South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 12-24-2007, 09:29 PM   #1
02blkwagn19
Member#: 146496
02 WRX Wagon 2.1L
Built not bought. #0003
Default torn cv boot...yeah baby
well as the post states i tore a cv boot, it appears that it became a tad brittle being so close to my down pipe..im not quite sure how long it has been torn, atleast 2 days thought it was my clutch burning at first, then smoke began to billowing out of the hood and thought it was the pcv valve but when i went to replace it today i realized all the fluid was actucally grease form the passenger halfshaft outer cv boot...and so i have been reading up and most say at this point its almost best to buy a whole new link, so my question is where? im sure the dealer has them but they will more then likely want and arm and a possible leg. does something like you regular napa, checker, autozone, ect have it or do i a need a specialty shop?
2nd part of question: should i replace the driverside as well or just the one side?
merry christmas!!
02blkwagn19 is offline   Reply With Quote
Old 12-24-2007, 11:54 PM   #2
Kdub
Member#: 129501
1996 Eclipse GSX
Red
im guessing its the inner correct? i wouldnt trust autozone, id go to napa if youre trying to stay away from the dealer. the whole shaft itself should cost less than $150 and the boot assembly around $45-$55 dollars. id go with the shaft and save yourself the greasy trouble tearing apart the boot and re-packing it. theyre basically the same amount of labor.
and no you dont have to replace the other side.
Kdub is offline   Reply With Quote
Old 12-25-2007, 11:18 AM   #3
joebud
Member#: 55089
I'll bet the tripod bearing is still good. It's probably been open for only a short time and the grease is still good. If it's not making any noise there is no reason to replace the bearing just the boot.
Do your self a favor and get the inter boot kit from the dealer. They will fit better, maybe last longerare not that much more than aftermarket.
You will for sure have to protect the new one from the heat from your downpipe, either wrap your downpipe or protect it some other way.
joebud is offline   Reply With Quote
Old 12-25-2007, 11:30 AM   #4
gormonk
Member#: 98960
1978 brat (fo realz)
red
i see aftermarket ones leaking all the time
gormonk is offline   Reply With Quote
Old 12-25-2007, 01:52 PM   #5
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
The boot is pretty simple to replace, if you are mechanically inclined save yourself money and put on a new boot.
Smoby is offline   Reply With Quote
Old 12-25-2007, 02:02 PM   #6
MIKE DD
Member#: 106818
2003 Truck
My local mechanic got me a used one just replaced it for $160 total.
MIKE DD is offline   Reply With Quote
Old 12-26-2007, 02:15 AM   #7
ram95
Member#: 121051
08 8k RPM
Vtak HoNdUh
I tore mine and ordered a new one from Hodge subaru, a vendor on subaruforester.org, got grease and new clips all for 80 over nighted and had a shop replace the outter boot for 40 dollars in flag. Mine was only torn for 100 miles and didn't think I needed to replace everything
ram95 is offline   Reply With Quote
Old 12-26-2007, 02:17 AM   #8
nosmo
Member#: 53142
06' STI,02WRX,982.5
www.Flat4lv.com
with the right tools get a universal and do it yourself for 30$ and about 2 hours for both sides. If your over 70K miles may as well do inner and outer on both sides.
nosmo is offline   Reply With Quote
Old 12-26-2007, 02:18 AM   #9
mxpop
Member#: 103776
2006 STI
My 2006 Axle assy costs almost $500 from the dealer. The hardest part was remove/replace axle. Once it's off, the boot is an easy fix as long as internals are still OK.
How many miles?
mxpop is offline   Reply With Quote
Old 12-26-2007, 09:32 AM   #10
racingfish
Member#: 60976
1969 LGT
FATURBO
parts and grease kit should cost around $40 at any dealer... labor is 2 hours flat rate. so depending on which dealership you get it done at your looking at anywhere from $250-$290 for the job including tax.
i hear you can buy reman axles for under $100 or something crazy like that. the passenger side inner cv boot is the most common boot too go. you can usually tell its a cv boot when you can smell the "sweet burning rubber" smell.
racingfish is offline   Reply With Quote
Old 12-26-2007, 01:18 PM   #11
nosmo
Member#: 53142
06' STI,02WRX,982.5
www.Flat4lv.com
Gotta love doing other peoples Up or Dp and seeing the mess, telling them about it, and seeing the same thing when the car is at your house a half a year later. Just with dirt crusted to the oil everywhere.
Old 12-26-2007, 02:59 PM   #12
racingfish
Member#: 60976
1969 LGT
FATURBO
lemme guess... subykid?
Old 12-27-2007, 11:13 AM   #13
nosmo
Member#: 53142
06' STI,02WRX,982.5
www.Flat4lv.com
No, just in general... Subykid seems to take good care of his schnitzle. I thought...
Old 12-27-2007, 11:21 AM   #14
MrMcCrackin
Member#: 89202
I'm # 1 when it
comes to # 2
yo that sucks!
i got new axles from NAPA for $66
no mess - just replace
MrMcCrackin is offline   Reply With Quote
Old 12-29-2007, 01:07 PM   #15
02blkwagn19
Member#: 146496
02 WRX Wagon 2.1L
sorry it took me so long to get back to this thread im also in the middle of moving so its been chaotic. but i did end up just buying the boot repair kit from the dealer for something like $50. and did the job in like 2 or so hours. its very easy, but a bit messy. and everything seems to be working just fine, just gotta burn the extra crap off my up pipe heat shield. ha but i have been recently concerned with a loud whining noise that sounds like its coming from my snowboard rack but i think it might be something a bit more serious then that, like tranny or rear axels. so i need to further look into that. but thanks for all the advice guys. oh and i have 71,500 miles on the car
Old 12-31-2007, 09:43 AM   #16
racingfish
Member#: 60976
1969 LGT
FATURBO
gratz...
Old 12-31-2007, 01:13 PM   #17
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
That is why you where the rubber surgical gloves, mess slips right off
Old 03-04-2008, 02:18 PM   #18
AphexDouble
Member#: 96427
2010 Legacy 3.6R
Pearl White
anyone have instructions on how to remove the front axle assembly? My Cv boot ripped too and I just want to replace the axle.
AphexDouble is offline   Reply With Quote
Old 03-04-2008, 02:24 PM   #19
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
there's a thread in maintenanace section or something.
The fastest way I know is to remove one of the two bolts that hold the spindle to the strut, top one I think. Once you take the bolt out, the spring pushes the spindle all the way out.
bobturismo is offline   Reply With Quote
Old 03-04-2008, 02:55 PM   #20
mxpop
Member#: 103776
2006 STI
That will make you need a re-alignment. I prefer to undo the lower ball joint which allows the assy to swing out. I think undoing the sway helps too.
Then, the axle will just pop out with a little pry. It goes back in with a tap from a rubber mallet to compress the clip on the axle. I would hate to do it without a lift but it is do-able.
Old 03-04-2008, 06:50 PM   #21
gormonk
Member#: 98960
red
dont forget the pin holding the axle to the transmission if you have female axles. remove the nut on the axle holding it to the hub (1 1/4 socket) an impact helps with that part. then a punch and a hammer will allow you to push the axle out of the knuckle. after that you can remove the whole axle assembly. makes it much easier to do the cv boots.
Torn CV boot John2.5RS Legacy Forum 8 01-03-2013 07:40 PM
Torn CV boot.. where to get new one? Calsoldier Transmission (AT/MT) & Driveline 10 10-17-2004 10:59 AM
Torn CV Boot question Calsoldier Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-27-2004 04:29 PM
Torn CV Boot...difficult to DIY repair? thebusiness999 Transmission (AT/MT) & Driveline 13 04-15-2003 10:01 PM
torn CV boot RaceCarRiot Normally Aspirated Powertrain 5 09-18-2001 08:52 AM
