Old 01-14-2009, 07:25 PM   #126
Troganin
Member#: 115770
2007 2.5i Wagon
you have to click on what table you want to look at on the left side. then something will appear in the black.
Troganin is offline   Reply With Quote
Old 02-13-2009, 11:25 PM   #127
justboosted02
Member#: 78285
2003 EVO
red and black
what happened to the turboxs wideband support?
its not in the new version of romraider and i NEEDZ it
justboosted02 is offline   Reply With Quote
Old 02-21-2009, 12:16 PM   #128
enXiks
Member#: 69363
2004 WRX
Where are you guys getting your Stage 1 roms from?
for 04 WRX?
enXiks is offline   Reply With Quote
Old 02-27-2009, 10:24 AM   #129
Tgui
Member#: 44771
It was alpha quality in that it used features from another program I wrote a long time ago. Kascade tore it out when pulling out dead-ish code.
Tgui is offline   Reply With Quote
Old 02-27-2009, 03:25 PM   #130
mr.four
Member#: 148479
When flashing a map onto the ECU I...
-Opened EcuFlash
-Connected my cable
-Connected the Green Connectors
-Connected the Init connector
-Opened the map I was going to flash
-Clicked Write to ECU
-Turned Key to "ON"
-Clicked Okay
-Done...
-Disconnected the Green Connectors
-Disconnected the Init connector
Did I miss something or do something wrong here...?
mr.four is offline   Reply With Quote
Old 03-14-2009, 02:04 PM   #131
ezramoore
Member#: 159597
2003 Impreza WRX
Sonic Yellow
Just a HUGE heads up as I see this WAY too often: YOU NEED AN OFFSITE BACKUP OF YOUR STOCK MAP.
So email it to yourself if you have a webmail account...
ezramoore is offline   Reply With Quote
Old 04-02-2009, 01:54 PM   #132
sburck
Member#: 191491
2011 Forester
Thanks for the guide, I was wondering though what exactly is a test write and how do you do one?
sburck is offline   Reply With Quote
Old 04-02-2009, 03:34 PM   #133
Tea cups
Member#: 103136
A test write in Ecuflash is one of the selections includiing the usual read and write. It basically does everything in the flashing process except the actual flash, allowing you to discover problems beforehand.
Tea cups is offline   Reply With Quote
Old 04-08-2009, 10:55 AM   #134
Irishman
Member#: 29933
2004 STI
Silver/Silver
My biggest fear is that it will erase or mess up and I will lose my protune when I get my ECU information. Has this ever happened? I only want to log.
Irishman is offline   Reply With Quote
Old 04-08-2009, 11:04 AM   #135
Tea cups
Member#: 103136
Logging has no risk whatsoever and will not change your tune.
Old 04-08-2009, 11:33 AM   #136
Irishman
Member#: 29933
2004 STI
Silver/Silver
Thanks for the quick reply. I am hoping to find my cable and contribute to the road dyno thread.
Old 04-24-2009, 12:02 PM   #137
ryrules1
Member#: 202574
Car: saab 92x linear
Engine: EJ253
I recently bought a tactrix cable and I started logging for using Romraider, driving around. I then desided to try and pull the ROM from the ECU, I put the car in test mode. (green connector). Then I opened ECUFlash, and yes I have the ECU defs installed. Then I hit read rom, and go this error message no madder which DBW setting I used.
[11:26:07.746] Using interface OpenPort 1.3 Universal TX45rBqS9d1ab7c956c5f7aae78bab98f7276a5dc3826586
[11:26:08.557] kernel get version
[11:26:08.938] SSM2 init
[11:26:09.088] SSM2 ECU ID is 3E 12 08 41 06
[11:26:09.188] Requesting Seed...
[11:26:09.238] Sending Key...
[11:26:09.879] interface close
any ideas?
ryrules1 is offline   Reply With Quote
Old 04-29-2009, 05:02 AM   #138
darkcrave
Member#: 204753
2002 wrx
just one question, can i use the cable that came with my cobb AP and connect it to my computer to run romraider?
darkcrave is offline   Reply With Quote
Old 04-29-2009, 08:45 AM   #139
Tea cups
Member#: 103136
If it is Accessport ver 1 cable, then you can log with RomRaider if you get a serial to USB converter (Belkin is a good one). However, that is it. You will not be able to flash your ECU (i.e. tune). AP ver 2 cable, you will not be able to log at all with RomRaider.
Old 05-05-2009, 03:59 PM   #140
svxpert
Member#: 11317
does anyone know how i can tell what tactrix cable i have? i searched but no results. i had originally bought one for a 2004 STi but after a year i have just located it in my garage. there is no stickers on it indicating what version it is so it could be 1.2 to a 2.0? thanks
svxpert is offline   Reply With Quote
Old 05-05-2009, 04:29 PM   #141
Tea cups
Member#: 103136
If it is a year old, it won't be the 2.0. It will show your cable's version in Ecuflash.
Old 05-05-2009, 05:18 PM   #142
svxpert
Member#: 11317
so you mean the 2.0 just came out in the last year?
Old 05-05-2009, 05:35 PM   #143
Tea cups
Member#: 103136
Yes, not to mention it looks different than the previous cables. It has a detachable cable and a translucent cover with led lights.
Old 05-15-2009, 08:16 PM   #144
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
I am a newbie, and Ive read as much as I can find out including this entire thread. I get this error:
[20:11:47.515] J2534 error [device not responding].
[20:11:47.515] unable to connect to vehicle interface.
[20:11:47.515] interface close
[20:13:56.812] J2534 error [device not responding].
[20:13:56.812] unable to connect to vehicle interface.
[20:13:56.812] interface close
[20:14:10.187] J2534 error [device not responding].
[20:14:10.187] unable to connect to vehicle interface.
[20:14:10.187] interface close
How do I know what com port to use?
Dubstar112 is offline   Reply With Quote
Old 05-15-2009, 09:19 PM   #145
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
woot got it. Just had to restart my laptop.
Old 06-23-2009, 01:53 PM   #146
Ferraz
Member#: 173553
1996 Civic VTi
Dark blue
Where can I get the Ecuflash? The link not working!!!!
Ferraz is offline   Reply With Quote
Old 07-14-2009, 12:14 AM   #147
AraSh
Member#: 211134
2007 Impreza STi
Originally Posted by Tea cups View Post
Post the ecu id shown in the lower right hand corner when you are connected with the logger and I can check and see if your ROM revision is supported or not. For extended parameter support (such as feedback knock correction, etc.), I have to have a copy of the ROM (extracted with EcuFlash) in order to define them. Likely no one has uploaded yours before, especially since it is an AT. If it is not supported, then you'll have to pull it with Ecuflash and a tactrix cable and send it to me and I can add logger as well as tuning support.
I'm having the same exact problem. I don't see the parameters "feedback knock correction", etc... How can this be fixed? and what do you mean by saying "you have to have a copy of the ROM to define them"? is this different for every rom?
And I have a 2007 wrx tr if that matters.
Also was wondering, tea cups, are you the person writing the definitions for RomRaider?
AraSh is offline   Reply With Quote
Old 07-14-2009, 08:50 AM   #148
Tea cups
Member#: 103136
You have to be connected to your car's ECU in order for the extended parameters to appear as they are ECU specific. That is, you have to have the tactrix cable hooked up, romraider running, and your car's ignition on in order to view any extended parameters. If they still don't appear (make sure you can actually log), then that could mean either you have old definitions or your ECU is not supported. If your ECU is not supported, that means that no one has uploaded your specific ROM revision before for support to be added (there can be multiple revisions for a particular car, so it doesn't matter if there's already support for a USDM 07 WRX MT, there can be multiple "versions" for that car).
Yes, I do the defs for RomRaider (my screen name at romraider is merchgod).
Old 07-14-2009, 11:21 AM   #149
AraSh
Member#: 211134
2007 Impreza STi
OK this makes sense. But still doesn't fix my problem. And the problem is that it is not supported because I did everything you mentioned (having everything connected and ignition on etc, AND it does actually log.)
I got a reflash at the dealership recently for "misfire" fix, so maybe thats why?
Anyway,
I have 2 questions:
1. Can I give you my ROM so you can update the def's for it?
2. If I "read from ecu" using ECUFlash, would it leave any marks on the ECU that it has been touched? I mean its not write to it its supposed to just "read" but still wanna make sure. Because I don't want the warranty to be denied with the car and ECU and everything
Thanks
Old 07-14-2009, 11:30 AM   #150
Tea cups
Member#: 103136
Yes, you can either PM me the ROM at the romraider site (merchgod) or post it there. Make sure you do it fairly soon as the next update will be in about a month.
Reading doesn't change anything as far as the ROM is concerned. The fact that you pulled the ROM should not be detectable by the dealership as far as we know.
romraider/ecuflash? weaponstroop Open Source Reflashes 8 10-21-2008 10:04 AM
reading logs - FAQ or getting started guide? jmc9809 Newbies & FAQs 2 08-05-2005 06:40 PM
I want to get started racing! Where to start? wayne_rx Motorsports 27 12-23-2004 03:00 AM
Auto-Xing Newbe, How to get started? Ed_RS New England Impreza Club Forum -- NESIC 7 01-31-2001 11:34 AM
how to get started jjp New England Impreza Club Forum -- NESIC 5 11-09-2000 06:26 AM
