Old 12-24-2007, 12:25 PM   #1
decaman
Member#: 73055
04 STi
Default Fused 12 volt ignition supply?
Hi, I'm looking for a convenient fused 12 volt ignition supply for wiring up my dual stage MBC. Don't worry, I'm going to install it right before my tune and let my tuner set it during my tune. I just want to know a good supply so I can plan for the install. Thanks!
decaman is offline   Reply With Quote
Old 12-24-2007, 01:59 PM   #2
danmezz
Member#: 126339
2003 WRX Wagon
I'm not sure what a MBC is so I don't know how many amps it draws... that aside, you could tap off the positive lead behind the cigarette lighter. Another option is to get a fuse tap that turns one fuse into two fuses. They run about $7 or so at auto parts stores and are really easy to install. You just take out a fuse from the panel, plug the thing in, and you have a free positive lead hanging there for the new device
danmezz is offline   Reply With Quote
Old 12-25-2007, 09:25 AM   #3
decaman
Member#: 73055
04 STi
Thanks Dan. Yeah a MBC is a manual boost controller. I have a dual stage and it runs off 12V. The instrustions told me wiring it to a fused ignition supply was mandatory.
Old 12-25-2007, 11:22 AM   #4
danmezz
Member#: 126339
2003 WRX Wagon
yea, either wiring method should be fine. I know the cigarette lighter in my 03 is wired with the ignition, so I'm assuming it's the same for an 04 also... only thing to look for if you do the fuse tap in the fuse box is to find a circuit that goes on and off with the car.
Old 01-01-2008, 03:21 PM   #5
decaman
Member#: 73055
04 STi
There is a 15Amp fuse in the engine bay fuse box called "Clock - Room". Would this be a good one to use with a fuse tap for the MBC? I'm pretty sure that this is a fused ignition source because the clock only turns on with the key, right?
Old 01-01-2008, 03:35 PM   #6
02redwagone
Member#: 87067
02 Old but tasty
SRP
Test probes are very cheap.
02redwagone is offline   Reply With Quote
Old 01-01-2008, 03:55 PM   #7
decaman
Member#: 73055
04 STi
Yeah, you are right. I actually have a probe already. I'll go out and test it.
I should have been more specific, though. My question was more along the lines of "Is it OK to tap into this circuit with an additional (albeit small) load? What stuff besides the clock runs through this fuse? I'm not sure what "room" means...
2010 WRX, 9500ci install to a switched 12-volt supply waroo Newbies & FAQs 2 04-17-2010 08:46 PM
Are optima car batteries 6 volt or 12 volt? edkwon Electrical & Lighting 6 02-09-2008 07:44 PM
Is everything coming off drive side fuse box 12 volt? triguy Electrical & Lighting 1 10-13-2007 08:19 PM
12-Volt Power Supply idiotkkid Off-Topic 30 08-23-2007 04:03 PM
Can you recharge a 12 volt motorcycle battery with a 12 volt car charger? Cjchaps Electrical & Lighting 3 07-01-2003 01:55 PM
