Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 12-27-2007, 10:39 PM   #1
maxbserr
Member#: 148417
WRB XPTStg2/GMBCS
Default XPT Stage 2 with GM BCS
delete
maxbserr is offline   Reply With Quote
Old 12-28-2007, 01:02 PM   #2
Not-EWRX
Member#: 158043
2013 Wrx Hatch
Go post over on Ev8siv3's site. I am sure he would be glad to help you. Other than that there should be no resson for adjusting the WG arm with that map. Did you buy the GMBCS map?
Not-EWRX is offline   Reply With Quote
Old 12-28-2007, 02:29 PM   #3
benw
Member#: 103320
1998 swapped
Forester L
constructive criticism? leave your wg arm alone, and fiddle with your duty cycles.
Ev8sive probably errs on the side of being too conservative, so people don't overboost their cars and blow motors using his product. Cobb does the same, hence the multiple wastegate maps.
benw is offline   Reply With Quote
Old 01-02-2008, 05:35 PM   #4
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
Aren't those maps only made for simple mods?
tux121 is offline   Reply With Quote
Old 01-02-2008, 05:36 PM   #5
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
Old 01-04-2008, 10:26 PM   #6
maxbserr
Member#: 148417
WRB XPTStg2/GMBCS
bump for new log.
Old 01-04-2008, 10:55 PM   #7
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
I didn't DL your log cause I felt like responding blindly, but if your not hitting your target across the board you can multiply the entire WGDC table by 1.05 until you do hit max boost, then begin to adjust for individual RPM's.
If your not hitting it at certain RPM's but hitting it at others, add 5% to the RPM's cells your low in until you hit it. Of course, 4th and 5th gear WOT will probably overshoot a bit if you tune your WGDC in 3rd.
/Brox
Broxma is offline   Reply With Quote
Old 01-04-2008, 11:39 PM   #8
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
Why isn't throttle at 100%?
mickeyd2005 is offline   Reply With Quote
Old 01-04-2008, 11:42 PM   #9
maxbserr
Member#: 148417
WRB XPTStg2/GMBCS
Not sure, I floored the car. Sitting in my garage with the logger running I can get a max of 88.63. Thats opening the throttle with the car off.
Old 01-05-2008, 11:02 AM   #10
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
Maybe you were hitting the target boost for the 88% column? Check that throttle cable and see if it has a ton of play at the throttle body and report back.
/Brox
Old 01-05-2008, 11:31 AM   #11
maxbserr
Member#: 148417
WRB XPTStg2/GMBCS
Throttle issue fixed. New logs are as follows.
Boost jumped quite a bit with only 5% increase across all tables. Im thinking that Ill add another 3% and do another set of logs for 3rd gear.
Logs posted in the first post.
Old 01-05-2008, 01:43 PM   #12
wage0052
Member#: 127556
2006 WRX
RomRaided.
1) As you're using an XPT map, you should post on Braden's section of the OSecu forums. I'm sure he would be willing to help you. IIRC, he doesn't take kindly to other's posting logs of his maps.
2) An '02 should be able to hit between 17-18 PSI in the midrange with the GMBCS. I've found that almost all of the GMBCS's really like to hover around 60-65 WGDC's to hit this type of target boost.
3) I would keep an eye on your injector duty cycles. All of the 02-03's that I've tuned with the GMBCS needed to taper quite quickly at around 5k, in order to not max out the injectors.
wage0052 is offline   Reply With Quote
Old 02-10-2008, 11:25 AM   #13
bucket7788
Member#: 124263
2004 WRX Wagon
RomRaider + UTEC Tuned
Damn! Your (above) post would have been so much help if I had found it just a few days ago! I'm getting my boost for GM BCS pretty close now. Currently Max WGDC is at 62% for midrange. I'm just a bit shy of achieving my target of 17.5psi with that.
You are also right about maxing out the injectors! I'm getting mine up to 99% in the upper RPM's, so I'll have to back the boost off a bit up there.
Buck
bucket7788 is offline   Reply With Quote
Gas mileage with an XPT stage 2 flash Ultimateone Commercial ECU Reflashes 9 10-04-2008 06:22 PM
Has anyone with xpt stage 2 map get custom tuned? p01ntb1ank Open Source Reflashes 2 04-08-2008 02:49 PM
gm bcs with an xpt stage 2 worth it?? adWRXi Commercial ECU Reflashes 21 04-02-2008 09:18 AM
CEL after flashing 02 WRX with XPT stage 2 khizzle Newbies & FAQs 2 03-29-2008 09:18 AM
xpt stage 2 gm bcs w/launch control?? dstnbmxvr6 Commercial ECU Reflashes 7 02-24-2008 07:54 PM
