Old 12-19-2007, 08:43 PM   #1
Danny Boy
Member#: 94938
'99 Hybrid RS Coupe
don't-pull-me-over Silver
Default Starts, but can't stay running....
Car: 1999 2.5RS
Background: Just put it back on the road after ~4 months of sitting outside. I started it and drove it around every couple weeks though.
Problem: Car starts, and idles for a couple seconds, then immediately dies.
Weird stuff: NO CEL's, or any idiot lights. All gauges are normal.
What I'm thinking....
1. Bad gas? it has been sitting for a while
2. I took in water through my COBB CAI w/ fender liners removed and screwed something up. No hydrolock because it still starts.
3. ???????
Thanks for all input.
Danny Boy is offline   Reply With Quote
Old 12-19-2007, 09:01 PM   #2
y0ungsubi3
Member#: 155097
altenator?
y0ungsubi3 is offline   Reply With Quote
Old 12-19-2007, 10:27 PM   #3
Danny Boy
Member#: 94938
'99 Hybrid RS Coupe
could be, but would there be a CEL for that?
Old 12-19-2007, 11:04 PM   #4
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
Vacuum leak?
PhilSine is offline   Reply With Quote
Old 12-20-2007, 11:27 AM   #5
Outback4Me
Member#: 152751
1999 Outback Wagon
Deep Sapphire
Oops, forgot to log off..
Outback4Me is offline   Reply With Quote
Old 12-20-2007, 11:33 AM   #6
renyo
Member#: 93577
98 Impreza
Okay...
(and IE manages to prove why I use Firefox on a daily basis)..
Basically, I second the whole vacuum leak thing. Does the 99 have a MAF or MAP?
renyo is offline   Reply With Quote
Old 12-20-2007, 01:05 PM   #7
Danny Boy
Member#: 94938
'99 Hybrid RS Coupe
Maf.
Old 12-20-2007, 01:09 PM   #8
Danny Boy
Member#: 94938
'99 Hybrid RS Coupe
Which would be the most likely vacuum lines? Anybody know? I just looked around the engine bay and couldn't find any obvious ones disconnected.
I also took out the air filter (cobb CAI) and cleaned it. Man was that thing dirty. Once it dries, I'll put it back in. Maybe that was the problem.
Old 12-20-2007, 04:32 PM   #9
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
fuel filter? if its been sitting for a wile, gas can gel and mess up a few things
PARANOID56 is offline   Reply With Quote
Old 12-20-2007, 06:27 PM   #10
Danny Boy
Member#: 94938
'99 Hybrid RS Coupe
bump.
Old 12-20-2007, 06:46 PM   #11
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
I was thinking it was the alternator, because the 2.5RS has a pathetic alternator. I dunno if it throws a CEL or anything like that though.
Nevertheless it could be that. *shrug*
Bad gas is definitely possible, but it doesn't happen that easily. Even 4 months outside shouldn't gunk it up enough to stop fuel flow. But it is a possibility.
To be honest it could be a lot of things..
I had a family of mice taking and storing dog food in the exhaust pipes of an old SUV that wasn't used for months. That was IN a garage. Think of the possibilities when it's sitting outside. (That is not a joke. It's 100% true. The mechanic flipped out when he saw dog food come tumbling out of the exhaust. lol)
Just using my example to prove my point.
That being said, check for any kind of blockage in the exhaust... lol
Or in any kind of the intake lines and manifolds. Who knows what might have gotten stuck in there.
formula91 is offline   Reply With Quote
Old 12-20-2007, 08:18 PM   #12
renyo
Member#: 93577
98 Impreza
Possible MAF is going? What I typed before (using Firefox now) was that before my MAF went, I had like a 1/4 tank of gas in the car and it acted like it was out of gas. I put more in gas and for some weird ass reason it started.. Anyways, the MAF problems snowballed from there. It didn't throw a code when it first started either. Goes along with a vacuum problem too.. If nothing else pans out, maybe try cleaning the MAF and seeing if it helps.
Actually, if it's the MAF, you should be able to disconnect it and see if it stays on, although I think by the time I could/had to do that I had a couple of CELs and horrible gas mileage.
Just a suggestion..
Old 12-20-2007, 08:50 PM   #13
Danny Boy
Member#: 94938
'99 Hybrid RS Coupe
To answer a few questions/comments.
1. alternator - when I had the car running, a voltmeter read ~14V for the alternator.
2. MAF - I replaced my MAF a little over a year ago.
Old 12-20-2007, 09:07 PM   #14
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
yeah but you just said you sucked in a bunch of water a while ago
if you filtered water through the intake
the MAF could have been compromised
I would not rule that out.....
now... you said you "screwed something up" when you took on this water
what EXACTLY happened?
Old 12-21-2007, 01:15 AM   #15
Danny Boy
Member#: 94938
'99 Hybrid RS Coupe
I didn't say that very clearly. What actually happened is that I started from a stop in a puddle (~.5" so very small) and then did WOT to merge with traffic. Then the car just stalled.
What I was saying is that there might be a SMALL possibility that I sucked a little water in through my CAI through the fender-liner-less fenders.
Today I took apart my intake and found moisture in the filter element, and a tiny bit of moisture (very small amount) on the screen before the MAF. It was 100% dry at the throttle body.
I now think this may be MAF related. However, the last time my MAF went out (about a year ago) a CEL also went on. Is it possible that the MAF is screwed up, but isn't triggering a CEL?
Old 12-21-2007, 01:51 AM   #16
renyo
Member#: 93577
98 Impreza
Like I said my MAF didn't trigger a CEL for awhile when it was borked.
In a somewhat related story, (full stock intake was on including at that time the fender liner) while I was driving through water that was way too deep I think I did something to the engine cause it would surge and cut out at random times (and random throttle positions).. the next day it all dried out.. could've just been a fluke or maybe i got water in one of the sensors and had to wait for it to dry.. no codes though... Maybe with the CAI it had an easier time getting in, but I figure if anything were going to happen it would've happened around the time when you went through the puddle..
Another question though, did you replace your old MAF with a new or used one? When I replaced the first one it ran fine for about a year, then it quit so I had to get a third one. The third one has been going strong for the majority of the life of the scoob though...
Old 12-21-2007, 02:30 AM   #17
Danny Boy
Member#: 94938
'99 Hybrid RS Coupe
It was new OEM subaru.
Old 12-21-2007, 04:55 AM   #18
renyo
Member#: 93577
98 Impreza
Ok so the new airflow sensor probably didn't just randomly die. Although from what I understand they're pretty fragile..
You said you can get it to idle for a few seconds before it dies.. Does it ever get stable enough for you to tell if it feels rough or does it die too fast? Have you ever revved it when it was alive for the couple of seconds?
Old 12-21-2007, 09:00 AM   #19
Danny Boy
Member#: 94938
'99 Hybrid RS Coupe
Yes. But yesterday, it completely died on me. Now it doesn't start at all. Turns over, but doesn't start.
Old 12-21-2007, 09:23 AM   #20
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
I'd discard any thought of the alternator. I'm betting on fuel delivery.
LetItSnow is offline   Reply With Quote
Old 12-21-2007, 09:59 AM   #21
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
or air-fuel mixture.
you can try cleaning the MAF
but I would recommend you either....
get the car into a subaru tech for proper diagnosis
or try to self diagnose...
starting with a new MAF, pull and check all plugs, and ecu reset
Old 12-21-2007, 10:08 AM   #22
Danny Boy
Member#: 94938
'99 Hybrid RS Coupe
I already reset the ecu to no avail. I felt like I had exhausted all my own knowledge, so yesterday I towed it to my subie dealership to see whats up. Hopefully they'll be able to get to it today.
Old 12-26-2007, 11:43 AM   #23
Danny Boy
Member#: 94938
'99 Hybrid RS Coupe
Turns out that the timing belt had skipped a couple teeth. They replaced the timing belt and tensioner and thankfully no valves were bent, so now it runs good as new.
Car starts but won't run - VIDEO! HELP! trilap5e Normally Aspirated Powertrain 5 09-26-2013 04:16 PM
starts but runs for a few seconds acidrain088 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-15-2009 10:16 PM
Engine will not stay start/stay running akira02rex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-25-2008 08:16 AM
Car starts but wont stay on... need help mofoporn Service & Maintenance 2 02-24-2004 12:36 PM
