Old 12-31-2007, 06:30 PM   #1
FAST-1
Member#: 105537
Default Stock STI 06 rear lateral links - do they have pillow balls?
Thinking of upgrading, would like to know if the stock OEM STI 06 rear lateral links have pillow balls?
Thanks!
FAST-1 is offline   Reply With Quote
Old 12-31-2007, 09:58 PM   #2
ten80
Member#: 53625
00 16' FXT
no, just soft rubber bushings. The group-n lateral link bushings are a fair bit stiffer and pillowballs even more so.
ten80 is offline   Reply With Quote
Old 12-31-2007, 10:07 PM   #3
mxpop
Member#: 103776
2006 STI
For a true upgrade, you should get some lateral links that are adjustable with the type of ends you desire. Cusco and Whiteline come to mind. Note that some lateral links require a sway bar change as well.
mxpop is offline   Reply With Quote
Old 01-01-2008, 01:34 AM   #4
kursplat
Member#: 89528
2005 sti
crystal grey
out of curiosity...what are you upgrading?
kursplat is offline   Reply With Quote
Old 01-01-2008, 12:55 PM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
That's only an upgrade if the alignment settings he's try to get to cannot be obtained with his current parts.
Old 01-01-2008, 04:44 PM   #6
mxpop
Member#: 103776
2006 STI
^^ They will also allow a change to pillowballs etc and also allow different wheel/tire combos. Additionaly, they are stiffer and help maintain whatever specs you set your suspension at even if you can achieve your desired settings with the stock LLs.
There are several good reasons to go with aftermarket lateral links regardless of desired settings, I thought you would know that. Being able to get settings beyond what you can get stock is a bonus.
Old 01-01-2008, 06:14 PM   #7
Daishi00
Member#: 78952
2005 WRX
CGM
Nothing you said makes much sense at all there chief. How would they help maintain specs when you are just adding in more items that can shift and therefore throw off said alignment.
I purchased the STi full pillowball set specifically to AVOID adjustable lateral links as they just create more of a headache when dealing with the suspension.
Granted, they do have a place, but very few actually see some sort of benefit from them except on an aggressive track vehicle.
Daishi00 is offline   Reply With Quote
Old 01-01-2008, 06:50 PM   #8
mxpop
Member#: 103776
2006 STI
Making a stronger and better designed part that is adjustable isnt just adding parts that can shift/fail unless you think that same way about the adjustable parts in F1, Nascar, etc... There is no advantage to having a heavy, stamped steel, non-adjustable, soft rubber bushed part on a performance car other than cost and comfort.
Getting specs not achievable with stock LL makes sense.
Having better toe adjustment makes sense.
Having better camber adjustment makes sense.
Being able to change track and/or fit different tire/wheel combos makes sense.
Keeping the whole package at the desired spec with less flex thru stronger parts makes sense.
Doesn't that all make sense?
If your one and only concern is to maintain your warranty coverage on a totaly stock car, then I guess what I said wouldnt apply or make sense.
Old 01-01-2008, 08:39 PM   #9
Daishi00
Member#: 78952
2005 WRX
CGM
Such as? How much negative camber do you need in the rear? Any camber adjustment that would be beneficial can be achieved with camber bolts 99% of the time. Or, slot your rear struts...gives you quite a bit of camber adjustment that way
Again, how much toe do you need? You planning on running an inch of toe?
See my first comment.
Only point that's valid IMO and even then we're talking track prepped cars. Pick the correct offset, roll fenders and you're pretty much good to go.
Putting adjustable ends on will create the chance of flex more than a solid piece. If someone uses them to correct for something like a damaged subframe they could adjust the link right to the end and then bye bye lateral link. Also, my STi links are much more beefy than the stockers so there goes that part of your reasoning as well
I'm not saying they don't have a place, but for the majority of people out there they are unneeded and more than likely will do more damage than help.
Old 01-02-2008, 12:04 PM   #10
FAST-1
Member#: 105537
Thanks ten80 for answering my question.
Also I would like to thank everyone else for the good info.
I already have the CUSCO trailing arms and I have a deal on some CUSCO links. I am just trying to decide if the money will be best spent there.
Oh...and HAPPY NEW YEAR ALL!!!
Old 01-02-2008, 12:31 PM   #11
mxpop
Member#: 103776
2006 STI
As pointed out by me and daishioo, everyone has different opinions so it should come down to what you want out of it.
I need and appreciate what stronger and adjustable links do for me so I have them. Daishioo doesnt, to each their own.
BTW, why did you get trailing arms before getting links?
Old 01-02-2008, 01:05 PM   #12
FAST-1
Member#: 105537
Hi, A friend totaled his 06 STI and I bought just about everything that was on his car at a great price. I autocross so I thought most of the parts would be helpful, including the trailing arms. I ran out of money before I got to the lateral links though. I have saved up some money since and was trying to decide if I should buy them.
Thanks again for your advice...
Old 01-02-2008, 01:40 PM   #13
mxpop
Member#: 103776
2006 STI
no prob, enjoy your car!
Old 01-02-2008, 02:07 PM   #14
Portly
Member#: 1197
1997 Impreza Wagon
Mystic Blue Pearl
Nothing about my Whiteline adjustable links makes me think they are "stronger" than a non-adjustable item. They added a lot of unnecessary WEIGHT, gave me some adjustment options that it turns out I have no real use for, and the poly bushings created a fair bit of extra "stiction" in my rear suspension.
In summary, as an owner of adjustable links, I would DEFINITELY do the Group-N bushing upgrade to stock links if I had it to do over again.
_Jeff
Portly is offline   Reply With Quote
Old 01-02-2008, 02:11 PM   #15
kursplat
Member#: 89528
2005 sti
crystal grey
i am curious what car your putting the sti parts on. are you just doing the rear suspension or front too? are you using the '06 swaybars too?
thanks
Old 01-02-2008, 02:16 PM   #16
kursplat
Member#: 89528
2005 sti
crystal grey
tell the truth, you just do car shows, right?
Old 01-02-2008, 03:26 PM   #17
FAST-1
Member#: 105537
thanks
06 STI, COBB sways and end links front and rear.
Old 01-02-2008, 08:44 PM   #18
mxpop
Member#: 103776
2006 STI
You are correct! I just do car shows....
...... at about 100+mph....
1st: '07 Tuner Shootout Street awd
1st: '07 TS Mod awd
1st: Redline Time Attack Overall Street class champion, Laguna Seca
1st: RTA Street awd, Laguna
2nd: Import Tuner Evo vs STI Street
2nd: Superlap Battle, Street
2nd: RTA Street, Buttonwillow
3rd: RTA Street, Cal Speedway
3rd: RTA Modified awd, Laguna
*No DNQ/DNF in 2007!*
*Fastest STI in 8 of 9 races!*
http://www.harmanmotive.com/catalog/index.php
http://www.drivingsports.com/blog/20...net-clean.html
http://www.stoptech.com/company_info..._Attacks.shtml
Old 01-02-2008, 08:50 PM   #19
mxpop
Member#: 103776
2006 STI
_Jeff
My Whitelines are way stiffer/stronger than the stock stamped steel part. I do agree that they have more stiction than I would like tho. A switch to heims would solve that but I hate heims.
Everyone has lots of opinions, I let results speak for themselves (see above post).
Old 01-02-2008, 09:12 PM   #20
Crawdads
Member#: 30907
SWP GDB-G
You keep saying "stock stamped steel"...but the STi has tubular aluminum lateral links...and the WRX has tubular steel ones.
The links don't really need to be upgraded...The bushings are the part that needs improvement.
Crawdads is offline   Reply With Quote
Old 01-02-2008, 09:17 PM   #21
STi-MAN
Member#: 70252
05 STI
blue
+1 even the stock sti lateral links are aluminium painted black with rubber bushings.
STi-MAN is offline   Reply With Quote
Old 01-02-2008, 09:26 PM   #22
kursplat
Member#: 89528
2005 sti
crystal grey
1st: '07 TS Mod awd
*Fastest STI in 8 of 9 races!*...
nice...if you ever what to see how it handles bring it out to Fontucky sometime
Old 01-03-2008, 01:52 AM   #23
mxpop
Member#: 103776
2006 STI
My mistake.
I changed mine out so long ago that I thought I remembered them being stamped steel like the trailing arm. My goal was to optimize my rear settings and that wasnt possible with the stock links. I forget what the limiting factor was, just that I had to get adjustable links.
Fontucky? You mean NASA?
Oh,now I see the link to the SOLO AX stuff. I have done a few AXs and had a lot of fun. I think I even did one with you guys one windy day last winter at Fontana. I'll try and go to some if it fits my schedule. I have about 15 car races planned as well as about 20 motocross races for my kids and some DH bike races too. I have my whole "team" to consider...
Old 01-03-2008, 10:23 PM   #24
kursplat
Member#: 89528
2005 sti
crystal grey
... I have about 15 car races planned as well as about 20 motocross races for my kids and some DH bike races too. I have my whole "team" to consider...
i know how that is. now my daughter's got her eye on a kart
06 rear lateral link Emperor WuRM Private 'Wanted' Classifieds 0 06-11-2008 10:51 PM
FS Burbank: WRX slotted Rear rotors & STi Cusco Rear Lateral links twizhimself SCIC Private Classifieds 12 09-03-2007 06:57 PM
pillowball or OEM lateral link? do they wear out faster? psun786 Brakes, Steering & Suspension 9 11-06-2005 02:03 PM
WTB: Stock WRX IC, rear lateral links DeusExMachina Private 'Wanted' Classifieds 3 10-04-2005 12:53 AM
WTB stock or aftermarket rear lateral links. PM ME shadoboxer Mid Atlantic Impreza Club -- MAIC 5 02-01-2005 02:18 PM
