South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 12-23-2007, 03:09 PM   #1
mike91401
Member#: 86510
2010 Toyota Tacoma
Default P2102 Cel
Anyone had any experience with the P2102 CEL (Throttle Actuater Motor Control Circuit Low).
It's a 2005 STI (Cobb Stage 2 Mods)
Car was running great this morning... now it's not running so great. It starts and idles, but won't rev past about 1700 RPMS.
If possible, I'd like to try fixing it without having to have it towed somewhere to get worked on.
Any help is appreciated.... I've looked for any bad grounds and fried wires... but didn't find anything.
Thanks,
Mike
mike91401 is offline   Reply With Quote
Old 12-24-2007, 10:13 AM   #2
racingfish
Member#: 60976
1969 LGT
FATURBO
SELL it and get a new one.
racingfish is offline   Reply With Quote
Old 12-24-2007, 11:23 AM   #3
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
http://www.northursalia.com/modifica...C_Criteria.pdf
Search for your code in this pdf and see if it helps you at all. Seems your electronic control throttle relay is not getting power.
Smoby is offline   Reply With Quote
Old 12-25-2007, 09:47 PM   #4
mike91401
Member#: 86510
2010 Toyota Tacoma
thanks for the link!
I now have a few possiblities of the problem... We're hoping it's just the relay..... Of course Santa didn't bring me a new relay so I'll just have to wait for Avondale to get one in for me
Old 05-03-2008, 11:46 PM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Any additional info on the solution to p2102?
Old 05-05-2008, 11:14 AM   #6
racingfish
Member#: 60976
1969 LGT
FATURBO
its fixed.
Old 05-05-2008, 02:21 PM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
I hoped so but can you give any insight? I'm too plagued by this DTC.
Old 06-16-2011, 09:49 AM   #8
bmw325_num99
Member#: 228676
2002 WRX Wagon
FYI, in case anyone searches for this problem in the future. I recently had the same code and the symptom of low revving engine (1500-2000rpm only). The car would drive slowly even when floored but it would drive. It would also stutter slightly or shudder when idling. When I saw the check engine light and P2102 code thrown (the only code that came up) I replaced the car's battery. It worked!
Summary: Replace the car battery.
bmw325_num99 is offline   Reply With Quote
Old 06-16-2011, 06:55 PM   #9
DooDooPWR
Member#: 224088
04 WRX
Your lucky... I ended up having to put an ecm in mikes sti.
DooDooPWR is offline   Reply With Quote
Needs Advise for CEL code P2102 EAuto Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 12-07-2010 05:12 PM
P2102 Cel Para83 Service & Maintenance 0 07-23-2008 03:24 PM
P2102 Cel Para83 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 07-23-2008 03:07 PM
CEL codes P2100 & P2102 dream Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 05-03-2008 11:46 PM
P2102 (Throttle Actuator Control Motor Circuit Low) th1rd3y3 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 02-20-2006 04:49 PM
