Old 12-25-2007, 08:41 PM   #1
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Default Rescaling the FLKC Table
OK, so Subaru was kind enough to extend the FLKC Columns (Load) all the way out to 1.8g/rev on my poky little NA 2.5L. Considering that the highest load I've ever seen on my car is 1.21g/rev this means that half the FLKC table isn't being used. I want to re-scale the table so ALL the columns in the FLKC table are able to be used, giving the ECU finer control over knock.
Here's the stock Fine Correction Range (Load) table:
Code:
Disable Below	Enable Above	Enable Below	Disable Above
0.68		0.70		2.10		2.20
Here's the stock Fine Correction Columns (Load) table:
Code:
Max1/Min2 	Max2/Min3	Max3/Min4	Max4/Min5	Max5/Min6	Max6/Min7	Max7/Min8
0.68		0.85		1.00		1.20		1.40		1.60		1.80
OK, so my question is what exactly do I need to do to rescale this properly? Here's what I'm thinking, let me know if I'm wrong:
1) Reduce the Fine Correction Range (FCR) upper bound to something realistic. The stock tables place the upper bound .30/.40 above the start of the highest column. Since I want my highest column to start at 1.2, that means the upper bound for FCR would be 1.50/1.60.
2) Move the lower bound down slightly to so that FLKC is active for the bottom of the load range that likes to knock on the freeway. The lower bound for FCR and the top of the lowest load column are the same on the stock map (btw, isn't this stupid? Doesn't it mean that the lowest load column isn't being used at all because the max value for that column is where FLKC turns on, thus putting the entire first column somewhere that's never used?). So set the lower bound of FCR to 0.60g/rev and the lowest column max to 0.60.
3) Since the FLKC columns now run between 0.6 and 1.2, they nicely turn out to be steps of 0.10 per column
Doing those three things, I end up with a scaled ine Correction Range (Load) table of:
Code:
0.60		0.62		1.50		1.60
And a modified Fine Correction Columns (Load) table of:
Code:
0.60		0.70		0.80		0.90		1.00		1.10		1.20
Does this seem like a reasonable and correct way to do it?
Old 12-26-2007, 06:29 PM   #2
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
will you please explain how this is beneficial? I have yet to figure these tables out...or how to get the data that has been stashed in them byt he ECU.
Wheeler Bement is offline   Reply With Quote
Old 12-26-2007, 06:35 PM   #3
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The way the stock ROM is, half the table is wasted in an area that the car physically reach. The table gets 8 columns any way you want to slice them. Stock, you're wasting the higher columns. If you re-scale the table so all 8 columns are in load values that the car can physically reach, you get better resolution and the ECU can "compartmentalize" the FLKC to just the problem areas.
In theory.
Old 12-26-2007, 07:07 PM   #4
Freon
Member#: 88322
2009 BMW 135i
I generally agree with your reasoning. Spread the columns where you need them. On the turbo cars, they're spread out pretty evenly from mid-low load to mid load. After tuning or especially a bigger turbo they should be shifted and spread a bit to where they are needed.
It could be on the NA cars they're intended to be somewhat large and chunky so that a larger area of the timing map is affected by learned data. If they're too fine grained, you may get extra knock events until the larger number of map points are learned, vs. a larger, chunkier distribution. It probably isn't a big deal if you are keeping an eye on your tune and knock. It is probably a bigger deal if you don't watch logs, you have some places that tend to knock as timing is first learned after a reset, and you reset your ECU a lot.
Freon is offline   Reply With Quote
Old 12-26-2007, 08:43 PM   #5
Tea cups
Member#: 103136
One thing that should be made clear is that the "Fine Correction Range (RPM)" and "...(Load)" tables are NOT the ranges where FLKC is applied but where changes to the FLKC tables are ALLOWED. FLKC application is not restricted by the range, depending on the "Fine Correction Columns (Load)" and "...Rows (RPM)" are setup. For example, looking just at RPM and disregarding load, let's say the "...Rows (RPM)" last value is 5800 RPM (which would mean 5800+ RPM). If the "Fine Correction Range (RPM)" disable high value was 6000 RPM, this would mean that changes to the FLKC table would be allowed from 5800-6000 RPM, however, these corrections would be APPLIED across the entire range (in this case any RPM above 5800). FLKC is active any time outside of idle. It is the ability to make changes to the table that is restricted by several conditions including the "Fine Correction Range (rpm/load)" tables.
Tea cups is offline   Reply With Quote
Rescaling the stock boost guage jackansi Interior & Exterior Modification 0 09-15-2008 10:31 AM
Tool to read FLKC table from ROMRAIDER BBBsti LTD Open Source Reflashes 3 03-22-2008 02:08 AM
Could this be the coolest table ever??? Fletcher Capstan Table The_Triton Off-Topic 57 12-30-2006 08:41 PM
Smashed my toe into the coffee table earlier... Colin84 Mid Atlantic Impreza Club -- MAIC 9 01-23-2006 11:04 AM
