South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 12-20-2007, 02:09 PM   #1
KevnKel
Member#: 165886
2008 Impreza WRX
Blue Mica
Question upgrade ECU?
ok, so i'm lookin' to drop in a high flow fuel pump/feul rail, and a set of Agency power AP-GDA-160 modified injectors (740cc), i've been told that some modified injectors require an upgraded ECU, or "piggy back" which i don't have. the website i found the injectors on said nothing about needing an ECU.
does anyone know anything about the above mentioned injectors, will i need a new ECU, or just a tune?
KevnKel is offline   Reply With Quote
Old 12-20-2007, 02:28 PM   #2
DroppedClutch
Member#: 52313
2005 STiOmgWtfBbq20G
2007 MS3 Black
Agency power/vivid racing is not generally recommended around here. You might want to do some searches for vivid and determine for yourself if you want to give them your money.
You wont need a new ecu, just a tune...
Do you have other mods that even require a fuel upgrade?
DroppedClutch is offline   Reply With Quote
Old 12-20-2007, 11:42 PM   #3
KevnKel
Member#: 165886
2008 Impreza WRX
Blue Mica
well not yet, but i'm mapping out all the parts i'm gonna get, figgerin' out what order to do things in, and buying them piece by piece as i can afford them.
why would you not recommend agency power / vivid? who WOULD you recommend?
Old 12-21-2007, 12:02 AM   #4
NO PULSE
Member#: 110733
NO PULSE is offline   Reply With Quote
Old 12-21-2007, 12:15 AM   #5
DroppedClutch
Member#: 52313
2007 MS3 Black
Not only that ^^^ thread, but if you search nasioc you'll find tons of reasons not to give them your money. Google "vivid racing sucks", you'll find people in other communities/forums with nearly identical problems.
I don't know what your power goals are, but you likely wont need new rails. Read the Unabomber's fuel faq (http://forums.nasioc.com/forums/showthread.php?t=533787). Regarding injectors... I've used Helix, Nismos, and am currently running Sards. PEs seem to be working well for many. I know some around here are using deatschwerks.com modded injectors, if you want to go the mod route.
Upgrade ECU timpreza5 Engine Management & Tuning 0 02-27-2006 03:31 PM
'04 FXT looking for someone to upgrade ecu windsurfnut Forester Forum 3 01-21-2005 02:07 PM
Anyone passed emmissions with Upgraded ECU? MY99 2.5GT Mid Atlantic Impreza Club -- MAIC 5 03-13-2003 01:06 PM
Can I keep boost controller with upgraded ECU? wReXeRw Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-30-2003 02:12 PM
