Old 03-07-2008, 10:24 PM   #51
WRX-17
Member#: 98725
05 WRX
to answer your PM questions:
1) The wiring plugs are different because the sti has 2 more wires for the dccd resulting in a 6pin plug vs the wrxs 4pin. if you are looking at the female plug on the tranny the 2 pins on the right side are for the dccd the other 4 are in the same order. I had the male sti plug so i just wired that into my wrx's harness so it was easy. You can drive the tranny without it plugged in, you will just get a CEL because there is no communication but you'll be fine. Just get it wired up sometime.
2) The tranny is a tight fit but it fits no problem because the sti and wrx bodys are the same and the tranny hump is the same size.
3) It is easy to put a jack on the tranny without the crossmember on but then you can't secure it first and then let down the jack once you have it in place. The crossmember is kinda in the way of the balancing point of the tranny which makes it a pain. I would say it would be best to do it with the crossmember on, but you can do it with it off if you have a someone strong friend that is willing to lay under there and hold up the end of the tranny after its fitted to the motor.
Oh and don't forget to put in the 6mt clutch fork before its too late. and if it looks lined up and doesnt want to slide on, slide in the driveshaft and put it in the end and twist to line up the splines. and before its all the way install the shifter linkage otherwise you cant. Good luck!
WRX-17 is offline   Reply With Quote
Old 03-15-2008, 08:27 PM   #52
xreign
Member#: 123859
06 STI 330hp/357lb
OPTION # 3 Trade in your wrx bend over and administer lube for new monthly payment haha i however will be taking option 1
xreign is offline   Reply With Quote
Old 03-16-2008, 01:08 PM   #53
Tha Shocker!
Member#: 171455
great info here!
Tha Shocker! is offline   Reply With Quote
Old 03-16-2008, 09:19 PM   #54
Rexer06
Member#: 125065
2006 WRX
noob here on STi transmission and trying to digest all the info i've found in this forum. thinking of swapping a STi trans into my 06 WRX. a few qns:
1. which year and make (JDM/USDM/EDM) of STi trans is considered the strongest?
2. which year and make would be best for daily driving?
3. which year and make would be best for track?
4. is worthwhile to do STi trans without the DCCD? would it be a day and night difference without the DCCD?
Rexer06 is offline   Reply With Quote
Old 03-17-2008, 04:28 AM   #55
fusionchicken
Member#: 123777
definitely stay away from 04-05 USDM 6spds, apparently 5th gear synchro failure is pretty common. my 05 6spd has a grinding 5th gear that pisses me off.
06 got carbon coned synchro's for IIRC 5th and 6th gear synchro's so they dont have that issue anymore. 07 6spd has a longer 4th gear to reduce the gap that existed between 4th and 5th gear on the 04-05 tranny's, which some thought to be the cause of common pre-mature 5th gear synchro failure.
JDM 6th gear is real short and your rpm on the highway will be pretty high. on the track though the shorter 5th and 6th would help you in acceleration...so it's your call.
i've been driving without DCCD on my 6spd but i've never driven it with DCCD so i can't comment on that one...good luck.
fusionchicken is offline   Reply With Quote
Old 03-17-2008, 11:42 PM   #56
Damien02WRX
Member#: 107492
2002 Impreza WRX
World Rally Blue
Question on the driveshaft and diff yoke. If I am using an STI driveshaft and an R180 can I reuse the bolts from my 5MT that hold the two together, are they the same as the STI?
Damien02WRX is offline   Reply With Quote
Old 03-18-2008, 01:59 AM   #57
2gsxtasy
Member#: 130249
2003 Evo VIII
Blue By You
From what I recall you can... the main thing I've seen that isn't noted is that the wrx flywheel has 6 bolts the sti has 9, so if you're switching clutches you need a few extra bolts from the dealer
2gsxtasy is offline   Reply With Quote
Old 03-19-2008, 12:31 PM   #58
Damien02WRX
Member#: 107492
2002 Impreza WRX
World Rally Blue
I'm not referring to the bolts for the flywheel, the bolts that hold the driveshaft to rear diff yoke.
Old 03-19-2008, 12:33 PM   #59
2gsxtasy
Member#: 130249
2003 Evo VIII
Blue By You
right.. sorry I was a little unclear... from what I remember I used the wrx driveshaft bolts.
Old 03-22-2008, 07:26 PM   #60
Damien02WRX
Member#: 107492
2002 Impreza WRX
World Rally Blue
Can you re-use the 5MT crossmember on the 6-speed? Is the 6-speed crossmember the same as the 5MT one?
Old 03-22-2008, 09:09 PM   #61
WRX-17
Member#: 98725
05 WRX
sorry guys i was gone for spring break for a week so now i can respond. heres responses in order...
- i drove around for a while without a DCCD and my brother has been for probably 6 months now. I have Spiider's controller and just driving around the difference is not apparent at all but without one there is more rear biased so you can definitely get the rear to slide out easier. That also means less lifespan of your R160 with more power going to the rear (that is if you are keeping the R160).
-Just to clear up the flywheel comment, i talked about that in post #24. yes u need 3 more bolts if u are using an sti flywheel, clutch and pressure plate.
-yes you can use the wrx driveshaft bolts no problem.
-yes the crossmembers are interchangeable. the sti one might be a little stronger though because it is boxed instead of just one piece but i know for a fact that you can use the 5MT crossmember.
Old 03-30-2008, 09:15 AM   #62
ebanks
Member#: 161469
Are there any specific shops that offer this swap and have a good reputation for getting it right? I don't have the time/space/desire to do this myself and would love to hear from people who have had a shop do the swap for them to see if they were satisfied.
Thanks!
ebanks is offline   Reply With Quote
Old 04-01-2008, 01:02 PM   #63
David L.
Member#: 130632
2002 Z28 35th Ann.
Pewter
I am confused too. I am looking into doing a 6mt swap from an 06 sti to 06 wrx. Not exatly sure what I need on top of the tranny either. From my understanding I need:
06 Sti rear diff, clutch, flywheel, axles to do this swap, drive shaft.
What is the ring and pinion thing?
David L. is offline   Reply With Quote
Old 04-01-2008, 04:20 PM   #64
WRX-17
Member#: 98725
05 WRX
no offense but if u dont know what a ring and pinion is then u shouldnt be tackling this swap
Old 04-01-2008, 05:48 PM   #65
David L.
Member#: 130632
2002 Z28 35th Ann.
Pewter
I have a master mechanic that I work with on stuff like this. I learn as I go...
Old 04-06-2008, 09:49 PM   #66
Damien02WRX
Member#: 107492
2002 Impreza WRX
World Rally Blue
One more question: Swapping a 2004 STI 6-speed into a 2002 WRX, will the front female STI axles slide right into my front hubs with no issues or are they a different spline count or larger?
Old 04-06-2008, 10:18 PM   #67
WRX-17
Member#: 98725
05 WRX
that setup should work no problem. pretty simple
Old 04-13-2008, 06:11 AM   #68
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
I bought an 04 sti six speed. Hasnt arrived yet, but I have an 07 WRX. My list of parts needed for the install
Trans
Axles(if it does have the stubs)
Driveshaft from automatic, or modify sti
3.9 r&p
6mt shift linkage
I've read that I dont need the crossmember/tranny mount because they are the same.
Spiider DCCD Contr.
All sound right?
Dubstar112 is offline   Reply With Quote
Old 04-13-2008, 11:28 AM   #69
bajozzy
Member#: 137556
2011 STI Sedan
Also , if you already have an STI driveshaft and your using the WRX R160 you can get a STI companion flange to bolt onto your R160 and the STI driveshaft will bolt up to it with out having to drill out anything. Seems like a stronger option than using the auto driveshaft.
bajozzy is offline   Reply With Quote
Old 04-21-2008, 05:23 PM   #70
jcovey2.5
Member#: 126195
05 CGM WRXTi
Wagon , 95 Red SVX L
can anyone tell me if an 07 STi stater is any different from an 04 STi starter????
jcovey2.5 is offline   Reply With Quote
Old 04-22-2008, 12:04 AM   #71
CR22
Member#: 167470
2005 Subaru
Thanks!
+876382
Still shopping for a Subaru but I don't feel like I should be looking into an STI if this swap comes out cheaper using a 2005-2006 WRX
CR22 is offline   Reply With Quote
Old 04-22-2008, 12:39 AM   #72
WRX-17
Member#: 98725
05 WRX
trust me...an STi is WAY worth it. the only thing i would possibly do instead of an sti if i was to do it again would be to buy a totalled sti and swap all the parts into a GC
Old 04-25-2008, 11:57 PM   #73
Damien02WRX
Member#: 107492
2002 Impreza WRX
World Rally Blue
Exactly which wiring do I need to swap over from my 02 WRX 5-speed to my late model 2004 STI 6-speed? I tried to plug my 5-speed speedo sensor harness into the 6-speed speedo sensor and it will not work, do I need to swap my 5-speed sensor over? What about the harness from the 2 round plugs off the 5-speed, do I just plug that harness into the round plugs on the 6-speed? Please help.
Old 04-28-2008, 01:11 PM   #74
GeneralTJI
Member#: 152680
Ok... but what exactly has to be drilled to use the STi DS??? haven't seen this explained in much detail.....
...and where do you get this flange?
GeneralTJI is offline   Reply With Quote
Old 04-28-2008, 05:18 PM   #75
bajozzy
Member#: 137556
2011 STI Sedan
You buy the STI companion flange from your dealer or subaru genuine parts dot com from the OEM catalog. You take the WRX companion flange off your R160 and replace the seal, then you put on the STI flange on your WRX R160 diff (fits perfect) and you wont have to drill anything. Also replace the side seals on your diff while your at it. This is what I did and it worked perfectly and in my opinion is the only logical option if you want to use the STI driveshaft in your swap. I love my 6 speed best mod by a mile so far.
How to make DCCD work on a 6MT swap into a WRX (or other non-STi) TROLL Transmission (AT/MT) & Driveline 45 01-23-2011 05:32 PM
NEED HELP!!! - 08 sti clutch fork doesnt work with 08 sti trans swap into 02 wrx STiGuy23 Transmission (AT/MT) & Driveline 4 04-09-2010 01:03 AM
04 JDM sti 6MT swap into 06 wrx lagodcm Transmission (AT/MT) & Driveline 20 04-06-2009 11:46 AM
2005 6MT swapped into 2006 WRX Team Scream Subaru Conversions 4 11-15-2008 09:40 PM
Questions on 6mt swap into 02 wrx shadymilkman129 Transmission (AT/MT) & Driveline 9 08-18-2006 11:46 AM
