Old 01-29-2002, 11:24 PM   #1
NinNin
Member#: 9011
99 RS EJ20 -ECU
Post EJ20G Injectors
Anyone know what the 91 WRX EJ20G's injector size / flow rate is? Also, anyone know a source to get a performance injector for this engine? Its an odd side - spraying type... Thanks!
NinNin is offline   Reply With Quote
Old 01-30-2002, 02:21 AM   #2
Gerry
Member#: 1829
EJ20G injectors are 440cc side feed. I know this because I 2 EJ20G engines..If you want 550cc or bigger shoot me a e-mail...I can hook you up with a set...Gerry
Gerry is offline   Reply With Quote
Old 01-30-2002, 04:32 AM   #3
Happy
Member#: 12115
What colour are they ?? Not all injectors are 440cc.
Grey = 380cc
Yellow = 440cc
Also, we believe the Subaru injectors are flow rated "static", ie, 3bar wide open.
Happy.
Happy is offline   Reply With Quote
Old 01-30-2002, 11:21 AM   #4
NinNin
Member#: 9011
99 RS EJ20 -ECU
Smile Thanks!
Going to go work on the car now. I'll look at the injector color to see what kind it is. I'll let you know about those injectors Garry, I want to get the car running first . Thanks folks!
Old 01-30-2002, 11:35 AM   #5
preza
Member#: 1454
2000 2.5 RS-T
Subaru made a WRX engine in 91' ?
preza is offline   Reply With Quote
Old 01-30-2002, 03:37 PM   #6
NinNin
Member#: 9011
99 RS EJ20 -ECU
Angry Trying to start car for first time
Ok, still trying to get the car started with the TEC-2. Cranks but doesn't start. Backfires sometimes. Is the injector duty supposed to be at .00% when I'm cranking? I think they made the first gen WRX from 91-93. Individual coils, 2 liter turbo. I could be wrong, as usual. Anyone know about that injector duty Q?
my EJ20G injector flow results rob Pre-2002 Factory Turbo Powertrain 12 06-30-2012 02:25 AM
EJ20G injector o-rings and spacers rob Subaru Conversions 21 12-07-2006 10:43 PM
In need of EJ20G injectors Millencolin! Private 'Wanted' Classifieds 2 03-17-2006 01:35 PM
wtb ej20g injector silvialost Private 'Wanted' Classifieds 0 11-03-2005 03:00 PM
ej20g injector problems smacksube Subaru Conversions 4 01-13-2004 03:12 PM
