Welcome to the North American Subaru Impreza Owners Club Sunday December 21, 2014
Old 12-25-2007, 08:19 PM   #1
Riles
Member#: 121154
2002 Impreza WRX PSM
Stage 47, Romraided
Default Injector scaling help
I have an 02 wrx with a 16g/exhaust/intake. I just installed PE650 injectors and need a little help getting this to idle. I changed the latency to 3.69, 2.39, 1.88, 1.58, 0.68. The idle still sucks and the CEL is flashing. Should I now keep the latency the same and scale them back to 560 to 570 to get me in the neighborhood or what?
Riles is offline   Reply With Quote
Old 12-26-2007, 11:13 AM   #2
DocDetroit
Member#: 24977
2003 WRX
I had an '03 WRX with PE1818, TurboXS topmount, PE650s, Walbro, Perrin fuel rail, etc.
After I installed everything, it fired up, idled and drove in closed loop reasonably well without any tuning.
Are you sure you don't have some other mechanical problem (vacuum leak, etc)?
DocDetroit is offline   Reply With Quote
Old 12-26-2007, 02:37 PM   #3
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
Don't just guess.
Datalog and make an educated estimate.
Your car should idle fine if you wait for AFR learning to set in as long as you are within 15% of your target.
First thing is to check your CEL and log roughness.
Then log AFR, AFR learning #1, AFR correction #1, IPW, MAF, rpm, load, CL/OL status.
mickeyd2005 is offline   Reply With Quote
Old 12-28-2007, 02:02 AM   #4
Riles
Member#: 121154
Stage 47, Romraided
Thanks guys, I'll try some data logging
Old 12-28-2007, 03:30 PM   #5
benw
Member#: 103320
2005 wingless
aspen white
what intake did you install? you're gonna have a beast of a time scaling the maf and the new injectors simultaneously. can you reinstall the stock intake?
benw is offline   Reply With Quote
Old 12-28-2007, 11:52 PM   #6
Riles
Member#: 121154
Stage 47, Romraided
its the spt intake and yeah its a toughy to scale but its doable
Old 12-29-2007, 12:49 AM   #7
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
If you scale the injectors and the intake simultaneously, your resultant maf and load will be slightly off. The AFR can be tuned such that it is correct. A small error is not that big a deal. My guess is anywhere between 1 and 10% depending upon how good you can guess.
It only becomes a problem when the load scale is really off like when you try to get around the 300 g/s of the 16 bit ecus by dividing everything by two.
The problem is that there are a LOT of ancillary tables that are MAF or load dependent. A lot of tuners forget to rescale the other tables.
help on injector scale up redrexmeister AccessPort 0 09-02-2008 11:31 PM
help with fuel trims / injector scaling.. logs inside AaronWRX UTEC 15 09-20-2007 10:37 PM
Injector Scaling Help (lean idle) xcntrk75 UTEC 4 01-03-2007 08:58 PM
Intersting thoughts on injector scaling and resulting timing effects Hitokiri Engine Management & Tuning 6 06-24-2004 10:31 AM
UTEC injector scaling thoughts cdvma Engine Management & Tuning 19 06-05-2004 02:42 PM
