Old 12-30-2007, 12:30 PM   #1
07Wagon
Member#: 152718
2004 WRX Wagon
Default CEL came on, and Cruise Control light is flashing
Anyone know what that signifies?
07Wagon is offline   Reply With Quote
Old 12-30-2007, 12:42 PM   #2
STIBungy
Member#: 51684
Holy crap, another one of these!
Step 1: go to an auto parts store or anyplace that has an OBD-II scanner and have them pull the code that's causing the CEL
Step 2: google and search on here the code and there should be some troubleshooting tips
Step 3: fix yo *****!
STIBungy is offline   Reply With Quote
Old 12-30-2007, 12:43 PM   #3
dougb76
Member#: 160340
2009 wrx 5 door
RIP
do this^^^
Could be a lot of things. have you done any mods? What were you doing when this happened?
dougb76 is offline   Reply With Quote
Old 12-30-2007, 12:44 PM   #4
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
vf39 ewg tuned ppg gears
You have just overboosted..I get that all the time in 4th gear. Kinda weird for you cause I never had that happen to me when i was stage 2. Anyways I think the only way to fix is maybe a protune. So im saving up and getting me a protune. =)
dumpstercrusher is offline   Reply With Quote
Old 12-30-2007, 12:45 PM   #5
07Wagon
Member#: 152718
2004 WRX Wagon
Well, I have an Invidia catted DP, HKS Hi-Power exhaust, and the stage 2 map. I was just idling waiting for the car to warm up when it started. I was just seeing if anyone knew offhand what those 2 together meant, if not I was going to go to the store.
Old 12-30-2007, 12:48 PM   #6
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
you could always try to pull the code up from your access port and if you want the cruise control light and the CEL to go away just turn off and turn on your car about 4-5 times. It will go away.
Old 12-30-2007, 01:12 PM   #7
mapleleaf
Member#: 103399
2009 Stripped STI
Dirty White
Check the code with your AP(might have been the smartest thing to due before you posted), reset your ECU and reflash your Realtime map if you use one. If it's an overboost code, you may want to get someone to adjust your WGDC accordingly and do a few data logs.
mapleleaf is offline   Reply With Quote
Old 12-30-2007, 01:14 PM   #8
mapleleaf
Member#: 103399
2009 Stripped STI
Dirty White
You were idling when it threw the code?
Look up the code ASAP.
Old 12-30-2007, 01:24 PM   #9
07Wagon
Member#: 152718
2004 WRX Wagon
AP can't pull the code, Advance Auto Parts doesn't have the ability, Firestone was too busy. I'm headed to the on-post auto shop, and if they can't help me, I'll hit the nearest Autozone.
Old 12-30-2007, 01:34 PM   #10
STIBungy
Member#: 51684
Just go to Autozone first. They've always been helpful with pulling codes. I send alot of local peeps there when I dont have my laptop with me to check for them.
Old 12-30-2007, 01:39 PM   #11
mapleleaf
Member#: 103399
2009 Stripped STI
Dirty White
That's strange.
Do you have ECUexplorer?
Download it on your laptop and pull the code.
Old 12-30-2007, 02:52 PM   #12
07Wagon
Member#: 152718
2004 WRX Wagon
p0304 is the code that autozone came up with, misfire in cylinder #4.
Old 12-30-2007, 03:10 PM   #13
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
reset and go on your way ,if it keeps happening I see a dealer in your future (warranty)
a6n6d6y is offline   Reply With Quote
Old 12-30-2007, 03:16 PM   #14
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
what does th AP say when you try to pull the code
Old 12-31-2007, 12:12 PM   #15
07Wagon
Member#: 152718
2004 WRX Wagon
AP said that there was no code. I reset the ECU, hasn't repeated thus far.
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 03:42 PM
Blinking Cruise Control, CEL, Tire Pressure, AND Traction Control Lights ALL on The Database Electrical & Lighting 5 03-14-2010 03:32 AM
Check engine light, VDC light is on, and cruise control and sport light is flashing Legacymun2k6 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-30-2010 12:47 PM
CEL on and cruise control light flashing silversurfer307 Service & Maintenance 0 01-11-2008 08:08 PM
Check engine light on and cruise control light flashing mpadovano Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 01-23-2005 02:04 PM
