Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 12-20-2007, 07:03 PM   #1
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
Default fuel pump wont prime
anyone know why this might be? 03 wrx swapped into 97 lgt....walbro 255 fp
any suggestions would be great
legacy1907 is offline   Reply With Quote
Old 12-20-2007, 08:44 PM   #2
supasweetr34skyline
Member#: 113060
2000 Built GC8
Aiming for 10's
check relays under the hood. i had this problem when one of my wires caused a relay to go out. car wouldnt crank or prime.
supasweetr34skyline is offline   Reply With Quote
Old 12-20-2007, 10:28 PM   #3
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
well....we went to check for problems by connecting the subaru scan tool to the ecu, however it wont connect. Not sure if this is a harness problem or an ecu problem....any ideas???? any help would be GREATLY appreciated!
Old 12-21-2007, 12:22 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
did you install the fuel pump controller?
the ecu primes the pump
you have a wiring proublme if you can't connect to thecu
Car Wont Start... Fuel Pump Not Priming... Any Ideas? dug-e-fresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 08-09-2011 04:35 PM
trying to swap my stock cluster back in but fuel pump wont stop priming fourage20 Interior & Exterior Modification 1 03-26-2009 12:33 PM
Fuel Pump wont prime!! 02ej257 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-08-2006 04:45 PM
Fuel Pump not priming ** prodriveuk Newbies & FAQs 3 04-15-2006 02:13 PM
fuel pump not priming/ecu not on? attitude Engine Management & Tuning 16 06-24-2005 01:16 PM
