Old 12-22-2007, 07:46 PM   #1
tsukuba speed
Member#: 167319
2002 impreza wrx
white
Default engine hesitates at high rpm
i noticed while passing someone on the freeway. i thought it was the fuel cut, but then i just tried it again. around 5500 rpm at full throttle it bogs in and out like crazy. ive asked around, some people said my turbos bad but idk. i am a new owner and new to subaru so any comments would be great.
tsukuba speed is offline   Reply With Quote
Old 12-22-2007, 08:19 PM   #2
Haelan
Member#: 151045
2013 Subaru STI
CBP
Do you have a boost gauge? If so, post some readings.
People tend to have boost oscillations in the upper gears under high engine load.
Haelan is offline   Reply With Quote
Old 12-22-2007, 08:31 PM   #3
Bike Psyco
Member#: 166159
2002 Wrx wagon
black
is it a modifyed car? if the ecu detects knock, It will pull timing, and it can almost feel like hesitation
Bike Psyco is offline   Reply With Quote
Old 12-22-2007, 11:22 PM   #4
tsukuba speed
Member#: 167319
2002 impreza wrx
white
i just bought it about 3 weeks ago the only mod i can see is a catback. i just got a boost gauge but havent had time to put it in. ill give some readings when i find out. but the car runs totally fine and pulls hard till about that rpm.
Old 12-23-2007, 02:20 AM   #5
Haelan
Member#: 151045
2013 Subaru STI
CBP
Find some empty highway and lay into it in 4th or 5th gear. See if it bogs in and out multiple times in either gear before redline.
If you're new to Subaru's these can be your best troubleshooting friend: http://www.tactrix.com/product_info.php?products_id=31
It's an OBDII-to-USB cable. Using open source software called Enginuity, you can log multiple sensors from your car in aid of troubleshooting. Very handy. Consider looking into it.
Old 12-23-2007, 04:50 PM   #6
tsukuba speed
Member#: 167319
2002 impreza wrx
white
yeah it will go in and out a couple times.
Old 12-23-2007, 06:27 PM   #7
Haelan
Member#: 151045
2013 Subaru STI
CBP
Probably boost oscillations then. They tend to get worse when the weather gets colder. Before you make any adjustments I'd recommend you hook up your boost gauge or a laptop to monitor your manifold pressure just be certain and post your results.
Old 12-24-2007, 02:05 AM   #8
tsukuba speed
Member#: 167319
2002 impreza wrx
white
yeah its been cold. do you have a location that you would recommend me to install the boost guage too. its going to be located where the clock is.
and sorry for all the questions im new to turbo cars.
Old 12-24-2007, 02:11 AM   #9
Haelan
Member#: 151045
2013 Subaru STI
CBP
You mean where to splice into the vaccum line? Mine is spliced in near the bypass valve nipple with a 'T' fitting. Runs through the firewall up to the steering column where my gauge is mounted.
Old 12-24-2007, 06:36 AM   #10
noktrnl23
Member#: 77235
2003 WRX sedan
MBP
I had this same problem, which got progressively worse. After spending 2 weeks going over the entire vacuum and turbo system, it turned out to be a combo of dying fuel pump and dirty in tank filter (the sock on the pump). Hope this helps. -Jason
noktrnl23 is offline   Reply With Quote
Engine "stutters" at high rpm and after corners? Help please masterpickle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 09-03-2008 03:57 PM
2.2l Engine whistle at high RPM boyleia1 Normally Aspirated Powertrain 11 10-24-2007 05:37 PM
chek engine light at high rpm bigislandracing Off-Topic 18 07-19-2007 08:22 PM
Engine sputter at high RPM? kenithzs Normally Aspirated Powertrain 4 06-29-2006 07:40 PM
Hesitation at high rpms w/ turbo. Tim Prudence Technical Forum Archive 5 08-07-2000 05:19 PM
