#1 |
Member#: 14727
Vehicle:2002 impreza RS |
Price: $200 shipped
Installation: long but painless Negatives: just one Overall: positive I purchased my trailer hitch from subaruparts.com. It came with instructions; however, some modification is required. On my car, I needed to drill a new hole in the thin U-shaped bracket that holds the rubber exhaust hanger. This hanger is located closest to the corner of the car...you'll know what I'm talking about if you want to do this. Since the hitch relocates the bracket, all you have to do is drill a new hole and flip it around. The bracket already has a little hole right in the spot you need to drill. I used a dremel to make it larger so that the 17mm mounting bolt could fit through. I used a jack to get the hitch in place because it weighs 30 lbs. Once the hitch is fitted, position the bracket so you use the new hole instead of the original one. There you go. As far as bumper trimming, I didn't do any, but it does touch near the muffler cut out. I think it is a good idea to trim this area somewhat, but not as much as the instructions claim. I think that it is a sturdy unit; I was niether impressed or disappointed with it's quality or fit. The paint on mine, however, was poor. It was flaked off in a few spots when I got it, so I gave it some rustoleum before installation. After a month, the paint flaked off in other places...so I painted it some more. Now it's fine. For $200 I think it's worth it if you plan on pulling or using a hitch mounted bike rack. It is not very low profile, but it's better than the Uhual ones. One strong suggestion I would make is to install harder exhaust mounts at the same time if you drive agressive or over bumps. You might as well since the two on the muffler have to be taken off and the hitch comes pretty close to the muffler tip. |
#3 |
Member#: 11015
Vehicle:'06 Volvo V70R Sonic Blue |
I installed the OEM hitch on my '02 Forester and I found the install ok. One of the bolts on the passenger side did not want to align and thread back in. Fortunately, there was another open hole that did work. Other than that the install was very straight forward. The wiring install was a snap, kudos to Subaru for having a wiring tail inside ready to go.
There is plenty of clearance around the factory exhaust chrome tip, the fit and finish on my unit is excellent, still nice after a year. I got my unit at the dealer.I towed a 5x8 u-haul trailer, unloaded weight was 900 lbs I think plus I hauled a load 1500lbs of bricks, 2400lbs total and I didn't have any issues. I have an automatic trans and even going up hills the Forester never seemed to struggle or have odd shift patterns. I am very happy with how the 2.5L engine handled the job. I got a ball and harness adapter at u-haul. |
#4 |
Member#: 22828
SCIC
Vehicle:02 Impreza Sedona Red Pearl |
correct me if im wrong but i heard that the wrx can also tow? i was very curious to know about that? have any insight?
#5 |
Member#: 17924
Vehicle:2003 Baja Black/Silver |
I bought a hitch off here from a guy and had it installed yesterday. the installation went pretty smooth and it lined up just fine. The only problem we had was the muffler being a little close to the hitch itself, so we got some washers to give it a little more room. My only concern is that the only a Twin tip aftermarket exhaust will work due to others hitting the hitch frame. as far as towing I talked to a Subaru person and he said " If you have transmission problems they will look at the hitch as the reason " I said well I'm just using it as a bike carrier. I paid about 75 bucks for a used hitch and you can get them elsewhere for 89 bucks.
#6 |
Member#: 22828
SCIC
dont mean it in a bad way.. i am just annoyed at the fact that the warranty can be voided so easily with this car.. damn them!!! so if we get a hitch and the tranny blows they can blame the hitch huh.. that sucks.. well i havent got an aftermarket exhaust yet but the thought of the hitch has dawned upon me...
#7 |
Member Sales Rating: (3)
Member#: 16906
Vehicle:2k3 wrx wagon |
I actually am taking off my hitch this weekend. The person I bought it from had it put on there cause I guess he had some jet skis. It's for a 2002 WRX, it's made by hidden hitch I believe. If anyone is interested I'll be selling it on I-club or Ebay as soon as I get all the info on it. Peace.
#8 |
Member#: 17924
Outkast - I'm with ya on the waranty thing ! I 've looked at BPM turbo back and MRT exhaust. I think these will work because they have the outlets at the bottom instead of the middle like others.
#9 |
Member#: 18834
Vehicle:2002 WRX wagon Silver |
I'm planning on installing a hitch to mount a bike rack on. As to the warrenty issues, the dealer may look at the hitch and tell you that the warrenty is voided, however it's not that simple -- they, the dealer/SOA, have to show that your use did the damage. In otherwise that the modification was the cause of the problem. So one might have to fight, but they can't just say that the warrenty is void because you have a hitch...
my 2 cents... Now with my hitch question... Is there a 2" reciever that mounts to the impreza wagon? I Want to beable to use the same hitch on the truck and car w/o adapters, and to beable to carry more than 2 bikes on the rack... Most or all rack makers say you need a 2" hitch to carry 4 bikes... |
#10 |
Floresbian
Moderator Member Sales Rating: (8)
If you want a better price on hitches check www.etrailer.com I got my Draw-tite hitch for $89
#11 |
Member#: 23345
Vehicle:2002 WRX Wagon Silver |
First question is for OPIE, did the Drawtite fit oK? I seen their's on etrailer.com and it seems that the hitch would interfer with the exhaust and how is the quality of Drawtite and ease of installation.
Next question is for "imprezive one" When Where and How much. also same questions for the Hidden hitch. thanks |
#12 |
Member#: 17924
My hitch fits fine and wasn't that hard to install. I have a Drawtite from etrailer and the exhaust is fine , but a little close. I'm going to eventually get an aftermarket exhaust , but only one with the tips at the bottom will work. You couldn't get one with the large center pipe due to it hitting the hitch. As far as the warranty issue I was saying that if you had transmission problems they would blame it on that !!!! A rep from Subaru said this to me ! But you are right the have to prove that is what caused the problem. But a Mountain or Road bike isn't going to cause a transmission problem !
#13 |
Floresbian
Drawtite fits fine, with a stock exhaust it will clear with no problem, depending on the size of the tip on aftermarket exhausts it may sit on the hitch. I have the SPT exhaust with Cusco hangers and the tip bearly touches the hitch, I zip tied a piece of rubber hose to the hitch and it is quiet as can be!
![]() My self & 3 other RS owners have the same hitch from etrailer (1=1999, 2=2000 & 1=2002) with no problems at all. |
#14 |
Member#: 23345
Great pic Opie, thanks really. Only problem is i have a WRX, i guess i should have mentioned it in the first post.
But i will look at etrailer.com website and see if the manufacter num. is the same for the 2.5RS and the WRX is the same. let us bow our head now and pray i do not have to spend an extra hundred for subaru's hitch. |
#16 |
Member#: 21783
Vehicle:2002 WRX Aspen White |
Now with my hitch question... Is there a 2" reciever that mounts to the impreza wagon? I Want to beable to use the same hitch on the truck and car w/o adapters, and to beable to carry more than 2 bikes on the rack... Most or all rack makers say you need a 2" hitch to carry 4 bikes... [/b][/quote]
I can't remember which hitch I had installed on my WRX, but it wasn't from Subaru since I have the sedan. The trailer shop that installed it for me, cut the 1 1/4" receiver off and installed a 2" reciever for me. It was a little extra, but you have a greater variety of racks you can use. I recommend the SportWorks rack, it's easy to use and very well made. Just a bit heavy. |
#18 |
Member Sales Rating: (2)
Member#: 24654
NESIC
Vehicle:1957 Taggart Comet gold |
I have an 03 Impreza pamphlet that also says the WRX can tow 2000 lbs. However, I have seen in a few places that Subaru does not recommend towing with the WRX. Perhaps they keep changing their minds but if Subaru's literature says you can tow they should not blame you if the tranny blows.
My understanding is that you have to be careful not to have the turbo boost up for long periods of time i.e. hauling a load up a long hill because you might overheat the turbo. |
#19 |
Member#: 64517
Vehicle:2005 impreza wrx black |
Hi guys, I am new to the subaru community. I just got an 05 wrx sedan. I am just making sure my info is correct. the frame has not changed to this year so the hitches you speak of above should work fine. Also, has there been any more clarrification about the warranty thing. I have also seen yes and no in subaru literature.
thanks, --z-- |
#20 | |
Member Sales Rating: (4)
It is very low profile and the hitch itself is painted fine, with nice welds. I think it is the best deal out there for the money.![]() |
#21 |
Member#: 31922
SWIC
Vehicle:03 wrx wagon fastAr than sound |
I just ordered a draw-tite! I'm nervous about fitment, as I have an aftermarket exhaust, but.. I guess I'll figure it out when it arrives! How about wiring, I understand the car (2003/wagon) has a plug ready to go? can someone verify this for me, and .. where is it? Thanks!
#22 |
The car is pre-wired for a trailer hitch. You'll need to get the T One Wiring Harness that goes for $34.95 (this is the same plug that fits the Legacy - don't worry, it fits the WRX too). The 6 plug adapter is (facing the rear of the car) on the right side. Pretty much behind the right taillight, near the bottom, but behind the cargo coverings and such - where you would expect to find wiring for a car. You run the wire through a grommet that is underneath the spare tire. Or you can leave it in there like me, and just pull it out and stick it between the wagon's door and the trailer only when you have to tow. Good luck!
#23 |
Member#: 31922
SWIC
Thanks very much!! I dug up the part number from an older post, and called them up, armed with confidance in Nabisco
The lady was like "I really can't recommend that you buy that........ if it worked in the Impreza, it would say so right here!! And it doesn't!!" But I made her sell it to me anyway! ![]() I think I might have to go ahead and get longer exhaust hangers, though, as I have a crazy aftermarket system. It's a dual-tip straight pipe that I had someone bend for me, and I specifically wanted it to sit up in the cutout all cozy-like, and... I think now that there just isn't room in there for everything, based on the pic of your car, and the hitch relative to the cutout. It's always something! |
#24 |
I placed my order online, so I didn't have someone tell me what to buy/what not to buy.
Good luck, and keep us updated on your progress. I hear that you may want to go with Kartboy hangers to help make the muffler fit. As you can see from the picture, there isn't much space to fit a large muffler outlet. |
#25 |
Member#: 95854
Question about hitches
So I'm leaning towards the Drawtite hitch because its so low profile, but I was wondering if it will interfere with a Greddy EVO2 exhaust which I want to install in the future. I was thinking of getting the kartboy exhaust hangers, if there was a problem will that solve it? Also, if any of you use Bike Racks, which ones do you use, either two or three bikes. thanks. Michael |
