Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 12-20-2007, 03:22 AM   #1
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Default sti radiator fans vs. wrx radiator fans
is there a difference? i'm using the wrx wiring and the sti radiator fans and the plugs coming out of the wiring harness of the wrx are totally different then the plugs coming out of the sti radiator fans.
i guess i assumed they were exactly the same. wondering if i can just chop the plugs off both and hard wire.
thanks in advance.
GrimmSpeed is offline   Reply With Quote
Old 12-21-2007, 01:01 PM   #2
jeffg
Member#: 2958
2001 WRX (GC8)
Are they both two wire or three wire fans? If so I would assume you could just change plugs. If they are two wire on ones side and 3 wire on the other that may be an issue.
2 wires = single speed fan
3 wires = dual speed fan
AFAIK, it is okay to use a dual speed fan with a single speed fan controller, you just use one set of wires and leave the other set open. I dont think you can use a single speed fan on a dual speed controller. I think it will throw an error.
J
jeffg is offline   Reply With Quote
Old 12-21-2007, 01:23 PM   #3
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
J
the fan is an sti and has the 3 wire design. the wrx wiring harness side has 5 wires..2 are ground
stock L radiator or 02 wrx radiator for ej20k swap? 2slofouru Subaru Conversions 1 04-16-2009 09:54 AM
Pics of some STi RA Gears vs. WRX gears taken at RalliSpec Geoff Transmission (AT/MT) & Driveline 18 10-20-2004 10:33 AM
Sti Back seat vs. Wrx back seat Silverevo8owner Interior & Exterior Modification 2 12-01-2003 12:54 PM
STi vs. WRX Radiator? Estiem Service & Maintenance 5 10-21-2003 09:07 PM
STi Turbo size vs WRX-XT DRNWAGN Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 10-02-2003 01:33 PM
