Old 07-01-2010, 05:44 PM   #226
murproject
Member#: 204836
2001 WRX
Do we need to change the subframe, transmission cradle, control arm and etc. while doing these swaps? Does 05+ r180 fits into the place of r160?
Thanks a lot.
murproject is offline   Reply With Quote
Old 07-01-2010, 05:59 PM   #227
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Bolts right in. No changes to the stuff mentioned.
Old 07-02-2010, 04:17 PM   #228
murproject
Member#: 204836
2001 WRX
I am thankful for your answer.
I am planning a swap to 02 EU WRX.
There are lots of choices for me. I can't select which would be good for me.
JDM MY04 V limited or 07 USDM? (both 6 speed)
I got the list:
transmission(reverse lock out, neutral switch, shifter assmbly, boot, knob)
r180(dccd sensor)
driveshaft
starter
2007 master slave, rotors,pads, calipers, brake lines, e brake cable
2007 clutch line & clutch fork
dccd computer & controller
6gunracing Hub&Knuckle change
but not sure about the crossmember, transmission cradle and subframe.
If i change those. Do i need to change endlinks, sway bars ? What about front?
Sorry for my English
Old 07-02-2010, 05:05 PM   #229
kpluiten
Member#: 120273
06 WRBWRXWGN
You don't need the starter. The WRX one works fine.
Old 07-02-2010, 05:17 PM   #230
murproject
Member#: 204836
2001 WRX
but if i use WRX clutch and flywheel? Isn't it? or if i use 2007 STI flywheel and clutch?
Old 07-02-2010, 07:48 PM   #231
kpluiten
Member#: 120273
06 WRBWRXWGN
My WRX starter works on STi flywheels.
Old 02-26-2011, 02:54 AM   #232
phattydrummer
Member#: 183070
2003 WRX
True Blue
Hey everyone! I read through all 10 pages of this thread to find the answer to a riddle I am dealing with, but it sounds like no one else has had this problem. If this info is in this thread, I missed it!
I am swapping the 6mt into an 06 wrx. The wire harness on the 6mt has the same connector location as the 5mt. The difference is that the 6mt has 2 round connectors, one black and one white, and the 5mt has one square connector. The vehicle harness calls for one square connector. obviously..
I think the 6mt came out of a 06-07 STI. The whole deal was sold as a "kit", drive axles, rear diff, shifter and everything included. The guy that sold it says that it all came out of another wrx that is going back to the 5mt, so theoretically, it should all work just fine.
I just need help on this little wiring harness issue...
phattydrummer is offline   Reply With Quote
Old 03-02-2011, 12:11 AM   #233
WRX-17
Member#: 98725
05 WRX
I am not sure exactly what you are talking about since there are 3 plugs total on the tranny. There is the speed sensor at the front passengers side and the two other plugs that go into the middle drivers side of the tranny. All my connectors are grey or black. Talking about the two that go into the side of the tranny, there is a 4 and 6 pin connector. I was able to get the sti 4 pin connector to splice into my car's harness to hook it up. You could go buy a 4pin connector at radioshack and use that or hook it up however you want. What is you actual question here?
WRX-17 is offline   Reply With Quote
Old 03-02-2011, 08:14 AM   #234
srREXed
Member#: 72234
2004 WRX SRR
EJ257-35R-6MT
Take a picture, it seems that you are not describing the connectors properly... My 5-6 swap was simple, plug the speed sensor, the N pos switch and the R pos switch and done. It really is as simple as 1-2-3.
srREXed is offline   Reply With Quote
Old 03-02-2011, 12:50 PM   #235
WRX-17
Member#: 98725
05 WRX
yeah you should take a picture of what you have going on. heres a pic of my car if it helps at all or at least tell me what you're asking about referencing my picture
Old 03-02-2011, 12:50 PM   #236
WRX-17
Member#: 98725
05 WRX
Old 10-13-2011, 11:19 PM   #237
mrjcotten
Member#: 241953
02 hybrid/6speed
01 2.5 RS sedan
Ok, so I'm not sure if this is t right place to ask this or not. I know that you can run wagon front axles in a sedan, but can you run sedan axles in a wagon? I think the sedan axles are 10mm longer maybe ? I do remember and I can't find any of the threads that have this info in them right now.
I have an 02 wagon that I am doing this swap on btw. Need to know if 05 sedan axles will work or of I need wagon axles.
mrjcotten is offline   Reply With Quote
Old 10-14-2011, 08:08 AM   #238
02RexWI
Member#: 165141
They should work just fine. 10mm is hardly anything, and the joints have a little slip in the joints.
02RexWI is offline   Reply With Quote
Old 12-28-2011, 04:02 AM   #239
Ethan_Drift
Member#: 264930
2011 GT, Evo 8
Sorry to bump this for a dumb question. Putting a 06-07 STi trans in my 04 WRX. How can I tell if I have the older or newer front axles? No need to change anything in the Rear Diff, correct? Also, will any year clutch fork and shifter assembly work, or do I need one from an 06-07?
Ethan_Drift is offline   Reply With Quote
Old 01-05-2012, 01:18 PM   #240
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
not sure if it was added later, didnt feel like going through this whole thread...for the OP the 02-05 wrx front and center diffs are 3.9's and the rear diff like the OP said is a 3.545 the 1.1:1 transfer gears make this possible. Not sure why subaru did this.
BlackJavaPearl04 is offline   Reply With Quote
Old 01-10-2012, 03:05 AM   #241
petiey33
Member#: 233956
02 wrx/sti
wrb
Quick question. I have a 02 Wrx. I'm putting a 06 STI trans in. I know I need the axle stubs from the 04 STI to reuse my front axles. From my research I've seen that I need specific oil seals for the stubs to properly work with the 06 trans. I've seen different part numbers for these seals. Just wondering who has done this specific swap and knows exactly which seals to use. Thanks.
petiey33 is offline   Reply With Quote
Old 01-10-2012, 07:27 AM   #242
02RexWI
Member#: 165141
You need the stubs and axle seals from an 04' STI. I can give you the VIN from an 04' STI if you need it for the dealership to look up the parts.
Old 01-11-2012, 09:01 PM   #243
coyote_94yj
Member#: 289875
2005 Impreza WRX
Platinum Silver Metallic
I would like to question the difference between the 5MT and 6MT transmission mount as noted in the first post. Last night I pulled the 5MT out of my 2005 WRX and bolted up a 6MT from a 2005 STi. I was able to use the stock 5MT transmission mount. It bolted right up.
Everything I've read on the forum about 6MT swaps has said the mounts are different and need to be swapped as well. Am I missing something or did I just throw a wrench into the blender?
coyote_94yj is offline   Reply With Quote
Old 01-11-2012, 11:13 PM   #244
02RexWI
Member#: 165141
I believe the crossmembers are the difference... there is a 5MT crossmember, and a 6MT crossmember. The mounts bolt up to the transmissions the same, but where the mounts bolt to the crossmembers are different.
IDK if that makes sense or not... lol
Old 01-11-2012, 11:27 PM   #245
coyote_94yj
Member#: 289875
2005 Impreza WRX
What you are saying makes sense but I used my old 5MT transmission mount and the 5MT cross member as well. The transmission is completely installed in the car utilizing all 5MT mounting hardware. I hadn't yet bought a 6MT mount and was putting the tranny in the car so I thought I would take a couple of measurements while I had both trannys on the floor to see what the differences were in the mounts. So I measured from the end that mates with the back of the block to the holes where the tranny mount bolts go on and the measurements were the same on both trannys. I installed the 6MT and fit the mount and cross member up to the car and all the bolt holes lined up so I just bolted it all up and called it a night.
Old 01-11-2012, 11:38 PM   #246
matthew0029
Member#: 238794
http://forums.nasioc.com/forums/show...seals+stubs+06
matthew0029 is offline   Reply With Quote
Old 01-12-2012, 01:20 AM   #247
02RexWI
Member#: 165141
I'm saying that you can use the 5MT mount and crossmember with either transmission without a problem, but if you try to put a 6MT mount on a 5MT crossmember it won't work.
Old 01-12-2012, 10:17 AM   #248
coyote_94yj
Member#: 289875
2005 Impreza WRX
Ahh. Gotcha. Makes sense.
Old 01-12-2012, 02:36 PM   #249
MIGUELE GRANVILLE
Member#: 306694
Default gc8
im driving a 97 subaru gc8
the car is running a 02 6speed manual box
can i install the 06-07 6speed box?
someone said it cant work because of an electronic feature on the 06-07 box
just need to know please
MIGUELE GRANVILLE is offline   Reply With Quote
Old 01-12-2012, 03:02 PM   #250
02RexWI
Member#: 165141
The rear differential will likely need to be changed as the ratio's are different.
Also, the front axle shafts will likely be different, but there are ways around that.
You can run a DCCD transmission without a controller, but the center differential will default to full rear bias. Other than that it should work without a problem.
How to make DCCD work on a 6MT swap into a WRX (or other non-STi) TROLL Transmission (AT/MT) & Driveline 45 01-23-2011 05:32 PM
NEED HELP!!! - 08 sti clutch fork doesnt work with 08 sti trans swap into 02 wrx STiGuy23 Transmission (AT/MT) & Driveline 4 04-09-2010 01:03 AM
04 JDM sti 6MT swap into 06 wrx lagodcm Transmission (AT/MT) & Driveline 20 04-06-2009 11:46 AM
2005 6MT swapped into 2006 WRX Team Scream Subaru Conversions 4 11-15-2008 09:40 PM
Questions on 6mt swap into 02 wrx shadymilkman129 Transmission (AT/MT) & Driveline 9 08-18-2006 11:46 AM
