Old 12-19-2007, 12:59 AM   #1
pilotstephen
Member#: 155145
2004 WRX STI
Bruised
Default Check Engine Light
Ive got a check engine light. Can I use my Tactrix cable with Enginuity or any other open source software to read the OBD II codes?
pilotstephen is offline   Reply With Quote
Old 12-19-2007, 01:28 AM   #2
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
You'll need ecuExplorer to do it.
Old 12-20-2007, 08:02 PM   #3
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
I've never been able to get ECUExplorer to work for me. I bought an OBD2Allinone cable to pull codes. Problem now is sometimes it conflicts with the com port for the tactrix drivers. Fundamentally ECUexplorer works, just not for me apparently.
/Brox
Broxma is offline   Reply With Quote
Old 12-21-2007, 12:27 AM   #4
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
Never worked for me either , But works for my Bud no prob ?
sense of nature is offline   Reply With Quote
Old 12-21-2007, 10:32 AM   #5
quazimoto
Member#: 70395
Works fine for me using the Taxtrix.If you have Ecuflash installed it will have the proper drivers for it.The just install Ecuexplorer
Old 12-21-2007, 11:16 AM   #6
Tea cups
Member#: 103136
You can't rely on Ecuexplorer for code reading as it is not an obdii scanner and the feature was never fully developled. Only if your ROM revision happens to match the template of bit checks that is supported, will it read correctly. Unfortunately, this can change not only between different years, but different ROM revisions in the same model and year. It seems to work fine on the USDM 02 WRX, but I've tried it on an 03 WRX later ROM revision and it returned something like 5 codes (when only 1 was actually set), in which some of the codes it returned didn't even apply to vehicle.
Tea cups is offline   Reply With Quote
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 03:42 PM
Check engine light, VDC light is on, and cruise control and sport light is flashing Legacymun2k6 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-30-2010 12:47 PM
check engine light, wierd engine trouble? gipoliceman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-14-2003 09:04 PM
Engine coolant temp sensor check engine light? rhdude Mid Atlantic Impreza Club -- MAIC 2 11-09-2002 02:42 AM
Engine vibrating, check engine light on codemunky Service & Maintenance 2 09-15-2002 07:50 AM
