Old 01-29-2002, 11:32 AM   #1
Torch
Member#: 10172
Question Fuel Additives (eg. Octane Boost)
I am wondering if anybody with WRX’s are using any sort of Octane boost? I have heard of people using 104+ and N2O, but do they work? Has anybody had any luck with either of these?
Thanks,
Torch
Torch is offline   Reply With Quote
Old 01-29-2002, 12:50 PM   #2
burr101
Member#: 907
2002 WRX Sedan
the only time i use octane boost is at the drag strip. I don't really use it for a preformance gain i just worry about the short bursts of speed w/ minimal time to cool down. I've never heard knock with my car but i never want to hear it either.
shaun
burr101 is offline   Reply With Quote
Old 01-29-2002, 01:00 PM   #3
malelee21
Guest
Member#:
I've used once and could not tell the difference....
Old 01-29-2002, 01:05 PM   #4
phxscooby101
Member#: 4355
Well i use 1 gal of 108 octane unleaded with a tank of gas since
our gas is 91 octane i'll get about 92.3 which is fine the less
the gas mix the higher the octane. and only costs 4.75 a gal
thats cheap if those octane boosters cost 6 dollars and only
raise your gas 3 to 7 points if that. later
phxscooby101 is offline   Reply With Quote
Old 01-29-2002, 01:13 PM   #5
Verist
Member#: 6501
Most octane boosters do nothing. Check out this link and this link which is even better.
Regan-
Verist is offline   Reply With Quote
Old 01-29-2002, 03:49 PM   #6
whitewag
Member#: 10164
2002 Black Sedan
looks stock
thanks for that link Verist, very informative
whitewag is offline   Reply With Quote
Old 01-29-2002, 04:46 PM   #7
selector37
Member#: 10370
So the octane boost only helps if your ECU is retarding your ignition timing? Does anybody have any idea how much the ignition is retarded on a stock WRX with various octane ratings? I'm in CA, which means I run 91 most of the time, and it would be great to see the difference between other people running 92 or 93.
Has anyone tried the toluene yet?
selector37 is offline   Reply With Quote
Old 01-29-2002, 04:56 PM   #8
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
I use 1 gallon of toluene in every tank, and have been for some time. The gas here in Oregon is pretty crappy, especially in the winter. 1 gallon of 114 octane Toulene with 12 gallons of 92 yields 93.7 octane. For track days, I usually run 1/2 110 unleaded race gas and 1/2 92 premium.
I have used toluene in both my Supercharged Integra as well as the wrx without any problems whatsoever. I would avoid going above 20% toluene, as the aeromatic content of the resultant mixture would be pretty high (certainly out of spec for normal gas).
-Jeff
sponaugle is offline   Reply With Quote
Old 01-29-2002, 04:58 PM   #9
mynew02
Member#: 13726
2002 WRX - 264 AWHP
ION-Turbo&LINK [email protected]
Does retarding mean that the number will just be less than normal or does it mean that it will go into the negative numbers?
I know that's a stupid question but I was examining a recording of my car taken from a scan tool and looking at my spark advance numbers.
My numbers were commonly around +12 degrees at idle and while costing, and they peaked at +30 degrees while under full acceleration (with stage0 and unichip.) Another guy's car peaked higher at around +40 degrees under full acceleration (he also had a stage 0 but I think Shiv may have re-programmed it) and I wasn't sure if my numbers were lower because of gas or his tuning...
Not trying to steal the thread but this seemed to be on track...
mynew02 is offline   Reply With Quote
Old 01-29-2002, 06:31 PM   #10
whitewag
Member#: 10164
2002 Black Sedan
looks stock
just went to a few hardware stores and they don't have toluene stocked for some reason. Went to Sherwin Williams they only had 1 gallon, and it cost $9.15!! Kinda pricey, thought it was going to be around $3-5, so I'll give it a shot see if it makes any difference.
Old 01-29-2002, 06:44 PM   #11
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
The only way I have seen to get the $3-5 is to buy in 20 or 55 gallons. There is a local place here in Portland (Tarr) that sells 20 gallon drums I believe..
-Jeff
Old 01-29-2002, 06:49 PM   #12
whitewag
Member#: 10164
2002 Black Sedan
looks stock
I wouldn't mind paying for a 20 gallon drum, but where would I find that sells it in bulk? Any suggestions?
Old 01-30-2002, 06:46 AM   #13
turbonutterbastard
Member#: 13548
MY99 WRX-vf22/Link/f
Blue mica
Here in Oz premium unleaded fuel is rated at 98 octane .I also add NF which is pushing the Ron to 100 or there abouts.
The benefit is being able to dial in significant advance , without fear of detonation - more advance more power.
The LINK of course allows the envelope to be pushed by manipulating timing , fuel and boost - for any given fuel .
turbonutterbastard is offline   Reply With Quote
Old 01-30-2002, 02:35 PM   #14
thng
Member#: 8062
Be careful with that. Sometimes the can says toluene but somewhere on the label it'll say toluol. Toluol is not as good as toluene.
thng is offline   Reply With Quote
Old 01-30-2002, 03:18 PM   #15
whitewag
Member#: 10164
2002 Black Sedan
looks stock
thng, it does say toloul on the label also.... I was wondering if there was a difference. I put it in last night and it made a huge difference. I'll have to hunt some more for this toluene
Old 01-30-2002, 04:54 PM   #16
Verist
Member#: 6501
Toluene is like crack.. so addictive. Weee. Whitewag, you can now send me copious amounts of money for the links
Regan-
Old 01-30-2002, 09:07 PM   #17
z&cobb
Member#: 12344
2002 2JC
blue
In the US the gasoline Octane Number is (RON + MON}/2, and the best I can get easily is 93. Most off the shelf octane boosters here are mouse milk because they "add up to 6 to 8 Points." points are like mortage points, like 0.1 percent. There is one that is coming out in February which will say a legimate "6 to 8 RON." 6 for 93 octane and 8 for 87 octane.
With my MRT system I will be able to dial in the octane for performance based on octane. If I get stuck at "last gas for 200 miles" in Death Valley, I can set it for 86 octane, or add some octane booster and set it for a higher octane. I am going to have fun experimenting with this system.
z&cobb is offline   Reply With Quote
Old 01-30-2002, 09:32 PM   #18
ascott
Member#: 6545
Rally Blue Pearl
Toluene is kinda hard to find in Kentucky these days. Meth labs use it, so the paint stores have cut all bulk sales to individuals at the request of the state Police and the DEA.
However, Xylene is available. 70% 93 octane plus 30% Xylene and a half a cup of ATF gives you about 100 octane.
The AFT is for a lubricant. If you mix in Toluene, you should use some too. It keeps the additive from drying out all the rubber parts in the fuel system.
ascott is offline   Reply With Quote
Old 01-30-2002, 11:31 PM   #19
Jung918
Member#: 10969
How long have you been doing this...? Seems kindof risy...
Jung918 is offline   Reply With Quote
Fuel chemistry - 110 octane plus lower grades to get 93 octane..? Deck Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 40 06-01-2005 08:17 PM
Best fuel additive? Mike Smith Service & Maintenance 14 03-25-2002 11:16 AM
fuel additive question IggDawg Normally Aspirated Powertrain 6 12-12-2001 07:37 PM
Fuel additives zensvx SVX Forum Archive 2 07-03-2000 01:58 PM
Fuel additives +/- John2.5RS General Forum Archive 2 05-28-2000 06:10 PM
