Welcome to the North American Subaru Impreza Owners Club Sunday March 29, 2015
Old 12-27-2009, 06:47 PM   #176
srREXed
Member#: 72234
2004 WRX SRR
EJ257-35R-6MT
to remove the stubs id recommend some BIG channel locks. If you cant yank them out with the channel locks, which you should be able to, get a female axle and pop in the lock pin thru the hole in the axle and stub and use a prybar... It shouldnt be too much trouble. For your diff, id just order new seals...
srREXed is offline   Reply With Quote
Old 12-27-2009, 07:03 PM   #177
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
do you know how to take them out? heard i have to take apart the side plates in order to. does anyone know the part #s
Old 12-27-2009, 09:35 PM   #178
srREXed
Member#: 72234
2004 WRX SRR
EJ257-35R-6MT
never had to do rear end seals but im sure if you pull the axles and get in there its simple stuff... When are you putting your swap together??
Old 12-28-2009, 11:20 AM   #179
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
Just got home from Subaru. Bought the (2) front axle seals. One superceeds so it was a different part #. And bought one rear axle seal. Luckily they had them in stock and was able to walk away with them in hand. :0) As soon as i get these little quirks worked out im dropping off the parts at Synaptic3 in NH and they'll be taking it from there. thanks srREXed for all your help!
Old 12-28-2009, 02:07 PM   #180
srREXed
Member#: 72234
2004 WRX SRR
EJ257-35R-6MT
you got it buddy. Hope you get to drive your setup before the snow is gone!
Old 12-28-2009, 02:26 PM   #181
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
ahh, i know i wont and to be honest i dont mind. this will be my first winter without my suby :-( and im only glad because all my new parts wont take the abuse of the stupid salt everywhere.
just got finished polishing my controls arms....hmm they looks so good now :0)
Old 12-29-2009, 08:27 PM   #182
BlueHeavenWRX
Member#: 189537
2002 WRX Sedan & Wag
Blue Sedan, Silver Wagon
Would 04 STi front hubs fit into 02 WRX front knuckles? Or would they need some machining to fit?
BlueHeavenWRX is offline   Reply With Quote
Old 12-29-2009, 11:17 PM   #183
srREXed
Member#: 72234
2004 WRX SRR
EJ257-35R-6MT
They are not matched... Machining? Ehh, why not make it fit correctly. What are you trying to accomplish?
Old 12-30-2009, 09:06 PM   #184
BlueHeavenWRX
Member#: 189537
I'm not trying to accomplish anything. I'm selling a pair of brand new 04 STi front hubs, and this guy asked in my FS thread if they would fit 02 WRX front axles. I told him it wasn't so much the axles he had to worry about, but the STi hubs had to fit the WRX knuckles, and I didn't think they would fit without machining or something.
Then some other guy posts in my FS thread, that they would fit, and I don't think they do.
So this is why I'm asking the question. I'm pretty sure they won't fit, but I need verification from a veteran here.
Old 12-31-2009, 03:47 AM   #185
srREXed
Member#: 72234
2004 WRX SRR
EJ257-35R-6MT
It doesnt say veteran next to my name but from experience, sti knuckles, spindles etc. are not interchangeable with the wrx/imprezas... I tried to put together an alternative to r180 swapping and come to find out dss axles would make it work but theyre a pretty penny. That said, i tried to fit the sti inner hardware with the wrx outer hardware and it wouldnt fit without machine work. That of which is a bit pricey if you dont have access to some professoinal grade tools... Labor rates of 80 plus an hour. And 1.5 hours of machine work for each side. To qc the answer, you should check the suspension topics and see if anyone has done it?
Old 01-02-2010, 02:00 PM   #186
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
with the stubs sticking out on my trans i cant figure out how to take them out. there isnt any good way to get into it. just a VERY tiny hole. ANY IDEAS?
Old 01-02-2010, 09:05 PM   #187
srREXed
Member#: 72234
2004 WRX SRR
EJ257-35R-6MT
put a female axle on the stub. Put the little lock pin in the little hole. Then take a prybar and pry them out. Easier method for strong people... Large channel locks and a fat hammer... There isnt any other way to do it.
Old 01-03-2010, 10:09 AM   #188
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
ok sounds good. i just wont be able to do it myself because my female axles (which im not using) are still in my car at the shop :0(
Old 01-03-2010, 12:51 PM   #189
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Just post up and see if anyone on you local forum has an old/busted/whatever female axle you can borrow. If you were local to me, I'd let you borrow one of the 4 I have sitting around.
But maybe you answered this: why not keep the female axles? Swapping the seals isn't hard, but there's a good chance you'll mess something up and she'll leak like crazy.
Old 01-03-2010, 01:38 PM   #190
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
because my (female) axles are 2.5rs' and the axles im going to use (males) are STi. but thanks and the idea of posting in my region
Old 01-04-2010, 06:35 PM   #191
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
crystalhelix is offline   Reply With Quote
Old 01-11-2010, 10:25 AM   #192
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
after trying to yank out the stubs, when i pull, it seems to either hit something on the inside or is stuck. does that sounds right? i dont want to pull to hard and break something on the inside. I want to be as careful as possible BUT i need to get them out. ahhh i dont know what to do BUT i know i dont want to have to take the trans apart.
Old 01-11-2010, 04:40 PM   #193
srREXed
Member#: 72234
2004 WRX SRR
EJ257-35R-6MT
its the same as pulling male axles out of a female tranny. The clip on the end is whats hitting. You need to pull hard enough to compress the clip and the axle will pop out. Trust sometimes its tough but its the ONLY way to do it. Its the same in many other cars as well.
Old 01-11-2010, 05:12 PM   #194
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
ok thanks. just dropped everything but the transmission off at the builders today, they will finish it off. quick question: do the rear axles need circlips? i just noticed when dropping them off, they dont have any, just the fronts
Old 01-11-2010, 07:04 PM   #195
srREXed
Member#: 72234
2004 WRX SRR
EJ257-35R-6MT
far as ive seen clips for the rear tend to be retained in the diff and the axles clip in to it that way...
Old 01-11-2010, 07:17 PM   #196
WRX-17
Member#: 98725
05 WRX
yes the rear axles need circlips...and unless they stayed inside the diff u need to put them on. they arent expensive and youre supposed to replace those anyway
WRX-17 is offline   Reply With Quote
Old 01-11-2010, 08:32 PM   #197
Lettuce
Member#: 209881
04 WRX
I have a 2004 wrx with a 2006 6 speed. I can get into gear while the car is off, but while running it doesn't let me. Using the 6mt clutch fork with a 5mt clutch, is this my problem?
Edit:
nevermind, seems to be the clip holding in the throw out bearing.
Lettuce is offline   Reply With Quote
Old 01-19-2010, 12:51 PM   #198
subietumbler
Member#: 109121
2002 Impreza WRX
WRB-world rally blue
If I go with option #1 would I be able to re-use all 4 axles, as long as I keep the same diff in the car? I have an 02 wrx and was thinking of getting a 06-07 sti trans.
subietumbler is offline   Reply With Quote
Old 01-19-2010, 01:53 PM   #199
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
Ok I have 2 options as I get ready for this swap.
Been reading and digesting several threads on the subject.
O3 wrx.
Option 1 2004 STI 6mt
-R160 Regeared
-6 speed shifter and assembly
-Crossmember and Mount
-DCCD controller
-6-speed clutch fork and slave cylinder?
-STI Driveshaft and Flange
Option 2 2005 STI 6mt
-R160 Regeared
-DCCD controller
-2005 WRX front axles OR 2004 STI front axles OR re-use my current W/Stubs
This sound accurate?
The Phenx is offline   Reply With Quote
Old 01-19-2010, 02:33 PM   #200
njk8010
Member#: 109813
2005 WRX STI
CGM (Subaru #3)
O3 wrx.
-R160 Regeared
-DCCD controller
-R160 Regeared
-DCCD controller
- You'll have to use the 6MT's clutch fork
- Your WRX's slave cylinder can be re-used on the 6MT
- You can re-use your WRX's front axle but will need the stubs/oil seal/circlip IF the 6MT is "stubless".
njk8010 is online now   Reply With Quote
How to make DCCD work on a 6MT swap into a WRX (or other non-STi) Wrinkleboi Transmission (AT/MT) & Driveline 45 01-23-2011 05:32 PM
NEED HELP!!! - 08 sti clutch fork doesnt work with 08 sti trans swap into 02 wrx STiGuy23 Transmission (AT/MT) & Driveline 4 04-09-2010 01:03 AM
04 JDM sti 6MT swap into 06 wrx lagodcm Transmission (AT/MT) & Driveline 20 04-06-2009 11:46 AM
2005 6MT swapped into 2006 WRX Team Scream Subaru Conversions 4 11-15-2008 09:40 PM
Questions on 6mt swap into 02 wrx shadymilkman129 Transmission (AT/MT) & Driveline 9 08-18-2006 11:46 AM
