Old 01-30-2002, 02:25 PM   #1
Turbotegra
Member#: 1389
2007 IS350
05 VFR 800 ABS
Unhappy HID problem
I bought and installed one of those K2 Hid kits that came with 6000k bulbs about a week ago and now, one of the bulbs won't stay on. It'll charge up about half way and fizzle out! I've tried switching the ballasts and ignitor from the other side of the car and still no luck. Any clues?
Turbotegra is offline   Reply With Quote
Old 01-30-2002, 11:53 PM   #2
Turbotegra
Member#: 1389
2007 IS350
05 VFR 800 ABS
Unhappy
back to the top.
Old 01-31-2002, 12:05 AM   #3
au112
Member#: 4412
MY01 Impreza 2.5RS
BRP
I don't have any experience on HID, but you may try to switch the bulbs to see if it is the problem of the bulb or the problem of other components
au112 is offline   Reply With Quote
Old 01-31-2002, 01:41 AM   #4
shawrf1
Member#: 3466
did you check your headlight fuses under your hood?
shawrf1 is offline   Reply With Quote
Old 01-31-2002, 02:30 AM   #5
Turbotegra
Member#: 1389
2007 IS350
05 VFR 800 ABS
The fuses were the first things I checked. Both sets of ballasts and ignitors tested good. The problem is that bulb but what can cause it to go bad? Thanx for the help guys.
Old 01-31-2002, 02:54 AM   #6
thermite
Member#: 13541
2002 Impreza WRX
Exclamation
if its a good company they should have warranty. Id try that route. Sounds like a bad bulb to me.
Glen
thermite is offline   Reply With Quote
Old 01-31-2002, 09:52 PM   #7
Turbotegra
Member#: 1389
2007 IS350
05 VFR 800 ABS
Yeah, they do have warranty. I brought it back to the store I bought it from and they're sending the bulb back for replacement. Too bad the store didn't just exchange it for me since I saw a kit sitting on the shelf a few feet in front of me. Now to put my stock bulbs back and wait for a couple of weeks.
Old 02-01-2002, 02:24 AM   #8
SilverWRX02
Member#: 11127
did you use a relay kit?
SilverWRX02 is offline   Reply With Quote
Old 02-01-2002, 04:48 AM   #9
sherifx
Member#: 10780
---- BRZ
Galaxy Blue Silica
my friend is experiencing this same prob with his hid kit... though its a different hid kit, the prob follows the bulb... if he flicks the light on then off again and agian, it eventually goes on... its just an inconvenience... I think replacing the bulb should do the trick...
sherif
sherifx is offline   Reply With Quote
Old 02-01-2002, 11:39 PM   #10
Turbotegra
Member#: 1389
2007 IS350
05 VFR 800 ABS
Nope, no realy kit was used. I had that happen to me a few times where the light flickered off but that was the bad bulb. The other bulb works just fine. The instructions say to use 30amp fuses. Isn't that a big jump from our 15? Won't the wires get hot from the high current?
Old 02-02-2002, 05:38 AM   #11
DEVO-2nd GEN
Member#: 3869
I can turn mine one when i have hand brake up (to the point that it indicator light shows up anyways)
when i'm in gear and actually rolling, one of them would go on, the other would flash and stay off.. i think both eventually comes up but i usually just turn them on with a little handbrake
then again, me having the old school 4200k phillips and automatic... proabably just applies to me :/
DEVO-2nd GEN is offline   Reply With Quote
McCulloch HID problem Bumble Bee 03 Electrical & Lighting 5 01-27-2004 07:51 AM
more hid problems fuzzy logik Electrical & Lighting 14 05-17-2003 01:02 AM
Hanabi HID problems Qbushido Electrical & Lighting 1 02-05-2003 04:03 AM
HID problem bentshoe Interior & Exterior Modification 33 01-06-2003 12:27 PM
hid problems m3eater Tri-State Area Forum 15 08-05-2002 07:09 PM
