Old 12-19-2007, 07:11 PM   #1
Subaruski
Member#: 39905
Default Anyway around 07 immobilizer?
Purchased an 07sti drive train recently. I was wondering how do i get around the fact that the 07 ecu has an immobilizer?
Subaruski is offline   Reply With Quote
Old 12-19-2007, 07:14 PM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
There is no going around it other than a standalone EMS. You will need to get all the parts needed for the immobilizer, as well as the original keys or a key made by Subaru (Subaru will need to change the immobilizer on the ecu)
Old 12-19-2007, 08:01 PM   #3
Subaruski
Member#: 39905
What parts do i need? All i have is the motor, wiring harness, and ecu.
Old 12-19-2007, 08:07 PM   #4
flstffxe
Member#: 155358
2008 Forester
Steel Silver
not sure but couldn't you get by with a 07 key and switch, replace yours and add in any missing wiring? a thought.
flstffxe is offline   Reply With Quote
Old 12-19-2007, 11:44 PM   #5
bmxpunk
Member#: 89599
1995 almost 22B:)
red
Hmm I would have to check again but I think the body integrated unit and the Gauge cluster are part of the immobilizer system too. NOt positive though....
bmxpunk is offline   Reply With Quote
Old 12-20-2007, 07:27 AM   #6
Slack
Member#: 17548
From personal experience, I will tell you that trying to get a car running with a stock setup, including immobilizer equipment, is pretty much impossible. Go standalone or find another engine swap.
Mick
Slack is offline   Reply With Quote
Old 12-20-2007, 12:33 PM   #7
Rabidbyte
Member#: 36039
2001 Impreza 2.5RS
You need the Key, Immobilizer, ECU, and Antenna Halo. They all, except the antenna halo, have to be from the same car. If your mission any of these you are SOL. Wiring the immobilizer is no big deal.
Rabidbyte is offline   Reply With Quote
Old 12-20-2007, 12:42 PM   #8
Rabidbyte
Member#: 36039
2001 Impreza 2.5RS
The Gauge Cluster does not have to be present. The only thing that is connected to the Cluster is the LED.
-G
Old 12-20-2007, 06:59 PM   #9
JJ's Red Wagon
Member#: 155937
1995 Impreza w/EJ255
Red
I believe the MY07 uses the CAN system so the gauge gluster is part of the imobilizer like the Legacy GT. You can use an MY04 sti ecu and just repin a few things if you want to avoid the imobilizer.
JJ's Red Wagon is offline   Reply With Quote
Old 12-20-2007, 07:14 PM   #10
RSmatt
Member#: 8039
94 v2 STi RA - RHD
The 07 STi is definitely not a CAN BUS system. Rabidbyte is correct. You will need the key , immobilizer box, ecu and halo. Wiring is no big deal. I've done quite a few immobilized STi's and 06+ wrx' without issue.
RSmatt is offline   Reply With Quote
Old 12-20-2007, 11:13 PM   #11
Subaruski
Member#: 39905
Is there any negatives to using the 04 ecu?
Old 12-20-2007, 11:29 PM   #12
Slack
Member#: 17548
I believe you also need to upgrade all four wheel hubs due to the ECU needing input from the abs/speed sensors.
Old 12-21-2007, 03:40 AM   #13
Subaruski
Member#: 39905
I plan on running 04 sti hubs to retain 5x100 already.
Old 12-21-2007, 12:21 PM   #14
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
if you have the tool to reauthorize the key
the other option would be a hydra...
Old 12-21-2007, 12:40 PM   #15
flystiguy14
Member#: 74416
91 SS leggy
pearl white
Mick
This is not at all true, I have witnessed at least 3 swaps using the immobilizer. If you have all the components
you can just wire it in.
flystiguy14 is offline   Reply With Quote
Old 12-21-2007, 03:06 PM   #16
Slack
Member#: 17548
That is correct. BUT, if you have to replace any component down the line (even a key), you're screwed. The system would have to be reinitialized by a dealership and they won't touch any vehicle with that setup.
Either getting an 04 STi ecu or a standalone would be the savvy way to go.
Mick
Old 12-21-2007, 03:39 PM   #17
Subaruski
Member#: 39905
Ok so what are the negatives to getting an 04 ecu?
Old 12-21-2007, 04:11 PM   #18
flystiguy14
Member#: 74416
91 SS leggy
pearl white
Mick
For the average joe walking in off the street probably not but if you were to take your car to a reputable shop like the one i work for then they SHOULD be able to get it done for you. At least one of the swaps that we have done have had to have the key reprogrammed.
Old 12-22-2007, 10:40 AM   #19
Slack
Member#: 17548
Reprogramming keys is one thing, but if, let's say, a body integrated unit goes bad and needs to be replaced. Unless you work at a Subaru dealership and have access to a Subaru Select Monitor-2, then you couldn't re-initialize the system. I've talked with people that work for SOA and they said a dealership cannot legally will not touch a car that has a new Subaru immobilizer system installed into an older car that didn't originally come with that system. Is it a stupid rule for people like myself who want newer, technologically advanced engines swapped into their older cars? Yes. But unless you have a dealership who doesn't mind going against official policy and will hook your car up to the SSM-2, then installing such a system is not a wise way to go.
Mick
Old 02-03-2008, 04:53 AM   #20
hungy
Member#: 60877
Hey guys,
I recently just obtained a 2006 Legacy GT that is going to become my donor car for my gc swap. My question in regards to the immobilizer is the LGT immobilizer different then the WRX/STI one? Do I need to swap the guage cluster from an LGT into the GC in order for the system to work. I will have the whole car and both set of keys by the way. Any input would be great. thanks
hungy is offline   Reply With Quote
Old 02-03-2008, 05:26 AM   #21
kaos200
Member#: 2692
Mick
Not True. Totally stock swap is very much POSSIBLE, and recommended.
Precisely.
-G
Again Correct.
If you are wiring in DCCD, ABS, from the donor car. You must also swap in all 4 wheel hubs/sensors etc to be compatible.
I have done an 04 swap to an RS that was compatible because it was still using the old style ABS pump/computer but I believe we still swapped the hubs/sensors anyways.
kaos200 is offline   Reply With Quote
Old 02-04-2008, 09:00 PM   #22
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
Doing a stock set up EZ30R into a 97 OBS. I feel your pain. Right Mick? Why didn't your's have ABS again?(one of the reasons he went Hydra and I"m buying his stock ECU and a few other bits.)
-Gaddis
Seraphinwolf is offline   Reply With Quote
Old 02-05-2008, 04:11 AM   #23
mikeis300
Member#: 149526
2002 aps dr65 hybrid
9.1x1 built block/heads
i have a couple ecu's and matching keys ill try swapping them to see if they turn over the car. if they work i can setup up with a pair
mikeis300 is offline   Reply With Quote
Old 02-05-2008, 12:23 PM   #24
Subaruski
Member#: 39905
what year ecus and keys do you have?
Old 02-05-2008, 12:30 PM   #25
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
Mick
That's why you go to an Independent shop that has a SSM2 and can reprogram the immobilizers WITHOUT SOA's help This only works for the 05's. The 06's and newer require the SSM3.
wrx_driver_2002 is offline   Reply With Quote
Verizon requires data plan to activate phone. Anyway around it? Mrhappy Off-Topic 28 04-18-2010 12:09 AM
07 wrx ecu, key, immobilizer, compatible with 06 sti? Dubstar112 Subaru Conversions 1 04-02-2010 01:37 AM
Military folk... Anyway around the permanent medical profile? Drink Off-Topic 19 07-20-2009 02:30 PM
Anyway around the 24.75 psi target boost limit in the 16bit ECU? Phatron Open Source Reflashes 10 11-06-2008 07:24 PM
05, with 07 motor with immobilizer problem. hitadeercivic Subaru Conversions 9 09-23-2008 12:46 PM
