Old 12-31-2007, 04:33 AM   #1
benw
Member#: 103320
1998 swapped
Forester L
Smile Video: Basic Datalogging with Enginuity
http://www.youtube.com/watch?v=dkDa7-ZbDBw
Made this tonight on request from a member. Hope it helps!
This video is for:
- someone who has never used Enginuity or datalogged their car
- someone wanting a quick primer on the basics of datalogging
This video assumes:
- you have the proper tactrix cable for your application
- you have installed the latest version of the openport drivers for your cable (these install as part of ecuflash)
- you have the latest version of Enginuity and its associated definitions installed
- your car and ECU are in safe state of tune (not going to blow up)
- you have your tactrix cable properly connected to the OBD2 port and to your laptop
Notes:
- my wideband reads erratically at idle because it's clamped to the tailpipe and sees fresh air. it reads normal as soon as exhaust gases begin flowing!
- upload your logs to Google documents, or copy paste them with abbreviated column headers to the forums, using the CODE tags.
benw is offline   Reply With Quote
Old 12-31-2007, 04:48 AM   #2
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
great job!
Bishop is offline   Reply With Quote
Old 12-31-2007, 04:51 AM   #3
benw
Member#: 103320
1998 swapped
Forester L
I hope everyone can see what was going on. It was very dark.
Old 12-31-2007, 10:19 AM   #4
Tea cups
Member#: 103136
Nice job!
I don't know if you are going to develop it further, but for noobs it might be a good idea to show the COM port selection in the logger that they will likely need to change and maybe even how to install the latest logger defs (this is simple but some are computer challenged). Maybe even show how the tactrix cable is connected. Also, I would log "Engine Load (Direct)" rather than "Engine Load (Calculated)" as it the actual load used by the ECU (i.e. more accurate) and will not impact your sampling rate when used instead of the calculated parameter.
Tea cups is offline   Reply With Quote
Old 12-31-2007, 12:21 PM   #5
Not-EWRX
Member#: 158043
2013 Wrx Hatch
This is some cool stuff. It will definitely be helpful to the learning impaired. (like me)LOL
Not-EWRX is offline   Reply With Quote
Old 12-31-2007, 12:59 PM   #6
benw
Member#: 103320
1998 swapped
Forester L
Originally Posted by Tea cups View Post
Nice job!
good info thanks!
I may do the definitions etc in the EcuFlash demo movie. that does seem to be a sticking point with some users.
Old 12-31-2007, 07:34 PM   #7
jordanretro1223
Member#: 143039
2007 STI
Satin White Pearl
How do you get into dashboard mode?!?!?!
Thats the coolest thing I've ever seen and looks super useful. I'm always squinting at red lights to read my data.
jordanretro1223 is offline   Reply With Quote
Old 12-31-2007, 08:08 PM   #8
wrx nig
Member#: 159864
03 RHD Bugeye STi
with Volk winter wheels
im beautiful!
wrx nig is offline   Reply With Quote
Old 01-01-2008, 02:18 AM   #9
benw
Member#: 103320
1998 swapped
Forester L
go to the bottom of the logger, see the tabs?
make sure you only choose parameters in one tab. otherwise they will all be logged simultaneously (I think)
Old 01-01-2008, 11:44 PM   #10
hetsaq
Member#: 63572
Nice work, this can really overwhelm someone that has not done it before, thanks for your time.
hetsaq is offline   Reply With Quote
Old 01-02-2008, 01:09 AM   #11
CenCali07sti
Member#: 144523
2007 Sti
Satin Pearl White
thanks benw this helps clear up alot of things for me. I will be doing logging soon once my custom TBE is finished and I want to make sure the car is safe. Much appreciated.
Brandon
CenCali07sti is offline   Reply With Quote
Old 01-02-2008, 02:33 AM   #12
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
nice video mate. Very helpful
Do you think you could do another vid, but for tuning with Enginuity and reflashing your tune with EcuFlash :P
wrxsti.l is offline   Reply With Quote
Old 01-02-2008, 10:42 AM   #13
Rogan
Member#: 142133
3 Jeeps
And a Saab
are the herps that prevelent there, that you need a defrogger switch?
just messin'.. good vid!
Rogan is offline   Reply With Quote
Old 01-02-2008, 02:34 PM   #14
benw
Member#: 103320
1998 swapped
Forester L
If you don't have a de-frogger switch, you can use the de-fogger, but it won't be nearly as effective, or nearly as imaginary.
I plan on doing an EcuFlash movie as soon as this flu clears up!
Old 01-02-2008, 02:47 PM   #15
Rogan
Member#: 142133
3 Jeeps
And a Saab
LOL!
here's a question: when I flash my ecu, I plug two plugs in: 1 jumper plug that came with my tactrix cable, and 1 pr of wires together. Is it necessary to do both, when flashing?
Old 01-02-2008, 03:17 PM   #16
benw
Member#: 103320
1998 swapped
Forester L
if you have a 02-05 WRX I know you do. On mine (05 STI) I just have to connect the green test connectors.
Old 01-02-2008, 05:08 PM   #17
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG,FMIC, Big turbo
wow that video was very informative!! I still dont really understand but that helped me, thanks alot
emsmap is offline   Reply With Quote
Old 01-03-2008, 03:56 AM   #18
Expurg8d
Member#: 163430
2010 WRX base
Excellent movie, it really helped me out. I can get eginuity to log and work fine but I can't get ecuflash to read my rom, i think I have the definitions in ecuflash set up incorrectly. I've reinstalled both the cable and ecuflash and the cable is recognized, but when I try to read my ecu a window opens with "read" in grey and "cancel" as the only two options and no reading takes places... I'm waiting for an ecuflash movie i think. Thanks.
Expurg8d is offline   Reply With Quote
Old 01-04-2008, 02:13 PM   #19
BBBsti LTD
Member#: 71682
2007 WRX Sti LTD.
This is simply GREAT!! Thanks ai know oyu guys do this because of passion, would be nice having a demstration on how to save the ROM and how to look at it...
Thanks
BBBsti LTD is offline   Reply With Quote
Old 01-04-2008, 02:21 PM   #20
Rogan
Member#: 142133
3 Jeeps
And a Saab
ben, I'll be flashing the ECU tomorrow (a couple times, actually).. I'll try to video it..
If my vid cam will work, I'll try to video "reading" the rom from the ecu in ECUFlash, too.
Old 01-04-2008, 05:43 PM   #21
benw
Member#: 103320
1998 swapped
Forester L
cool, let us know how it goes! Tonight or tomorrow I'm doing a lot of flashes myself. I would like to post up videos of the process as well, to go with this first vid.
Old 01-04-2008, 06:20 PM   #22
crazyGC8
Member#: 107421
MY00 RSTi-SOLD BUILT
MY04 STi-SOLD AG2 S13-DD
Thanks for the video!! It's very helpful....
Now I need to go figure out the dashboard mode.
crazyGC8 is offline   Reply With Quote
Old 01-04-2008, 06:25 PM   #23
Rogan
Member#: 142133
3 Jeeps
And a Saab
since the profiles for the logger are tab-specific, I created three profiles: logger_dash, logger_graph, and logger, for the respective tabs.
Old 01-04-2008, 06:37 PM   #24
geddesk2
Member#: 119397
98rs 06sti
RBP & WRB...BLUE!
"by pressing the defrogger"
Nice work but that made me laugh!!!
geddesk2 is offline   Reply With Quote
Old 01-04-2008, 07:20 PM   #25
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
You must have a great presentation skills. Awesome video!
ps: maybe you may want to state what to look for when analyzing the data... maybe top 2-3 parameters that you normally look to identify problems (value, trend, etc)?
Datalogging with Enginuity NO Defrost button!! elsanto Commercial ECU Reflashes 6 11-25-2007 02:44 PM
Problems with enginuity reflash Mr.Krinkle Other Engine Management 2 01-02-2007 11:33 AM
'06 WRX stg2 tune with Enginuity Airboy Western Canada 3 12-24-2006 01:54 AM
Anyone Familiar With Enginuity & OpenEcu Tools... JohnnyWas Engine Management & Tuning 9 11-07-2006 04:34 PM
Anyone Familiar With Enginuity & OpenEcu Tools... JohnnyWas Tri-State Area Forum 18 08-31-2006 02:29 PM
