Old 12-20-2007, 02:15 PM   #1
RedRicer
Member#: 128810
05 STI
CGM
Default Vista, LC-1, Serial to USB cable
What version of enginuity logs LC-1 data with vista? Should I run it as XP 2 or admin or something? I am using a converter cable from serial to USB and 774 doesn't work. 702 works sporadically but goes between 0 and correct sporadically
RedRicer is offline   Reply With Quote
Old 12-20-2007, 02:19 PM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
774 is the version which has the plugin for lc-1. it's probably a conflict with vista.
Old 12-20-2007, 02:53 PM   #3
RedRicer
Member#: 128810
05 STI
CGM
Default Anyone have it working?
Does anyone have Vista and LC-1 logging with 774?
Old 12-20-2007, 09:40 PM   #4
jibber
Member#: 6675
98 SF5 some mods
01 allroad
There was a glitch in this version I think that requires you to check, uncheck, and then recheck the LC1 in order to get it to start logging. At least this is the problem I have with XP and that version. There may be an issue with the USB to serial adapter as well. I recall there may have been problems with certain brands.
Good luck
Josh
jibber is offline   Reply With Quote
Old 12-21-2007, 08:37 AM   #5
RedRicer
Member#: 128810
05 STI
CGM
Default I will try that
thanks I will try that. I heard there was a glitch but still had my xp laptop until recently. I have a good serial converter so I think I should be ok. IT has worked in the past with a different version just sporadically.
Old 12-21-2007, 01:12 PM   #6
Casey
Member#: 82371
2002 IMPREZA
22 psi @ 2600rpm
Does anyone know what brands of serial-usb adapters work? My LC-1 is on the way and I need to pick one up.
Casey is offline   Reply With Quote
Old 12-21-2007, 02:02 PM   #7
RedRicer
Member#: 128810
05 STI
CGM
Angry
The check, uncheck, and recheck LC-1 workaround fixes the glitch.
I got a belkin from Comp USA works like a charm but it is 60$
Old 12-21-2007, 03:12 PM   #8
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
http://www.newegg.com/Product/Produc...82E16812107108
This has worked great for me, ~20 with shipping.
Not sure if it ships with drivers, or if you need them, but they are on gwc's website.
ExpO is offline   Reply With Quote
Old 12-21-2007, 03:55 PM   #9
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Old 12-21-2007, 04:15 PM   #10
Infamous1
Member#: 133692
2003 Chevy Z06
Black/Black
Infamous1 is offline   Reply With Quote
Old 12-22-2007, 04:16 AM   #11
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
http://www.gwctech.com/prodimg/driver/ap1103.zip
For some reason newegg calls it a uc320, and gwc calls it the ap1103...
Old 12-22-2007, 09:55 AM   #12
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
I do, no problems. I use the latest EcuFlash too on Vista. Using an Airlink serial to USB.
gabedude is offline   Reply With Quote
Old 12-22-2007, 03:17 PM   #13
Phatron
Member#: 36033
CEO PhatBottiTuning
I hooked up my LC-1 and I am getting the Error 1 code. Says the cable is bad or the sensor. I bought 2 LC-1's, one for my wrx and 1 for the STi. I tried both bosch sensors and i get the same code.
Is it possible that this is a wiring issue? Or is my LC-1 cable just bad?
THanks
ron
Old 12-22-2007, 03:39 PM   #14
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
Error 1 is for a shorted heater circuit, do both sensors work on the other LC1? Other than the slight possibility of two bad sensors, I'd check your wiring. All the grounds should be soldered together, then grounded (preferably to the block, although mine worked fine on the chassis). Also, if you're using the LED, check the polarity.
Old 12-22-2007, 03:49 PM   #15
nhat
Member#: 140163
03 STi
hellaflunctional
probably a bad ground. i wired my ground to the chassis by the BCS.
Old 12-22-2007, 03:51 PM   #16
Phatron
Member#: 36033
CEO PhatBottiTuning
I only have the LC-1 hooked up on my WRX. My STi isnt here right now.
I ran a ground from the battery to a distrubution block and grounded everything to that, not soldered, its just a 1 in 3 out connector.
I did the same for the power.
Old 12-22-2007, 05:56 PM   #17
Infamous1
Member#: 133692
2003 Chevy Z06
Black/Black
I have the radio shack adapter also and I cant get my computer to see the driver for nothing.
Old 12-24-2007, 12:19 AM   #18
Phatron
Member#: 36033
CEO PhatBottiTuning
my radio shack adapter wont use the driver above either
Old 12-24-2007, 04:13 PM   #19
jibber
Member#: 6675
98 SF5 some mods
01 allroad
I am glad that helped!
Old 01-12-2008, 02:00 PM   #20
Infamous1
Member#: 133692
2003 Chevy Z06
Black/Black
Got my plug to work with the install disc that came with it. What you have to do to install is, don't let it autorun run, stop it and view the file on your disc. Right click on file and select properties click on compatibility and select to run as XP SP2. Then double click file to start install and just folow instructions given.
Old 01-12-2008, 03:33 PM   #21
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Radio Shack drivers do not work correctly under Vista.
Keyspan makes a Vista-compatible unit that is very nice. It also has the screw-in connections for the serial port, so you can solidly connect the Innovate cable to it without fear of it coming loose during a tuning session.
http://www.keyspan.com/products/usa19hs/
I think I paid $35. Works perfectly with my LC-1 using Enginuity. Works perfectly with my LC-1 and LM-1 using EcuEdit.
lancelucas is offline   Reply With Quote
Old 01-12-2008, 04:51 PM   #22
Infamous1
Member#: 133692
2003 Chevy Z06
Black/Black
Works for me....
LC-1 Serial to USB MicMcKee Open Source Reflashes 7 04-02-2009 01:15 AM
FS: (PA) 2005 STi Accessport v1 + serial to usb cable rcolonie Tri-State Area Private Classifieds 5 02-17-2007 07:20 PM
FS: (PA) 2005 STi Accessport v1 + serial to usb cable rcolonie Engine/Power/Exhaust 6 02-17-2007 07:20 PM
FS Tucson: 02-03 AccessPort with Free Serial to USB Cable Payback SWIC Private Classifieds 1 11-05-2006 02:12 PM
FS: CT Serial to USB adapter for UTEC remborsky Private 'For Sale' Classifieds 9 11-11-2005 12:56 PM
