Old 12-23-2007, 02:01 AM   #1
WhiteTurbo13
Member#: 134971
2006 Limited WRX
Subaru Stars Tilt The Headlights Vertically
Hey i was wondering if it is possible to maybe have the lights hit higher up.. Just installed the Hid Kit looks amazing with the cut off.. but i feel that it is to low.. i dont want to blind anybody but, i would like to adjust the headlamps a little. Thanks in Advance
WhiteTurbo13 is offline   Reply With Quote
Old 12-23-2007, 07:49 AM   #2
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
Look in the owner's manual. There's an adjustment nut on the back of each headlight.
RP31 is offline   Reply With Quote
Old 12-23-2007, 08:04 AM   #3
Zspectrum
Member#: 152933
CT9A
TB
it tells you to take it to the dealer, my lights are low as hell.
Zspectrum is offline   Reply With Quote
Old 12-23-2007, 08:06 AM   #4
RP31
Member#: 123574
CGM STi
WTF? When did they do that?!
Well, at least on mine, get out an allen wrench that fits into the white nut on the back of the headlight, then start turning. Although I can't remember which way to turn if you want to bring the lights up... I did it so long ago.
Old 12-23-2007, 08:14 AM   #5
RP31
Member#: 123574
CGM STi
Edit: I'm we todd did.
It's not in the owner's manual... I have the service manual and that's where it is.
Old 12-23-2007, 01:10 PM   #6
WhiteTurbo13
Member#: 134971
2006 Limited WRX
ok so the only way to do it is.. mess with it . thanks for the advice..
Old 12-23-2007, 01:48 PM   #7
bluegrasswrx
Member#: 147339
06 WRX TR WRB
20g fmic ewg
Shouldn't there be a philips head screw that fits into the leveler that let's you just screw it up and down? I have 06 sti headlights on my 06 TR and they have it. Although my stock headlights didn't. Maybe all TRs don't have the screw. But if you do have the screw then it's a piece of cake. And I think it's clockwise to raise IIRC.
bluegrasswrx is offline   Reply With Quote
Old 12-23-2007, 10:58 PM   #8
WhiteFox
Member#: 117606
2005 FXT
Projectors always seem low if you are used to driving with halogen housing lights. They sound like they are adjusted just fine. You don't have any reason to change it from where it is set.
Normally your lights should shine as high as the side mirrors on the average car, any higher and you'll blind people.
WhiteFox is offline   Reply With Quote
Old 12-24-2007, 02:37 AM   #9
kirkeemonster
Member#: 113721
WRBP
isn't there a legit way to measure them? I can't remmeber if it's get on a flat spot, aim it to a wall, measure 30 feet away form the wall and it's like 12.5feet high or somethin like that (where the cut off should be) or somethin like that, can't remember exact measurements
kirkeemonster is offline   Reply With Quote
Old 12-24-2007, 05:46 AM   #10
NaturallyAspirated
Member#: 64792
2001 Impreza L
BRP
Check out this site for how to PROPERLY aim your lights.
http://www.danielsternlighting.com/tech/aim/aim.html
NaturallyAspirated is offline   Reply With Quote
Old 12-24-2007, 09:31 AM   #11
Xprezs
Member#: 139714
2006 WRX Limited
Crystal Gray Metallic
I've done this numerous of times. Open your hood, in the front region right behind the hid bulb (but inside the engine bay) you should see a very small hex looking bolt just sticking out of the back of the headlight fixture. I believe it is an 8mm. I used the 8mm and a small ratchet. Hope this helps.
- Matt
If you have any further questions just PM me.
Xprezs is offline   Reply With Quote
Old 12-24-2007, 11:57 AM   #12
05wrxmatt
Member#: 87169
2007 STI Limited
That's just for the STi.
05wrxmatt is offline   Reply With Quote
Old 12-24-2007, 01:25 PM   #13
Mechie3
Member#: 120152
Ditto. The bolt is horizontal (parallel to the ground). On the passenger side you will probably need to remove the intake ram/horn to access the bolt. On the driver side you can pop the upper portion of the fluid reservoir off and get to the bolt that way.
Mechie3 is offline   Reply With Quote
Old 01-05-2008, 03:40 PM   #14
WhiteTurbo13
Member#: 134971
2006 Limited WRX
Thanks guys aweseom thread.
I really Appreciate all the info.
Old 01-06-2008, 12:41 AM   #15
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...from the '06 fsm
Old 05-03-2009, 10:36 PM   #16
gsk3rd
Member#: 155825
07 WRX TR
WR Blue
thank god i found this. I bought my 07 wrx tr from a guy who painted the headlights black for me. Awesome. but i have noticed that my beam pattern is way to low. found the screw and will adjust tomorrow. thxs.
gsk3rd is offline   Reply With Quote
Old 05-04-2009, 12:48 AM   #17
wrx07LT
Member#: 160434
2007 WRX Limited
CGM
Thanks guys! The crap SilverStar bulbs I put it blew within 5 months. When I put in new Subaru bulbs, I noticed they were aimed much lower.
wrx07LT is offline   Reply With Quote
Old 05-04-2009, 01:44 AM   #18
bcWRX-02
Member#: 181780
2002 WRX Sedan PSM
'01 CBR 600 F4i
Nice. do an improper HID retrofit, then aim them up some more just incase you aren't pissing off oncoming drivers enough already.
bcWRX-02 is offline   Reply With Quote
i got the peices between the headlight and the grill for sale. jeremywrx15554 Exterior/Styling 21 02-27-2009 07:28 PM
I want to be able to turn the headlights on without the key in the ignition bomber991 Electrical & Lighting 4 10-22-2008 11:40 AM
align headlights vertically? OMAHA2.5RS Service & Maintenance 0 07-19-2003 04:51 AM
I found out how to reaim headlights...vertically ATX25RS Interior & Exterior Modification 0 09-09-2001 10:02 PM
