Old 12-19-2007, 11:08 AM   #1
I Love Boobies
Member#: 146137
06 WRX R.I.P.
06.06 - 10.08
Default is there a way to raise the box next to the tow hook.
i am trying to do a diy diffuser but am running into a lot of problems with the canister on the passanger side right infront of the tow hook. i belive there is a way to raise this so it tucks under the bumper to allow a flat diffuser. i think arp gives you new bolts to move it out of the way, anyone know what im talking about?
I Love Boobies is offline   Reply With Quote
Old 12-19-2007, 12:43 PM   #2
Mechie3
Member#: 120152
It's the charcoal canister. Do you have a wagon or a sedan? IIRC, it sits lower on the wagon relative to the bumper.
Mechie3 is offline   Reply With Quote
Old 12-19-2007, 03:51 PM   #3
I Love Boobies
Member#: 146137
06 WRX R.I.P.
06.06 - 10.08
i have a sedan, yes its the charcoal canister. how do i tuck it higher up in the bumper?
Old 12-19-2007, 05:02 PM   #4
vtecTHIS
Member#: 48048
. Nasioc, serious
Bidnazz
see how it's connected and try to figure a way to move it. haven't looked at in a awhile, not sure if you can move it honestly
vtecTHIS is offline   Reply With Quote
Old 12-19-2007, 05:13 PM   #5
fastlanerex
Member#: 133391
2004 boosted saleen
white
whats this for ive always wondered?
fastlanerex is offline   Reply With Quote
Old 12-19-2007, 07:18 PM   #6
bluwrx27
Member#: 107312
06 STI
it absorbs the vapors in the gas tank...p.s never overfill ur tank after the first click b/c that is the first thing that will break!!!!!
bluwrx27 is offline   Reply With Quote
Old 12-19-2007, 07:31 PM   #7
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
there is not going to be much you can do to move the charcoal canister
it basically bolts to a bracket mounted right to the chassis.
you'd be well advised to just leave that thing alone
and cut the diffuser if needed (dremel)
Jamie
Old 12-20-2007, 11:04 AM   #8
I Love Boobies
Member#: 146137
06 WRX R.I.P.
06.06 - 10.08
i would cut it, but the diffuser is going to be made of flat sheet metal. now that the canister hangs lower than the bumper, i can use a flat piece on that side.
Old 12-20-2007, 02:21 PM   #9
vtecTHIS
Member#: 48048
. Nasioc, serious
Bidnazz
if you're welding it, just weld a dip in it. or try to bend one in
Old 12-20-2007, 04:35 PM   #10
AaronWRX
Member#: 7194
2011 997.2 Turbo
its been a while since i installed my APR diffuser but if my memory serves me correctly seems like they had me remove the tow hook and provided some other hardware to move it up about 1 inch.
AaronWRX is offline   Reply With Quote
Old 12-20-2007, 04:48 PM   #11
I Love Boobies
Member#: 146137
06 WRX R.I.P.
06.06 - 10.08
i wish you had a better memory
Old 12-20-2007, 04:56 PM   #12
vtecTHIS
Member#: 48048
. Nasioc, serious
Bidnazz
read thru sausages diy diffuser thread. guess the apr diffuser has somethign in the kit that moves the box up about 2 inches. should try to get a copy of their instructions
Old 12-20-2007, 08:16 PM   #13
vf15hammer
Member#: 150385
60% TXIC
40% SCIC
I would like to add my two cents and hopefully clear this up.
Yes, you CAN move the box up so you don't have to trim the diffuser. I bought the APR and it is sitting on my 07 STi uncut (except for a little bit to clear the G200 ).
I did remove the towhook and then the spacers that are mounted on the bracket of the filter. I did slightly modify the bracket (with a hacksaw) so when the filter is raised it will still bolt together with the bolts that came with the diffuser. Suffice it to say you will see what I mean about modifying it when you go to do this task. The only issue was making sure the hoses stayed attached to the box as they are very short.
Maybe APR can give you more info....
Have Fun!
vf15hammer is offline   Reply With Quote
Old 12-20-2007, 10:50 PM   #14
redrex2002
Member#: 118915
2002 wrx
srp
little ot but i was wondering what the hell that box thing was for the longest time what happens if it breaks?? lol i have filled my gas up a little more than a coupple clicks before
redrex2002 is offline   Reply With Quote
Is there any way I can download pics/ringtones to my cell..without using my provider? GooseMan Off-Topic 9 09-23-2004 10:36 PM
Is there a way to test if my USB connections are hooked up? Stroke Off-Topic 9 04-14-2004 11:49 AM
is there a way to trick the ECU into thinking your o2 sensors are hooked up?? ammoniaman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 04-14-2004 12:16 AM
('93-'01) Is there any way to find out if the WRX is the most crashed "new" car this year? Snoopy Impreza Forum 25 10-16-2002 01:53 AM
Is there a way to make my RS raise up with a button like my friend's Legacy? scootr Brakes, Steering & Suspension 3 12-18-2000 06:35 PM
