Old 12-23-2007, 10:45 PM   #1
ASpec818
Member#: 37059
03 WRX
World Rally Blue
Default Stuck clutch pedal in cold weather?
I had something really wierd happen to me today. I was at Lake Tahoe in about 20 degree weather. I was stopping at a stoplight, shifting from second to neutral. When I was stopped, I let go of the clutch but it just stayed up there. Pushing it again would do nothing. I had to open my door, get out, and use my hands to pop it back out.
Does anyone know why this occured? I find this pretty scary and dangerous if my clutch would get stuck while moving during gearshifts.
ASpec818 is offline   Reply With Quote
Old 12-23-2007, 10:51 PM   #2
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
I have seen this happen when you get air in the line. Did it only happen that one time? Might also need to get under the dash and cleana nd relube the return spring
robbieshonda is offline   Reply With Quote
Old 12-23-2007, 11:19 PM   #3
ASpec818
Member#: 37059
03 WRX
World Rally Blue
Yep it only happened that one time. Kinda freaked me out a little after that.
Old 12-23-2007, 11:44 PM   #4
Kylar
Member#: 159215
2008 LGT Limited
Check your clutch fluid level. Your master or slave could be on the way out(leaking).
Kylar is offline   Reply With Quote
Old 12-26-2007, 08:30 PM   #5
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
that happened to me this morning. it was about 5 degrees out, but the pedal didn't stay on the floor, it just took about a second to come back up. with subsequent movements it got a little better.
Stuck Clutch Pedal MY98 ehime Forester Forum 4 08-10-2008 01:05 PM
Brake and Clutch Pedal Sticking in Cold Weather alexk243 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-31-2008 09:52 AM
Stuck Clutch Pedal MKXIII Transmission (AT/MT) & Driveline 6 02-25-2007 11:33 AM
('93-'01) Clutch "sticking" in cold weather Seeing StaRS Impreza Forum 11 02-11-2004 12:38 PM
Stiff brake and clutch feel in cold weather? banman Service & Maintenance 3 01-08-2004 03:37 AM
