Old 12-29-2007, 11:44 PM   #1
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Default hazard switch bulb burned out
My hasard switch illumination bulb burned... the dealer told me the entire switch is 40$ or so. Is it one of these little 12V radio-shack bulbs I could change myself in the switch?
Also, can I just pry off the switch, or do I need to disassemble the plastic around the vents with the screws next to the cupholder?
Old 12-30-2007, 10:57 AM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Are you sure the bulb is really bad. Since that light gets so little use I would suspect there may be a connection problem to the light rather than the bulb itself being bad.
Cougar4 is online now   Reply With Quote
Old 12-30-2007, 06:48 PM   #3
Bluefoton
Member#: 141373
2008 2.5i-hatch -
well its the bulb which illuminates the switch along with the cluster lights, when the headlights are switched on. I guess they just burn randomly, as it should always be on with the main lights (and not only when the button is pressed).
Old 12-30-2007, 07:14 PM   #4
Cougar4
Member#: 53443
Winestone
Ok, I understand. That does get a lot use. You may just have to remove the switch to get at it. You might try prying on the front bezel slighty to see if you can get at it from the front side.
Old 12-30-2007, 11:21 PM   #5
avk
Member#: 17252
'06 WX8
59E
A bulb from RadioShack should work.
avk is offline   Reply With Quote
Old 12-31-2007, 12:24 AM   #6
100_Percent_Juice
Member#: 126042
2004 W Ŕ X
I just did this myself and will post pics of the install tomorrow. All you need is the bulb from radio shack, and about 10 minutes. It seems hard when you first look at it, but its cake and the dealer and everyone else can suck a fat one for telling you that you need a whole new button.
100_Percent_Juice is offline   Reply With Quote
Old 01-04-2008, 04:28 AM   #7
100_Percent_Juice
Member#: 126042
2004 W Ŕ X
Old 01-04-2008, 07:58 AM   #8
Cougar4
Member#: 53443
Winestone
My compliments to your nicely done work on this. It will help some folks out.
Defroster and Hazard switch bulb replacement Kansai Subaru Electrical & Lighting 3 04-21-2008 11:03 AM
DIY: Hazard Switch Bulb Replacement 100_Percent_Juice Electrical & Lighting 19 01-22-2008 09:05 PM
bulb burned out in my gauge cluster, 04 wrx Anamagous Interior & Exterior Modification 0 03-27-2007 07:17 PM
fog/cruise/defrost/hazard switch bulbs NateDogg Electrical & Lighting 1 05-11-2003 03:37 PM
Legacy gauge bulb burned out... jarnold Legacy Forum 9 01-02-2002 03:59 AM
