Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum
Old 01-29-2002, 01:49 PM   #1
Rusty
Member#: 4769
01 RS 2.5
Default 24K Check-up
I apologize if this has been discussed a lot, but what should I do for my 24K. Its a 2001 RS2.5, Std.
On of the local Dealers are charging $250 (starting). Which seems to be alot.
I was thinking I would:
Rotate Tires
Change Oil
Clean K&N
Change plugs (more for the upgrade to NGK's)
Get under and inspect all boots
Inspect Brake pads
Is there anything I am missing?
I would rather spend $250 on a good jack and solid set of stands and start working on my own car.
Rusty is offline   Reply With Quote
Old 01-29-2002, 02:16 PM   #2
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
The plugs only get changed at 48kms....
You could clean your brakes,
-grease the sliders,
-apply rustcheck to the door hindges, battery terminal, ground
-other stuff can be done.....
I went to Lachute and it cost me under $100 including taxes for the 24k service....
Robin
Robin2 is offline   Reply With Quote
Old 01-30-2002, 09:06 AM   #3
allwheeldrive
Member#: 14800
2000 2.5RS--->VQ35
yeah i payed $280 just got it done
after i looked at the bill they did nothing
all u r paying is the labor
bigggest rip off i got
allwheeldrive is offline   Reply With Quote
Old 01-30-2002, 04:50 PM   #4
STI RDY
Member#: 5738
2002 WRX Sedan
Sedona Red Pearl
Robin
$100 including taxes...wow, that's a big price difference from what you get from the Ottawa dealers.
I wonder if the $100 service applies to WRXs. If it does, then I might want a road trip up to Lachute in the near future...
STI RDY is offline   Reply With Quote
Old 01-30-2002, 08:05 PM   #5
d00f
Member#: 6000
2000 GC8 STi V4 swap
BRP
Lachute is the place to go. I prefer to take my business as far away from the locals as possible. Them taking me for a moron when I bent a rim and trying to convince me that I needed a new hub and bearing doesn't help.
Lachute will actually do more to your car for less money. They do stuff like glass beading the break sliders so they don't seize up (known problem) and oil your long bolts in the rear in case they ever need to be taken out so a cutting torch isn't needed.
Just call ahead and set up a time before you go. They are much better but I find they do take a little longer than other guys. Just get someone to show you the candy shop
-Michael
d00f is offline   Reply With Quote
Want a free check up to check up on your tune? 311logan311 Rocky Mountains Impreza Club Forum -- RMIC 41 05-11-2010 07:37 PM
7,500 mile check-up Hyudra General Community 7 12-04-2001 02:56 AM
70k mile check up chrisj Normally Aspirated Powertrain 1 06-28-2001 02:33 PM
30,000 mile check-up SupaScooby Newbies & FAQs 4 03-05-2001 05:52 PM
30K mile check-up Travis R General Forum Archive 5 06-15-2000 12:54 AM
