Welcome to the North American Subaru Impreza Owners Club Wednesday April 1, 2015
Old 12-28-2007, 07:24 PM   #1
skydes
Member#: 141347
2005 WRX
Default Regreasing STi struts
Finished The Job. Scroll Down For Some Tips.
Since this thread is part of a FAQ, I'll include some more helpful information:
Disassembly and assembly instructions: http://www.scoobymods.com/forums/showthread.php?t=6054 (registrations required)
Tools I used:
-Air compressor and Impact wrench (not required)
-14mm socket
-Spatula
-Torque Wrench
Materials I used:
-Mobil 1 Sythetic Red Grease
-Disposable Shop Towels (Lots and lots of them, greasing is messy business)
Other helpful stuff:
-A good hand cleaner like Gojo or Fast Orange really helps when you gotta get all the grease off your hands.
-Small flashlight. When doing the deep greasing, it helps to shine a flashlight down to see if you've missed any spots.
Torque specs:
-If you look at the Prodrive bumpstops PDF, they say that the torque spec for the nut at the bottom of the strut is 40 Newton-meters. This is approximately 30 Ft-lbs. When finally torqueing that nut back down, a vice with soft jaws would help, but I just used a chair, creatively.
TIPS:
-When cleaning out the old grease, use a small spatula for the grease furthest away. You won't be able to get the grease farthest in, but you'll be able to go in a good 8 inches with a spatula.
-Try to avoid using your finger to clean out the old grease. I cut my finger somewhere while doing it and it bled for a while. Use a piece of shop towel on your finger and swab that way.
-When you're done packing grease into the strut, you'll want slide the insert in with the bumpstop a good 8 inches. If you keep the bumpstop dead center, the bumpstop will help pick up the excess grease. Pull it out, clean the bumpstop, and then slide insert in all the way making sure to keep it absolutely dead center. If you don't keep it center, you could end up scraping the wall of the housing and picking up grease on the bottom of the bumpstop.
-MAKE SURE that when you finally slide the insert back in all the way that you rotate the insert until it slots into the buttom of the housing. You'll know it's slotted in when you cannot rotate it any more.
skydes is offline   Reply With Quote
Old 12-28-2007, 09:15 PM   #2
kodiaksti
Member#: 129452
06 sti
wrb
good or bad ive got an 06 sti and started to get a clunk in the lh rear strut. i bought a can of white lithium grease, jacked up the car till the wheel was off the ground, went behind the wheel, pulled up the dust boot and sprayed for couple seconds. quick fix i know but havent heard anything in 8k miles and it took all of 3 minutes.
kodiaksti is offline   Reply With Quote
Old 12-28-2007, 09:53 PM   #3
skydes
Member#: 141347
2005 WRX
I'm trying to go for a more thorough fix right now with repacking the grease.
Thanks for the input though.
Old 12-28-2007, 09:53 PM   #4
Fred
Member#: 3560
06 STi, 02 WRX
94 Open Light 2.5RS
Should I scrape out as much of the old yellow grease as possible and then pack in some mobil 1 grease?
Yes.
Or should I have bought a different grease?
No clue. What kind of grease is it?
Fred is offline   Reply With Quote
Old 12-28-2007, 10:37 PM   #5
skydes
Member#: 141347
2005 WRX
It's mobil 1 synthetic red grease.
Old 12-29-2007, 09:06 AM   #6
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
That grease will be fine. I have used several different kinds of grease when repacking and all have outlasted the stock grease and kept the clunking away. Clean out all of the old crap, clean out the struts completely, do a quick spray with white lithium grease inside, then repack the grease traps with the new grease. You should be good for a long time.
Tony
Old 12-29-2007, 08:05 PM   #7
skydes
Member#: 141347
2005 WRX
^^^Thanks. It's going to be a big hassle getting all the old grease out that is farther in the housing. Any tips?
Old 12-29-2007, 09:13 PM   #8
Zornorph
Member#: 17332
2004 Black STI
Not stock anymore
how is this done - any links to how to take the struts apart to grease them?
Zornorph is offline   Reply With Quote
Old 12-29-2007, 10:16 PM   #9
skydes
Member#: 141347
2005 WRX
Yes. Google prodrive bumpstop pdf. that will tell you how to take apart the strut. From there, you should clean out as much of the old grease as you can and then pack in new grease. It's a messy process.
Old 12-30-2007, 09:59 AM   #10
Fred
Member#: 3560
06 STi, 02 WRX
94 Open Light 2.5RS
I use a small plastic spatula to remove the old grease and to put in the new grease.
Old 12-31-2007, 12:41 PM   #11
ten80
Member#: 53625
00 EJ205 LGT LTD
Synthetic/lithium grease is usually best from my experience. Axle or bearing grease is too thick and will not allow for smooth operation. If the grease feels slick between your fingers rather than sticky, then it is likely suitable. I've had good luck using Napa lithium and various mountain bike synthetic fork greases for STI struts. No clunks in any of the four sets I have re-greased!
ten80 is offline   Reply With Quote
Old 12-31-2007, 10:40 PM   #12
skydes
Member#: 141347
2005 WRX
Ok I finished repacking my struts with grease today. See original post.
Good luck.
Old 12-31-2007, 11:05 PM   #13
Scooby-Doode
Member#: 28976
2007 Twin Turbo
Spoolin'
bah. Should have taken pics. Nice job though.
Old 01-01-2008, 12:28 AM   #14
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Anybody have picts? I have a set coming that I bet need greased.
dexterous is offline   Reply With Quote
Old 01-01-2008, 12:51 AM   #15
skydes
Member#: 141347
2005 WRX
Google prodrive bumpstops pdf. Follow that and it's pretty self-explanatory.
Old 01-03-2008, 04:24 PM   #16
skydes
Member#: 141347
2005 WRX
I've updated the original post to help people who still might be confused on what to do.
Old 01-03-2008, 05:01 PM   #17
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Thanks, good writeup
Old 02-23-2008, 02:27 AM   #18
Daggah
Member#: 152077
2002 Integra Type R
Championship White
How long does this keep the problem at bay?
Daggah is offline   Reply With Quote
Old 02-23-2008, 03:15 PM   #19
skydes
Member#: 141347
2005 WRX
No one can say for sure.
Old 02-24-2008, 08:10 AM   #20
SimonJ
Member#: 135309
I did the simple jack up and spray method under the dust boot. I did that last September and haven't heard a squeak since, even during a harsh Canadian winter
SimonJ is offline   Reply With Quote
Old 02-24-2008, 03:29 PM   #21
wrxman71
Member#: 162450
2004 wrx
How much grease do you put in?
wrxman71 is offline   Reply With Quote
Old 02-24-2008, 09:28 PM   #22
skydes
Member#: 141347
2005 WRX
Do not put in too much grease. You basically want to make the inside of the housing level with grease.
Old 04-16-2008, 01:46 AM   #23
MindzeyeWRX02
Member#: 145138
2002 Impreza WRX
WR Blue
i was getting worried about clunking issues i've heard about the sti struts. glad to see your post.
MindzeyeWRX02 is offline   Reply With Quote
Old 04-16-2008, 11:16 PM   #24
MindzeyeWRX02
Member#: 145138
2002 Impreza WRX
WR Blue
I just purchased a set of 04 sti take off suspension from the forum. I want to do this as a preemptive measure against clunking.
How much grease do i put in there?? all along the inside wall of the strut housing all the way down and thick enough for the bumpstop to pass??
and is the Amsoil grease any good?Synthetic Water Resistant Lithium Complex Grease
Old 04-17-2008, 03:32 PM   #25
MindzeyeWRX02
Member#: 145138
2002 Impreza WRX
WR Blue
^^ any help would be appreciated.
Need to borrow impact gun to regrease rear STI Struts JeffyLube SCIC Private Classifieds 8 10-23-2009 12:26 AM
Will pay anyone to regrease/repack my 04 STI Struts JeffyLube SCIC Private Classifieds 18 09-27-2009 09:43 PM
Should I regrease the front STi struts while I have them out? MF-DIF Brakes, Steering & Suspension 6 07-03-2009 09:19 PM
04 sti strut clunk after regrease crxgator Brakes, Steering & Suspension 9 04-02-2009 01:10 PM
Need help regreasing to solve STi strut clunk! zmaster Texas Impreza Club Forum -- TXIC 6 12-01-2008 03:32 PM
