Old 12-23-2007, 04:19 PM   #1
k22addict
Member#: 92561
Default just installed new rotors and pads
just installed new rotors and pads, i got about 10 feet down the road and hear scrapping...like my pads are grinding on my new rotors....is this normal? should i drive it off or is this a bigger issue i have to deal with?
k22addict is offline   Reply With Quote
Old 12-23-2007, 04:57 PM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
well something is grinding.
start by checking the backing plates to make sure they are not contacting the rotors.
Old 12-23-2007, 05:11 PM   #3
k22addict
Member#: 92561
awesome...will definitely look into it...also my calipers seem to not retract even with the brake pedal depressed...is it because i need to wait for my pads to wear down?
Old 03-10-2008, 01:44 PM   #4
Curifor
Member#: 128551
I just replaced my rear rotors, calipers, and pads at both wheels and have a similar grinding/scrapping metal on metal sound coming from both rear wheels.
I haven't had a look yet but hopefully it's just the backing plates rubbing against the dust guard or something basic that can be easily adjusted/fixed.
I also noticed before I took the car off the jackstands that the rear wheels with the lug nuts tight were hesitant to turn. Something is dragging, what is the most likely suspect? Backing plate, parking brake, something else?
Anyone else have this problem after replacing their brakes?
Curifor is offline   Reply With Quote
Old 03-10-2008, 02:04 PM   #5
salisburyv
Member#: 41863
2015 STI
Crystal Black Silica
wheel not wanting to turn... know it well... I'm my situation the right front caliper froze.
salisburyv is offline   Reply With Quote
Old 03-10-2008, 02:07 PM   #6
Garage Spec
Vendor
Member#: 133383
2004 Subaru GDB STI
Did you bed in the pads and break in the rotors correctly?
Garage Spec is offline   Reply With Quote
Old 03-10-2008, 05:13 PM   #7
Curifor
Member#: 128551
Nope, haven't got there yet. Dragging noise was too much to drive the car out of the driveway.
Old 03-10-2008, 06:12 PM   #8
Garage Spec
Vendor
Member#: 133383
2004 Subaru GDB STI
check the brake pistons and see if they move in and out freely.
Old 03-10-2008, 06:15 PM   #9
thrdeye
Member#: 24569
2011 Impreza WRX
Some rubbing/grinding is normal at first - full thickness pads and full thickness rotors will do that sometimes. If it is loud at all, you may have something outta whack. If the car stops fine, I would go bedding. But don't drive it until you're sure you've installed everything correctly.
thrdeye is offline   Reply With Quote
Installed new rotors and pads, but making sound while driving... gi2005 Brakes, Steering & Suspension 1 07-15-2008 04:46 AM
Got my new rotors and pads... Now where to install wanalaugh74 Mid Atlantic Impreza Club -- MAIC 16 01-12-2008 08:07 PM
installed new rotors and pads squeaking freshpl Brakes, Steering & Suspension 8 08-07-2007 08:03 PM
just installed new rotors and pads. now parking brake needs adjustment? Wagon Joe Brakes, Steering & Suspension 8 04-19-2005 02:31 PM
just installed crossdrilled rotors and brake pads STEALTH-WRX Brakes, Steering & Suspension 2 09-19-2001 10:39 AM
