Old 03-09-2008, 12:25 AM   #51
calgearhead
Member#: 133745
1998 Lifted Outback
Green + Dirt
Being a noob and everything, I've been seriously considering cams for my 98 2.5 DOHC, and already have an e-bay intake, IM Spacers, StreetLite flywheel going in and stock exhaust for now (thinking OBX EL Headers). I REALLY don't have the $$$ for a separate engine management system nor the knowledge on how to use it (yeah I know, dyno day, but too far away for me). Do you have to have separate EM with cams? Also, how much torque loss with the 2000 over 1000?
calgearhead is offline   Reply With Quote
Old 03-09-2008, 12:52 AM   #52
rougeben83
Member#: 115154
2005 Outback XT
White on grey
No, DLC has cobb cams and basically every other bolt on you can have on the car and he has no EM and runs perfectly fine. You'll still have CEL though.
rougeben83 is offline   Reply With Quote
Old 03-09-2008, 06:19 AM   #53
02RSBRP
Member#: 159398
Engine Management is not required for Cams. BUT.......
I've been doing a lot of logging of my car. I'm not a tuner and just starting to look at what I'm getting on my logs. It appears to me that the ECU programing from subaru is missing out on a lot of HP/TQ. So by putting Cams in, we may not be seeing the gains that we could if we could go in and change some stuff in the ECU (wich only 05+ can).
So I think if you are going to be modding and want to get every penny worth, Piggyback or even stand alone EM would be something that you invest in. May not be one of the first, but maybe down the line.
02RSBRP is offline   Reply With Quote
Old 03-10-2008, 01:16 AM   #54
calgearhead
Member#: 133745
1998 Lifted Outback
Green + Dirt
Good to know and thanks for the info. EM is on the "eventually" list along with other non-engine related mods. I just wanted to see if I could get away with running cams for X amount of time before going EM, or if I had to do them together.
Old 07-03-2009, 04:13 PM   #55
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Why do you have two graphs for each cam which show different amounts of lift?
Old 09-17-2011, 01:46 PM   #56
02RSBRP
Member#: 159398
Wow, been a long time since I had looked at this post I did. To answer your question williaty, one set of graphs are for the actual CAM lift, where as the other set is the actual VALVE lift (these graphs show the RAR at top that was used).
Still working on figuring out the exact RAR on the subaru, I've found at least 4different ones listed. Finally got a spare motor and just need to finish determine that.
Old 01-26-2012, 10:13 PM   #57
vicious_fishes
Member#: 158864
2003 SOHC destroker
were we ever able to get the 1500 specs?
interested for my SC'd setup
vicious_fishes is offline   Reply With Quote
Old 01-26-2012, 10:38 PM   #58
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
Originally Posted by rougeben83 View Post
I'll be honest, the 2000 grind, thought more aggressive of the two profiles, is no where as aggressive as the "race/spice" cams that cobb/weber puts out, so I think the day to day driveability of the 2000 grind is still reasonable.
I know this is an old post but I have the Cobb "Spicy" cams in my car and I don't believe they are all that aggresive in comparison to Delta 2000.
Unfortunately, Web Camshafts only has specs on their 148e cams posted on their website.
Here's the specs for 148e: Web Cam 148e
The Cobb "Spicy" cams were manufactured by Web and are equivalent to the 115 grind, which were more aggresive than the 148e's.
My cams even have a "Web 115" stamped into them.
I wish I had more info on them, but I even emailed Cobb awhile back and they had little archived information.
T Wrex--OH is offline   Reply With Quote
Old 01-26-2012, 10:47 PM   #59
vicious_fishes
Member#: 158864
2003 SOHC destroker
shot delta an email off hoping to get the profiles for the 1500 and 1000/2000 cams up as well.
having an SC'd setup i'm having a little more difficult time concluding which are the most suited. so far as i can tell i want the intake profile from the 1000 with the exhaust from the 1000 but retarded a little, but haven't seen the 1500's to do a comparison.
sigh. this would be so much easier if i was DOHC.
Old 01-26-2012, 11:18 PM   #60
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
Okay, while searching I found some apparent specs for the Web 115:
Duration @ 0.050" 224 degrees
Intake Lift 0.410"
Exhaust Lift 0.350"
That compares to the Web 148e:
Duration @ 0.050" 208 degrees
Intake Lift 0.410"
Exhaust Lift 0.355"
The 115 has slightly less exhaust lift and a longer duration, very similar to the comparo between Delta 1000 & 2000.
Old 01-27-2012, 01:02 AM   #61
subi400
Member#: 216984
1996 Impreza outback
Green
So, that graft in the first post is pretty cool! But, has someone looked at the difference between the delta 2000's and the delta 3000's? Looking at building a higher revving NA like 7500-8500 rpms so any info for the difference between the two would help!
subi400 is offline   Reply With Quote
Old 01-27-2012, 04:22 PM   #62
vicious_fishes
Member#: 158864
2003 SOHC destroker
alright so i got the full datasheets from delta. i can email them to anyone that knows what they're reading/can turn them into the excel graphs ala the OP.
shoot me a PM with your email address if you can do this
Old 01-28-2012, 03:51 AM   #63
sergey2007
Member#: 304910
2004 Legacy ej20y
written request to the private messages
sergey2007 is offline   Reply With Quote
Old 01-28-2012, 06:04 AM   #64
vicious_fishes
Member#: 158864
2003 SOHC destroker
email sent.
Old 02-27-2012, 12:44 PM   #65
OB2
Member#: 51500
1999 impreza rs-t
sylver
I know it is a old post but did anyones dyno test the difference between the stock, 1000 and 2000 cams on a turbo setup???
OB2 is offline   Reply With Quote
Old 02-27-2012, 02:19 PM   #66
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
I doubt it. They are not designed for positive manifold pressure.
Old 02-28-2012, 03:04 AM   #67
sergey2007
Member#: 304910
2004 Legacy ej20y
email sent.
Thank you. All received. But there is a performance camshaft 1000, 1500, 2000 for the ej251 engine. And what are all the same characteristics of a camshaft (the only one available option) for the ej253 AVLS engine?
Old 02-28-2012, 04:08 AM   #68
vicious_fishes
Member#: 158864
2003 SOHC destroker
as long as it's SOHC it uses the same cams.
if it's DOHC, they do "220" and "230" etc cams, which you'll need to ask them about.
Old 02-28-2012, 09:04 AM   #69
sergey2007
Member#: 304910
2004 Legacy ej20y
SOHC, but the 253 engine camshafts are different because of the AVLS system.
Old 02-28-2012, 01:34 PM   #70
vicious_fishes
Member#: 158864
2003 SOHC destroker
sorry, i should rephrase: the same grinds. i don't believe the grinds differ at all between the various SOHC engines. there's nothing getting in the way or whatever of delta's grinding wheel.
Cam comparison ej20twinturbo versus ? 2.5 cam reddevil Built Motor Discussion 1 03-18-2007 04:14 PM
Opinions on Delta Cams? RayQuon Normally Aspirated Powertrain 65 06-27-2006 10:50 AM
Those with Delta cams please read Crash477 Normally Aspirated Powertrain 11 06-27-2006 01:11 AM
Who's using Delta Cams? I got Questions Burnout Normally Aspirated Powertrain 11 06-23-2005 12:14 AM
Sending Cams to Delta Cams subachad Subaru Conversions 10 02-28-2005 11:23 AM
