Old 12-19-2007, 03:16 PM   #1
ChuChi
Member#: 128662
2006 WRX
Default Power cuts on/off under *LIGHT* boost
So I've been lurking on here for the better part of a year. Never had a reason to post before now. Every question I could possibly think of, and then some, had already been talked and flamed to death. Until now...
Tha car is stock, 26K miles, 1000 miles post oil change and 1/2 way through a tank of gas. I'm using the factory boost gauge (mPa FTL, it's on my list of TBD changes). Basically my power is not consistent. When hitting ~.02 on the gauge I can feel the power drop off and come back. Everything is fine as long as I stay out of boost. It feels almost like a rough shift or the shaking that happens when someone's learning to drive stick, except for I'm nowhere near the clutch at the time. As the power drops and comes back I can watch the boost needle move .005-.01 up or down accordingly. This is most noticable on long, straight, uphill sections where I can hold the car in boost for a good amount of time and not accelerate too much.
If I mash on it, boost comes up. It'll hiccup a few times as it passes through the .02 range, but once it gets to .04 or greater everything is smooth.
Now for the best part. It went away this morning!!
I first noticed it late Sunday night, but wrote it off as being way too tired and making it up. I confirmed it Mon morning on the way to work and took it right to the dealer. They were slammed and had me make an appointment for today. On the drive home Monday it got noticably worse (harder jolts, more often). I leave it home Tues, drive in this morning and it doesn't happen anymore. I spent the whole 20 mile backroad drive tring to get it to happen again. It's like nothing was wrong to begin with. Stop by the dealer anyway, but they obviously can't do anything unless they can reproduce it. They asked if it threw a CEL (no) and what gas I've been using (92) and said to come back if it happens again.
So, what do you experts think? ECU got confused and relearned? Some sort of boost leak magically sealed itself? My motor is going to explode in the next 100 miles?
ChuChi is offline   Reply With Quote
Old 12-19-2007, 04:51 PM   #2
Badler
Member#: 133597
Bad tank of gas possibly?
Badler is offline   Reply With Quote
Foglight on/off switch light isn't working txl146 Interior & Exterior Modification 19 08-10-2005 09:21 AM
Ignition cut under load/boost? rice wrx Engine Management & Tuning 2 06-25-2005 10:12 PM
Ignition cut under load/boost rice wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-24-2005 10:17 PM
all power cutting off beobe99 Service & Maintenance 0 06-03-2005 10:02 PM
Noise under dash with power going on and off Tangmere Service & Maintenance 1 06-06-2002 04:07 PM
