dont know if this has been discussed, but are you able to use a cable from a v1 cobb accessport for the use of open ecu tuning instead of a tactrix cable?
srREXed is offline   Reply With Quote
Old 07-25-2008, 08:04 AM   #90
Rogan
Member#: 142133
3 Jeeps
And a Saab
nope.
Old 07-25-2008, 08:24 AM   #91
srREXed
Member#: 72234
2004 WRX SRR
EJ257-35R-6MT
Originally Posted by Rogan View Post
nope.
Thank you.
Old 07-30-2008, 02:39 AM   #92
SubyWill
Member#: 166830
2003 WRX
sorry noob here....... so i want to load an xpt stg 2 map, i bought the tactrix cable and im downloading the map, what exactly do i have to do now? im confused? lol, and should i buy a gm bcs?
SubyWill is offline   Reply With Quote
Old 07-30-2008, 08:32 AM   #93
Tea cups
Member#: 103136
As a customer, you can get support for your XPT map here:
www.xpttuning.com
Old 07-30-2008, 10:15 AM   #94
SVT_WRX
Member#: 164830
G61 III OVE 58e
You will be much happier with the GMBCS and the XPT stage 2 map for it. I tried them both.
With the GMBCS map boost comes on quicker, stronger and smoother than with the non-gmbcs XPT stage 2 map.
SVT_WRX is offline   Reply With Quote
Old 07-30-2008, 10:15 AM   #95
srREXed
Member#: 72234
2004 WRX SRR
EJ257-35R-6MT
nope.
Thanks. I dont want to give incorrect advice. I sold my acceport to somebody in AL and they wanted to use the cable for open programming. I havent ever tried it as I have had the tactrix for quite a while...
Old 07-30-2008, 12:13 PM   #96
SubyWill
Member#: 166830
2003 WRX
alright thanks guys, i was just wondering about the whole logging thing
Old 08-08-2008, 10:21 AM   #97
phoenix_wrx
Member#: 98532
na B-Wing
rebel red
"OpenPort for Subaru Drive-by-wire vehicles -> Purchase this cable if you wish to read/flash only the 32-bit ECU (you would still be able to log the 16-bit ECU, however). You can also purchase the flash jumpers separately for the 16-bit ECU later if you wish."
I may be a little thick here, but perhaps someone can help. I want to log, and had tried to use the APv2 cable and all the associated software from cobb and tari, but have had no luck even connecting to the ecu.
I really want to log, and when i looked at this sticky, and tried to find which tactrix cable to buy, i just get "product not found" from the link above on the tactrix site.
Can someone point me to a tactrix cable for my 06 wrx?
phoenix_wrx is offline   Reply With Quote
Old 08-08-2008, 10:29 AM   #98
Kjott21
Member#: 116937
2011 WRX DGM
forums.pghsubarus.com
Looks like the old version of the cable is gone now. The new one is here:
http://www.tactrix.com/product_info....products_id=40
Kjott21 is offline   Reply With Quote
Old 08-08-2008, 10:35 AM   #99
phoenix_wrx
Member#: 98532
na B-Wing
rebel red
Crap. I was under the impression it was $75. This changes things. that $200 was earmarked for a sway bar.
Guess I am going to try harder to log with the APv2 for now, unless i can find a used one.
Old 08-08-2008, 12:52 PM   #100
bp_968
Member#: 186439
2003 WRB WRX Wagon
2008 Infiniti G35x
couple of questions I didn't see covered:
1> can this be used with the generic "ELM 327" units you see on ebay all the time (I have one I used for my other cars before I got my 06 STi this week).
2> can it be used in *READ ONLY* mode (I have ZERO desire to tune yet. I want nothing to do with messing with the ECU right now. I only want the data!)
Thanks!
bp_968 is offline   Reply With Quote
romraider/ecuflash? weaponstroop Open Source Reflashes 8 10-21-2008 10:04 AM
reading logs - FAQ or getting started guide? jmc9809 Newbies & FAQs 2 08-05-2005 06:40 PM
I want to get started racing! Where to start? wayne_rx Motorsports 27 12-23-2004 03:00 AM
Auto-Xing Newbe, How to get started? Ed_RS New England Impreza Club Forum -- NESIC 7 01-31-2001 11:34 AM
how to get started jjp New England Impreza Club Forum -- NESIC 5 11-09-2000 06:26 AM
