Old 12-23-2007, 10:23 AM   #1
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Default T3/T04S to GT37R - Projected Gains?
Thinking of swapping out my T3/T04S for a Garrett GT37R (.82 hotside.) My current mods are as follows:
Weisco Coated Pistons
Eagles Rods
ARP Head Studs
Calico Coated Engine Bearings
Ultimate Racing T3/T04S Turbo (.82 a/r)
Ultimate Racing 1000cc Top-Feed Injectors
Ultimate Racing Fuel Rails
Dual In-Tank Whine-bro 255 LPH Fuel Pumps
Fuel Pressure Regulator
Ultimate Racing 3" Down Pipe
Ultimate Racing Up Pipe
TiAL 44mm Wastegate w/ Dump Tube
Perrin Semi-Equal Length Header (wrapped)
Invidia Turbo-Back Exhaust
Ultimate Racing Front-Mount Intercooler
Ultimate Racing Polished Intercooler Piping
TiAL Blow-Off Valve
Ultimate Racing Cold-Air Intake w/ MAF Housing
TurboXS DTEC 4 bar Pressure Sensor
TurboXS UTEC w/ Map Switch
TurboXS Manual Boost Controller
Exedy Twin-Plate Clutch
The car previously put down 431 WHP on 93 octane and 517 WHP on C16. What sort of numbers could be projected from swapping out the UR T3/T04S for the Garrett GT37R? Both are using .82 a/r hot sides, and I'm still running stock heads, cams, and valvetrain for the time being.
Update - The turbo has been offered to me for $900. I may be able to get him a little lower if I try. It's a GT37R with a .82 a/r hot side. You guys think it's worth it? How much power do you think it can put down?
Teh Legacy is offline   Reply With Quote
Old 12-23-2007, 10:24 AM   #2
norexyet
Member#: 39149
11 elantra
yea i said elantra
I could be wrong. But i thought the 37r seemed more suitable for cars with higher rev ranges. Do they make it in twin scroll applications?? If not why not go with a t/s 40r?
norexyet is offline   Reply With Quote
Old 12-23-2007, 10:29 AM   #3
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Half the reason for considering the 37R is because I can pick one up from a friend for VERY cheap. If I don't end up getting it, I'll be getting a FP3582HTA.
Old 12-23-2007, 11:30 AM   #4
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
If you end up making the swap I'd be willing to give you some cash plus my .63 housing for the .82 housing off the t3/t04s.
LiquidForce is offline   Reply With Quote
Old 12-23-2007, 12:37 PM   #5
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Sounds good.
Old 12-23-2007, 02:30 PM   #6
perrin247
Member#: 129369
2005 WRX STI
World Rally Blue
Im going to use the 37r on my car with the .82 as well. Evo's have been making great number with this turbo for a while, so i wanna see what the for extra displacement will do for it... my goal is 600whp and a mid 10 second pass with all the supporting mods.
perrin247 is offline   Reply With Quote
Old 12-23-2007, 02:31 PM   #7
spoolindc2
Member#: 72972
2003 WRX Stage 2 HKS
I think going to the 37r you will definitely pick up more power, but your whole power curve is gonna be shifted to the right since its going to be a bit laggier than a t3/t04s... With the 37r you will probably be breaking into the tens with your current setup being low 11's.... good luck with whatever you do let us know how it goes...
spoolindc2 is offline   Reply With Quote
Old 12-23-2007, 04:08 PM   #8
THE-95-STi
Member#: 113734
2oo3 Vdub 1.8T
Subaruless(MAIC4LIFE)
Meh I'd just get some Headwork and cams
THE-95-STi is offline   Reply With Quote
Old 12-24-2007, 12:02 AM   #9
STimo
Member#: 110273
450 whp 30R STI
[email protected]
Id skip the 37R and just go with a 40R if i were you and was going to upgrade, i've heard that 37R's lag about the same as a 40R and dont make as near much power..
STimo is offline   Reply With Quote
Old 12-24-2007, 12:22 AM   #10
nosmo
Member#: 53142
06' STI,02WRX,982.5
www.Flat4lv.com
Agreed!
nosmo is offline   Reply With Quote
Old 12-24-2007, 12:31 AM   #11
perrin247
Member#: 129369
2005 WRX STI
World Rally Blue
from what I understand on evos the lag is 300 to 500 rpms diffrent then 35r and the 37 will make well into the 600's with some c16, I want to see what it will do with a little more displacement.
Old 12-24-2007, 06:59 AM   #12
LiquidForce
Member#: 12811
2002 2.5l Wrx
I found this while looking around for .82 exhaust housings
http://www.ztechz.net/sitebuildercon.../gt-turbos.jpg
Old 12-24-2007, 07:11 AM   #13
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
what about sending the 37r to fp for the hta treatment?
Old 12-24-2007, 08:07 AM   #14
Teh Legacy
Member#: 9853
to keep your mouth
shut.
The only reason I'm even considering the 37R is because I'm picking it up at an incredible price.
Old 12-24-2007, 08:33 AM   #15
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
i second that!
blowbyu24 is offline   Reply With Quote
Old 12-24-2007, 09:07 AM   #16
LiquidForce
Member#: 12811
2002 2.5l Wrx
I say get the turbo. If it doesn't work for you just sell it.
Head work and cams is neither easy or cheap. I'd wait to see how the turbo performs as is before thinking about tearing a motor down for that kind of work.
edit: All of this is assuming the price is real cheap and it will just bolt up to your current setup. If it requires a new up and downpipe I wouldn't do it as it would no longer be **cheap**
Old 12-24-2007, 09:53 AM   #17
drewwrxrogers
Member#: 132574
04 Aspen White Sti
GT35r, axis motor,280cams
Def go with the 40R! The lag is indiffernt between the two but the 40R makes more power. But like mentioned above, a 35R and up size turbo is a high rev setup. Your going to want the room to use and play with the power. Get your valvetrain done. Also have your heads at least gone through. IMO I would def without a doubt get a set of cams. With your goal I would suggest going 280's! Good Luck!
drewwrxrogers is offline   Reply With Quote
Old 12-24-2007, 12:16 PM   #18
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
It is very easy to swap out a rotated turbo. Get it, and tune for it. If you don't like it, put the old one back on and set the tune back to where it is now.
TAPOUT is offline   Reply With Quote
Old 12-24-2007, 12:17 PM   #19
2004stiwrb
Member#: 70613
i'm @ the dragstrip
with over 600awhp!!!!!!!!
i've got some insite on the 35r .82 to a 35r 1.06 to a 37r 1.06 here you go. and by the way this is on my own car.
35r .82 35psi on c16
here is the comparison of my 37r with a 1.06 to the 35r i swapped back to but with a 1.06 instead of the .82 like last year. the problem with the 37r is that it never got to where i wanted it to be as far as boost wise. i even tried reving the motor out witch helped very little. the torque really sufferd because of the turbo spooling so late witch dropped me about 7 tenths in the 1/4. but with the 35r .82 to the 35r 1.06 they spooled the same witch is a plus to me. i'm changing a few things now to help with spool up and changing a few things to try and keep the boost up to 35-36 psi instead of it dropping off like you see in these dyno sheets. once i get everything straightend around i'd say it will be around 670whp and 600wtq.
2004stiwrb is offline   Reply With Quote
Old 12-24-2007, 12:24 PM   #20
StillBoostin
Member#: 46177
2002 WRB WRX
99 RSTi Coupe
If you go with the GT40R let your buddy know I would buy the 37r. Mine just craped out on me. Same thing as a T04R or PT63 with the big wheel. The turbo is great and the power is amazing. But if the twin scroll GT4088R spools the same as the GT37R then just get the GT4088R. Vibrant makes a twin scroll manifold that brandon at turbo xs could modify and use 2 waste gates. Little pricey but would be on sick set up.
Or could you just get the T4 divided housing. I have the T4 .96A/R housing and it is great. Go V-band down pipe.
James
PS head work is a must. Hi revs would make this a drivable car on the street. Start saving for that 6spd dog box cause your gonna break that 6spd right after you make 600+. If you don't then your lucky. But have that money set a side cause it is $$$$$.
StillBoostin is offline   Reply With Quote
Old 12-24-2007, 03:40 PM   #21
Md05STI
Member#: 76974
2005 CGM STI
10.03 @ 135
Is it the T3 or T4 version of the GT37r? If its the T3 and you can get it cheap id go for it. The 40r would be the better choice but you would have to change your up-pipe and downpipe to use it, so unless your looking to spend more money I'd just buy the 37r.
Md05STI is offline   Reply With Quote
Old 12-24-2007, 04:02 PM   #22
BuggeyEYED
Member#: 101691
97 Supra TT
SOLD - 35r bug/hawkeye
id say get the turbo, you already have ALL the supporting mods and strength for it, AND getting it at a good price..do it!
BuggeyEYED is offline   Reply With Quote
Old 12-25-2007, 12:30 AM   #23
PacmanGSX
Gone... But not forgotten
Member#: 113077
1999 2.5RS
Some Blue Color
Hey John....
Rumor is some guy at Andrewtech has a Gt4088R kit for sale.... ;-)
-Edwin
PacmanGSX is offline   Reply With Quote
Old 12-25-2007, 12:54 PM   #24
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Originally Posted by PacmanGSX View Post
Hey John....
-Edwin
What's that idiot selling it for? Give me a call bro.
Old 02-01-2008, 06:09 PM   #25
Teh Legacy
Member#: 9853
to keep your mouth
shut.
T3/t04s to twinscroll??? HELP! wrxdwpsti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-04-2008 01:15 PM
Ultimate Racing T3/T04E Turbo Kit and T3/T04S juanmedina Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-02-2008 09:44 AM
Is there any benefit in me switching from a T3/T04S to a GT35R? Teh Legacy Proven Power Bragging 71 05-17-2008 10:41 PM
T3/T04 turbine housing turbos drdeuce Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 07-28-2005 05:58 PM
T3/T04 psi and hp potencial DJIMPREZA Normally Aspirated with bolt-on Forced Induction Powertrain 10 01-08-2002 08:13 PM
