Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 12-31-2007, 12:42 AM   #1
02RSBRP
Member#: 159398
Post Delta Cam Comparison (updated 3/06)
Ok so I finally got all the profiles for the following 2.5l SOHC: Stock, Delta 148 grind, Delta 2000 grind, stock vs 148, stock vs 2000, 148 vs 2000, and then one comparing them. I put all the profiles into excel and did some graphs up of them. Below is the graphs that you can take a look at. I would like to get the profile data for the other Cams that are available to us so I can compare those also. The lift on the side is actually the valve lift. The RAR is the Rocker Arm Ratio wich is multiplied times the actual cam lift.
I added the actaul cam profiles, not the actaul valve lift for those that would rather see those. On the new graphs don't worry about the lines at the bottom of the graph, just something I was working on for valve lash.
Valve lift
Stock
148
st vs 148
2000
st vs 2000
148 vs 2000
all
Cam Lift
stock
148
2000
02RSBRP is offline   Reply With Quote
Old 12-31-2007, 05:40 PM   #2
02RSBRP
Member#: 159398
Default More information while comparing
Here is some information that you may want to consider when comparing the cams.
VARYING LOBE SEPARATION ANGLE
...............Tighten ………………..........…..……………. Widen
Moves Torque to Lower RPM…………...... Raise Torque to Higher RPM
Increases Maximum Torque ……….......… Reduces Maximum Torque
Narrow Power band ……….. ……………...... Broadens Power Band
Builds Higher Cylinder Pressure …………... Reduce Maximum Cylinder Pressure
Increase Chance of Engine Knock …..…… Decrease Chance of Engine Knock
Increase Cranking Compression ……....…. Decrease Cranking Compression
Increase Effective Compression ………..... Decrease Effective Compression
Idle Vacuum is Reduced …………………...... Idle Vacuum is Increased
Idle Quality Suffers ………………………........ Idle Quality Improves
Open Valve-Overlap Increases …….…...... Open Valve-Overlap Decreases
Closed Valve-Overlap Increases …….....… Closed Valve-Overlap Decreases
Natural EGR Effect …………………….......….… Increases Natural EGR Effect is Reduced
Decreases Piston-to-Valve Clearance …… Increases Piston-to-Valve Clearance
Above 114 Deg. = Extremely Wide
114-112 Deg. = Wide
112-110 Deg. = Moderately Wide
110-108 Deg. = Moderate
108-106 Deg. = Moderately Tight
106-104 Deg. = Tight
Below 104 Deg. = Extremely Tight
ADVANCING / RETARDING CAM TIMING
.............ADVANCING …………......………........……… RETARDING
Begins Intake Event Sooner ……….......……. Delays Intake Event Closes Intake
Open Intake Valve Sooner ……………......…… Keeps Intake Valve Open Later
Builds More Low-End Torque ……….......……. Builds More High-End Power
Decrease Piston-Intake Valve Clearance …. Increase Piston-Intake Valve Clearance.
Increase Piston-Exhaust Valve Clearance … Decrease Piston-Exhaust Valve Clearance
Old 12-31-2007, 05:52 PM   #3
2.5EYE
Member#: 125996
This is some good info. This should be stickied.
2.5EYE is offline   Reply With Quote
Old 01-01-2008, 11:44 AM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Where did you get the profile data from? Did you degree the cams yourself?
Old 01-01-2008, 03:35 PM   #5
02RSBRP
Member#: 159398
I got all the data from Delta Cams. They sent me the data sheets for the different cams.
Old 01-01-2008, 09:40 PM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
I'll be damned. I've seen duration and lift numbers for other cams before, but never the real profiles like that.
Old 01-01-2008, 11:05 PM   #7
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
OK, so help a cam noob like me figure this out. I'm working off of your little list up there so check to see if I understand this.
Compared to stock, the 148 grind has greater separation between lobes, more lift, more duration, but less overlap. This means the 148 grind will have peak torque at lower RPM, but peak torque will be higher and the cam will require less timing.
Compared to stock, the 2k grind has less separation between lobes, very slightly more lift, much more duration, and more overlap. This means peak torque will be at a higher RPM, and the peak torque will be lower, however, it will allow more timing to be run.
Is that a correct interpretation? If so, what's the point of the 2k grind?
Old 01-02-2008, 01:14 AM   #8
02RSBRP
Member#: 159398
Basically the 148 grind gives you more low and mid power, but won't give you anything up top. The 2000 grind gives you more mid and upper power. So for people looking for more top end power, they would get the 2000 grind. If you look at the graphs, the new profiles of the cams have altered the timing already.
I'm more of a visual person when it comes to comparing two things. Plus with the graphs I can see where the difference are. I just basically took the profile sheets I got from Delta and put it into Excel then graphed them. It definetly made it alot easier to see the entire profile of each cam.
Old 01-02-2008, 07:46 PM   #9
swede978
Member#: 89233
99 RS Aspen White
2014 Outback SWP
Thank you so much! You rock
swede978 is offline   Reply With Quote
Old 01-02-2008, 10:27 PM   #10
02RSBRP
Member#: 159398
I'm just trying to learn more about these engines and what is available. Figured what I come across should be shared.
Old 02-28-2008, 05:56 PM   #11
02RSBRP
Member#: 159398
See next post.
Old 02-29-2008, 02:18 AM   #12
02RSBRP
Member#: 159398
Alright guys. Those are all the graphs for your viewing pleasure. I hope this helps people out.
Old 02-29-2008, 03:38 AM   #13
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Great stuff. thanks for the hard work
rougeben83 is offline   Reply With Quote
Old 02-29-2008, 06:35 AM   #14
Guerice
Member#: 51519
2006 2.5i Wagon
AKA Drtywgn
I'm with you on being visual, I happy I got some 2000 grind from ^^^^^^
Guerice is offline   Reply With Quote
Old 02-29-2008, 03:34 PM   #15
ArcticWolf
Member#: 146732
2006 Impreza 2.5i
Obsidian Black Swirl
Going to ask a silly question here...
For our cars, what are the rev ranges for low, mid, and high?
ArcticWolf is offline   Reply With Quote
Old 02-29-2008, 05:51 PM   #16
02RSBRP
Member#: 159398
Well our Rev limit is 6200 RPM's. So Low would be less than 3k, mid would be 3k to 5k, and high end is greater than 5k. Not sure if this is what everybody else looks at, but that's how I seperate them out.
Old 03-01-2008, 01:43 AM   #17
batman 2.5i
Member#: 172005
2005 wrx
Crystal Gray Metallic
Anyone know if delta has made cams for the 2.5i. I heard they were like 6 months ago. And what kind of power gains would you guys think it would give.
Thanks!
batman 2.5i is offline   Reply With Quote
Old 03-01-2008, 11:22 AM   #18
02RSBRP
Member#: 159398
Delta doesn't make cams. You have to remove your stock cams and send them to Delta. They regrind the cams to the new profiles and you reinstall. The 2.5i has the same EJ25 as all the older ones, so it they should be able to regrind them no problem.
Old 03-01-2008, 06:30 PM   #19
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Not quite. The EJ253 in the 2.5i has i-AVLS, which means there are three intakes lobes per cylinder. One valve operates on the low lift lobe until conditions are met for the rockers to lock together and have the valve use the high lift lobe.
Counterfit is online now   Reply With Quote
Old 03-01-2008, 07:21 PM   #20
02RSBRP
Member#: 159398
Ok I must have missed that. I looked it up to see if the 2.5i had AVLS, but didn't see anywhere that said it did. I know the DOHC models do, but didn't think the SOHC did. Thanks for the info Counterfit.
Old 03-03-2008, 01:48 AM   #21
batman 2.5i
Member#: 172005
2005 wrx
ok thanks guys. i was told something different a long time ago..so glad you guys cleared that up. and yes the 2.5i has i-AVLS thats why i was asking cuz i still dont know if they can do it to my car without messing up the i-AVLS. anyone know what kinda of hp gains would come from these guys messing with the cams??
thanks guys!
Old 03-03-2008, 08:06 PM   #22
02RSBRP
Member#: 159398
I would call Delta and talk to them about it. I'm sure that they could probably do a grind on the i-AVLS cams. Probaly run a little bit more since they have to grind two extra lobes on the intake valves. They may still be working on what kind of profile or something.
Old 03-04-2008, 12:12 AM   #23
HeyChris
Member#: 2234
2013 F-XT
Obsidian Black Pearl
What has the average mailbox to mailbox timeframe been for people?
HeyChris is offline   Reply With Quote
Old 03-04-2008, 01:22 AM   #24
iRick.
Member#: 158155
i'm going to call up delta once i get some money and see what they can do for me
anyone know who the hell i could get to remove my cams?
i can't do that stuff myself ><
iRick. is offline   Reply With Quote
Old 03-04-2008, 12:59 PM   #25
SilverSubie2.5
Member#: 136144
2006 WRX Wagon
CGM
From what I've seen over on RS25, they will do the grind the same day they receive them, send them out the next day. So theoretically, you could have everything done in a week from the time they leave, to getting them in the car.
SilverSubie2.5 is offline   Reply With Quote
Cam comparison ej20twinturbo versus ? 2.5 cam reddevil Built Motor Discussion 1 03-18-2007 04:14 PM
Opinions on Delta Cams? RayQuon Normally Aspirated Powertrain 65 06-27-2006 10:50 AM
Those with Delta cams please read Crash477 Normally Aspirated Powertrain 11 06-27-2006 01:11 AM
Who's using Delta Cams? I got Questions Burnout Normally Aspirated Powertrain 11 06-23-2005 12:14 AM
Sending Cams to Delta Cams subachad Subaru Conversions 10 02-28-2005 11:23 AM
