Welcome to the North American Subaru Impreza Owners Club Tuesday September 1, 2015
Old 12-25-2007, 04:02 AM   #1
benw
Member#: 103320
2005 wingless
aspen white
Default enginuity test release 774 LC-1 plugin not working
Well, it worked a couple weeks ago. I installed the enginuity test release on the new laptop, installed all the newest defs for logger and main app, and no dice. the AFR data reads zeroes.
AFR works like a charm in LogWorks. It's a drag trying to match up the AFR data from two different datalogged sources.
Anyone got any tips?
P.S. thanks to Enginuity.. seeing the same MAFV on plain 91 octane and 18 psi as my protuned map on 91 + 50/50 injection at 19 psi.
benw is offline   Reply With Quote
Old 12-25-2007, 09:27 AM   #2
Tea cups
Member#: 103136
Someone said something about deselecting the LC-1, then reselecting it when you have this issue. It was in one of the other threads in this sub-forum.
Tea cups is offline   Reply With Quote
Old 12-26-2007, 01:32 PM   #3
RedRicer
Member#: 128810
05 STI
CGM
Default Check and uncheck fixes this
I was having the issue and it is fixed by reselecting the LC_1 after loading the logging file
RedRicer is offline   Reply With Quote
Old 12-26-2007, 05:37 PM   #4
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
Same here, just check it twice and you're good to go.
ExpO is offline   Reply With Quote
Old 12-27-2007, 06:24 PM   #5
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
I had some issue with it as well but mine was both selecting the LC-1 and physical. It seems the connection only worked in certain positions and I had to futz around with it alot to get it to read.
/brox
Broxma is offline   Reply With Quote
Old 12-30-2007, 11:42 PM   #6
zman519
Member#: 118086
2003 WRX
where can i download Enginuity?
i found it http://forums.nasioc.com/forums/show...1409612&page=2
zman519 is offline   Reply With Quote
Old 01-04-2008, 03:37 PM   #7
XJDave
Member#: 142173
Spectra Blue
Post
I'm still having trouble getting my LC-1 to read anything but 0's. I tried clicking and unclicking the LC-1 in enginuity with no luck, so I reselected the com port through the Innovate LC-1 plugin, and I am still not getting any sort of reading. Any ideas would be great.
thanks
XJDave is offline   Reply With Quote
Old 01-04-2008, 03:37 PM   #8
XJDave
Member#: 142173
Spectra Blue
Post
thanks
Old 01-04-2008, 03:37 PM   #9
XJDave
Member#: 142173
Spectra Blue
Post
thanks
Old 01-04-2008, 03:38 PM   #10
XJDave
Member#: 142173
Spectra Blue
Post
sorry about the multiple posts, my computer froze up on me...
I just went through the entire wiring set up and double checked everything, and now I'm getting all the data I need. Must have been a bad connection somewhere along the line.
Old 01-04-2008, 05:33 PM   #11
benw
Member#: 103320
2005 wingless
aspen white
I had to reboot and restart the computer. I think Java might have been hosed for me. clicking and unclicking is now working again like before.
wideband lc-1 not working correctly with romraider jaxscuby Open Source Reflashes 13 05-12-2009 09:38 PM
Trunk release lever not working... Toadsworth Newbies & FAQs 5 07-18-2008 09:41 PM
Enginuity Test Release + LC-1 Wideband simon021 Open Source Reflashes 3 02-08-2008 08:12 PM
cruise not working, will I be able to see why with enginuity or ecuflash? shipjumper Open Source Reflashes 3 01-05-2008 06:35 PM
enginuity - how to log LC-1 dynamix Commercial ECU Reflashes 5 11-17-2007 02:39 PM
