Old 01-30-2002, 01:08 AM   #1
datdudedennis
Member#: 3928
2002 WRX sedan
WRB use to be MBP
Default need info about tein s-tech springs
im looking into buying some tein s-tech springs for my car but i wanted some feedback on it. its about a 1.8 inch drop, will i need to correct my camber? also how are the quality of these, (soft ones by the way). any helpful feedback is greatly appreciated.
dennis
datdudedennis is offline   Reply With Quote
Old 01-30-2002, 02:16 PM   #2
AScooby25rs
Member#: 4665
Location: Because life is too short to drink cheap beer!
1999 Grand Cherokee
I put the soft S Techs on my car last October, I can tell you a little bit, I'm no suspension wizard like some of the guys around here are.. But here it goes anyhow..
Lowering? More than 1.8" without question. I'd say a little closer to say 2.3 or so. I drive in snow, and this is a little bit of a problem for me, but nothing terrible, being in Texas, I'm sure you're not worried. I like a car that handles pretty good on the street, but my car will never see any track time, so allot of the reaon behind me getting these springs was purely asthetic, and for that, they're great. Unlike many of the springs out there for our cars, they lower the car evenly front to back. H&R's and Eibachs lower the back end more than the front, supposedly this is a good thing, something about the relationship between the front and rear roll centers or something like that.. Anyhow, I put them on the factory struts, and the ride is OK. A little more uncomfortable than stock, but it's not going to be that big of a deal. As far as camber correction, well, you will have to correct the camber, but when you take the strut assembly off, you have to reset the camber anyhow. If you've taken the struts off you car before, then you already know, if not.. It's really easy. The lower part of the strut assembly is held on with 2 big bolts, the top bolt is an eccentric bolt, this one adjusts the camber, there's little "tic marks" on the bolt head and on the strut. Loosen the bottom bolt just a touch, then turn the top bolt to your desired camber setting, really easy stuff. You'll see what I mean when you get everything apart.. All other things aside, I'd definitely reccomend these springs if you are looking for a good "lowering" spring. If you are planning to put your car on the track at any point, look into some coilovers, or at least some other spring and strut combo. Good luck! If you can think of any other questions, PM me, I'll do my best to help!
AScooby25rs is offline   Reply With Quote
Old 01-30-2002, 05:25 PM   #3
datdudedennis
Member#: 3928
2002 WRX sedan
WRB use to be MBP
that sounds reassuring but.....i have a 2002 wrx, not a gc8. i just don't think spending 200 for camber correction is worth it for a small drop but if the stock parts will allow camber adjustment than thats great.
dennis
Old 01-31-2002, 10:46 AM   #4
AScooby25rs
Member#: 4665
1999 Grand Cherokee
I knew you had a WRX, the springs are the same, the only difference is that the spring rates are more suited to the WRX, and mine are more suited to the GC8, otherwise the springs are the same. Same deal with the suspension setup and camber adjustment. Under the skin, the cars are *fairly* similar. In fact, the springs I have on my car were owned by a guy who had a GC8 2.5rs, then he bought a WRX wagon and had these springs on that car for a month or so. He said the spring rates were a little soft and they lowered the WRX more than the GC8, so he sold them to me and got some Whiteline springs. You might want to look into that as another option as well. If I remember correctly, the Tien GC8 springs were also rated at like a 1.8" lowering, so I am speculating when I say that they'll also be a little lower than that on your car.
Old 01-31-2002, 04:07 PM   #5
datdudedennis
Member#: 3928
2002 WRX sedan
WRB use to be MBP
yeah im getting the springs from godspeed used but they are for the gc8. he told me they would lower the wrx 1.8 but im guessing close enough to 2 inches. i guess all i need is the rear camber bolts. thanks for the help man
dennis
What about Tein G.tech springs for rally? Chase R Brakes, Steering & Suspension 13 11-17-2008 01:31 AM
We have $10,000 in Tein S-Tech Springs that we need to Move!!! Spun Autosports Suspension/Brakes/Handling 57 10-02-2006 11:00 PM
WTB: need tein s tech springs silverGDB Private 'Wanted' Classifieds 0 02-21-2005 04:43 AM
Need pics of Tein S-tech springs on an 93-01 Impreza with 17" rims K Rock Impreza Tire & Wheel 0 02-25-2004 08:18 AM
Tein S-Tech springs on a WRX - with photos about 1.5" drop ImprezaRS dot com Brakes, Steering & Suspension 13 04-18-2001 07:03 AM
