Old 12-20-2007, 11:13 AM   #1
THEVERGE
Member#: 127421
2002 Subaru WRX
Default Problems flashing back to stock...
Ok, here's the deal.
I am rebuilding my 2002 wrx engine, and the entire engine is still completely out of the car.
I previously had a generic stage 2 map, flashed on the ecu using ecuflash.
I'm trying to flash back to the stock map but am having troubles getting the car to enter test mode, so...
1. Do I have to have the engine in and the wiring harness hooked up for the ecu to enter test mode?
2. If not, does anyone have any suggestions on what i can do to get the stock map back on the ecu?
Thanks,
Verge.
THEVERGE is offline   Reply With Quote
Old 12-20-2007, 11:25 AM   #2
dynamix
Member#: 122603
I would have thought an engine in the car would be the reason.
dynamix is offline   Reply With Quote
Old 12-20-2007, 08:00 PM   #3
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
find an 02-03 and swap the ECU you want to reflash into it and do it on the running car. I would think that the ECU would be pissed by having so many sensors disconnected that it wouldn't want to enter test mode.
/Brox
Broxma is offline   Reply With Quote
Old 12-21-2007, 12:02 AM   #4
THEVERGE
Member#: 127421
2002 Subaru WRX
Great! Thanks alot.
Old 12-21-2007, 12:20 AM   #5
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
/Brox
^^^ + 1 exactly
sense of nature is offline   Reply With Quote
flash back to stock tune? conrad87 Commercial ECU Reflashes 2 02-29-2008 11:08 PM
Flash back to stock question (gutted uppipe) Humboldt wagon Newbies & FAQs 12 10-26-2007 09:57 PM
Noob question on flashing back to stock tokstad Commercial ECU Reflashes 3 11-16-2006 11:06 AM
Can ecutek be flashed back to stock?? MachinesWRX Engine Management & Tuning 1 11-30-2005 08:20 AM
can eku-tek flashed ecus be flashed back to stock programming? dothespeedlimit Engine Management & Tuning 2 03-29-2004 01:22 PM
